0 registered members (),
210
guests, and 52
spiders. |
Topics36,748
Posts594,299
Members6,775
Most Online723 Dec 5th, 2019
Re: Advice sought re "1 shot lubrication" system
[Re: Graham, G4FUJ]
#600340
21/10/19 08:30 PM
21/10/19 08:30 PM
Posts: 281 Cotswolds
SteveH
Cotswolds
Hi Graham Good to see you on Saturday. β- unfortunately like ships in the night once again. Greasing. We fitted remote greasers (as recommended by Ian ) and pp gaiters from Concourse Dave. Seem to work really well as long as Pauline is still nimble enough to twist her neck underneath and watch out for the grease in between services. Once a year we put her (the Morgan that is ) on the ramp and work clean grease through the pillars. It doesnβt help me run Prescott any quicker - but it makes me feel good πππ
Stingmog
[Re: SteveH]
#600367
22/10/19 06:52 AM
22/10/19 06:52 AM
Posts: 22,881 Cheltenham, Glos. UK
And you Steve. Not quite as busy as I expected (though the fist train from CRC was packed). Put a note in another thread in Morgan Arms.
Graham (G4FUJ) D8921 L44FOR '93 4/4 Giallo Fly 2 seat  '90 LR 90 SW '07 MINI Cooper
[Re: CarMart]
#600484
22/10/19 08:00 PM
22/10/19 08:00 PM
Posts: 324 Colorado, USA
britmog
Colorado, USA
Robbie,
I didn't use the one shot oiler for a long time, the problem occurred with the piping becoming brittle and starting to leak. You do want to have a leak in the system before the foot switch as it is under pressure and loss of oil could be catastrophic. As I was not using the system I simply removed the pipe to the foot switch, relocated the oil pressure sender to the oil filter housing and eliminated the issue.
Bruce Marshall 1964 4/4 Series V Comp (Megan) 1994 +8 (Maurice) 2013 M3W (Olga)
[Re: CarMart]
#600611
23/10/19 02:34 PM
23/10/19 02:34 PM
britmog
Colorado, USA
Of course in the post above I should have said "You do NOT want to .........."
[Re: CarMart]
#600679
23/10/19 09:25 PM
23/10/19 09:25 PM
Posts: 6,527 Warks
NeilL
Warks
I saw ..and used ..the One Shot system this week on a 4/4 I was looking at. It seemed v v simple. And worked v well for the owner. The King Pins have just been replaced after 40,000 miles!
Neil
