28 registered members (Mogdriver, John V6, Phil4/4, Craig Jezz, Jon G4LJW, Heinz, RJW, Spanner Juggler, DaveW, HJP, Swedewheeler, milliemollie, MDS61, Hamwich, John Winn, +8Rich, Clipper, Alan Patterson, BertR, Menm, TBM, bilibib, RoyH, M3W55, Image, sospan, Doug J, HeadlessBlue), 132 guests, and 28 spiders.
+8Rich 442
John V6 428
TBM 234
Heinz 191
Fabulous Aeromax
by +8Rich. 06/06/20 08:29 AM
Sidescreens for 96 +4 2 seater
by Mogdriver. 06/06/20 08:07 AM
Steeriing gaiter split
by Mats. 06/06/20 07:38 AM
Morgan 100 Programme 10
by Hotwells. 05/06/20 07:09 PM
Steel Sprocket
by Dutch. 05/06/20 07:07 PM
1981 +8 water pipes
by GARYMYNARD. 05/06/20 04:54 PM
Plus 4 Push Button Start?
by Nostalgiajohn. 05/06/20 02:45 PM
Hard Top Badge
Glove box net
sump/crossmember guard
The great escape
Sidescreen Mounting in Storage
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,428
Posts629,918
Members6,938
Most Online1,033
Dec 28th, 2019
DaveK, James Nolan
Page 6 of 7 1 2 3 4 5 6 7
Re: Compensator dilema. [Re: planenut] #601088
26/10/19 10:02 AM
26/10/19 10:02 AM
Grindelwald Switzerland
Laurens Offline
Laurens  Offline
Originally Posted by planenut
Inspecting through the grease hole, my Centa rollers look good after 12,000 miles but I will find out for sure when I take the engine out next week for Phils mods. My rollers were fitted just over two years ago and were supplied to me by MMC as "improved trial" items. They seem to have lasted better than the original early 2015 items that fell apart after just under 10,000 miles. Maybe all you need to do is have post 2017 Centa rollers fitted? That said, Phil Bleazeys mods do much more for the feel of the car than just improve drivetrain life.
What kind of different feel will it give the Phil Bleazey rubbers or upgrade ? And if I’m correct informed PaulR does have the Phil Bleazey upgrade but with the original rubbers ? !
www.m3w-jungfrau-treffen.com
Re: Compensator dilema. [Re: Laurens] #601098
26/10/19 10:15 AM
26/10/19 10:15 AM
Lancaster
Phil Bleazey Offline
Lancaster
Originally Posted by Laurens
Would it make sense (or is it possible) to make the ˋgrease hole ˋ bigger so we could easily exchange the rollers like on the Phil Bleazey upgrade ? Or is it only possible to cut this hole bigger when the engine is out ?
It is not just the bigger hole that makes it possible Laurens. the middle rotor of the Centa unit has to be assembled the other way round ( as it should be ) with the removable flange on the outside of the unit. see here for details http://www.bleazey.co.uk/M3Wstage3text.htmlhttp://www.bleazey.co.uk/M3Wstage3text.html
Phil
2013 M3W www.bleazey.co.uk - Builder of upgrade kits for the Centa coupling and BB mounts for M3W
Re: Compensator dilema. [Re: PaulV] #601099
26/10/19 10:19 AM
26/10/19 10:19 AM
Lancaster
Lancaster
Originally Posted by PaulV
My 2015 has had frayed bits of rubber come out of the inspection hole. Naturally come warranty time the dealer said something like "nothing to worry about sir" and "you would know if they had failed" (yes, I found bits of rubber smile )... but so far no issues with performance. I have to fit the Phil-mod for the bevel box before I worry about the rollers...
Drive carefully Paul, the rubber rollers exert huge sideways force on the intermediate shaft when any one ( or more ) starts to disintegrate and if you have the original set up, the shaft only has one bearing - at the other end! That said most of my customers arrive with various degrees of disintegration of the rollers and no reports of that bearing failing yet.
Phil
Re: Compensator dilema. [Re: Dab of oppo] #601103
26/10/19 10:39 AM
26/10/19 10:39 AM
Warks
NeilL Offline
NeilL  Offline
Warks
Paul - IMO this is clear signs of the Rollers breaking down - its a warranty issue scared
Neil
Re: Compensator dilema. [Re: Laurens] #601139
26/10/19 02:33 PM
26/10/19 02:33 PM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
I have driven Bunnies car after the Bleazey Centa mods and it is smoother than before and smoother than my similarly aged M3W. The transmission seems to cope much better with low rpm and starting from still is (almost) like an ordinary car, quite an achievement with a lumpy V-twin and some built in transmission wind up. I think it is worth doing, so I am soon smile . PaulR tells me that there is very little difference, that he can detect, between Phils rubber inserts and the standard ones. He has tried both as it is a quick job to change them after the mods. Being able to replace the inserts easily is one of the major plus points I think.
Re: Compensator dilema. [Re: planenut] #601169
26/10/19 05:34 PM
26/10/19 05:34 PM
Cheshire, UK
nippymog Offline
nippymog  Offline
Cheshire, UK
+1 , given impressions from my car after Phils upgrade
Re: Compensator dilema. [Re: Dab of oppo] #601183
26/10/19 06:20 PM
26/10/19 06:20 PM
Gods own county! Oop north
Dab of oppo Offline OP
This is one of my dilemmas, with the old HD comp. there was no slop, wind up or clonking in either forward or reverse, it was just like a “normal car”. Solid drive from crank to gearbox.
Does anyone suffer these characteristics with the standard Centa comp?
Still not decided which way to go.
Re: Compensator dilema. [Re: Dab of oppo] #601194
26/10/19 08:44 PM
26/10/19 08:44 PM
West Sussex, UK
Chris99 Offline
Chris99  Offline
West Sussex, UK
I recently drove a new M3W with <700 miles and a MMC stage 1 exhaust. It was a revalation of smoothness compared to my pre replacement 30k+ car.
It'll be interesting how my car performs with a new clutch and rollers and hope to get it back next week so will report then.
Red Leader drive
Re: Compensator dilema. [Re: Chris99] #601197
26/10/19 09:29 PM
26/10/19 09:29 PM
Oxford, U.K.
Ricardo Offline
Ricardo  Offline
Oxford, U.K.
I think this could be the car you’re referring to Chris 🤓
https://youtu.be/6GBXC0vDfWs
Re: Compensator dilema. [Re: Dab of oppo] #601252
27/10/19 03:41 PM
27/10/19 03:41 PM
West Sussex, UK
Chris99 Offline
Chris99  Offline
West Sussex, UK
thumbs
Filmed mainly on Ranmore Common between Dorking and West Horsley - a lovely bit of road woohoo
The car's for sale at Bell & Covill and the colour looks even better in the flesh smile
Red Leader drive
Moderated by  Aeroman
