13 registered members (kankeL, IcePack, Craig Jezz, LightSpeed, +8Rich, Ray, LE52MOG, Rog G, Graham, G4FUJ, TBM, Mike D, BertR, TheCustomer), 136 guests, and 18 spiders.
+8Rich 256
John V6 120
Peter J 118
Hamwich 111
Radio reception
by Riverstar. 26/01/20 12:51 PM
Coronavirus / Corona Virus
by Cat302. 26/01/20 01:54 AM
Wiper end caps
by David_E. 25/01/20 10:19 PM
Speedometer Calibration
by planenut. 25/01/20 09:02 PM
Easy-Up Hood stay
by Themorganeer. 25/01/20 07:37 PM
Aerial Fitting "HELP"
by Nostalgiajohn. 25/01/20 07:19 PM
Germany - an aera of MORGAN thieves?
by xc68anc. 25/01/20 02:01 PM
New year walk
Seals and wreck of the Ythan estuary,
Saint Ex the Morgan in all its glory
Bevel box oil leak
Hogmanay Run
craig123, Martin Medland, banjo2005, kailambers, Martin Peel
6812 Registered Users
Topics37,081
Posts601,725
Members6,812
Most Online1,033
Dec 28th, 2019
No Birthdays
2006 Roadster Exhaust flange gasket #601879
01/11/19 04:25 PM
01/11/19 04:25 PM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
My Roadster exhaust has a blow on the drivers side where the manifold meets the cat. This is a triangular gasket.
The MMC parts book has it as part MX1309 Ex flange gasket.
None of the usual suspects stock it but it looks like a common item fitted to many vehicles.
Does anyone have a spec for it?
2006 Indigo Blue Roadster S1
Re: 2006 Roadster Exhaust flange gasket [Re: John V6] #601888
01/11/19 04:59 PM
01/11/19 04:59 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
I wrote this in the „any known issues 3.7“ thread:
„It's been 12.5 years since I had given up the series 1 Roadster, so the exact memory has faded a bit. But there is a connection with a flange gasket. Either it was between the manifold and the catalytic converter or behind the catalytic converter I can't remember exactly. This gasket (on both sides) never lasted longer than 4000 km. You can hear it immediately when it blows and the performance is significantly lower.“
Meanwhile I am pretty sure it was the same gasket as you describe John. I do not know a parts number but it could be worth to think about a stronger replacement gasket which a exhaust maker could perhaps cut to the right dimensions, or if different suppliers are there to chose the strongest offer. This gasket is a weak point.
Re: 2006 Roadster Exhaust flange gasket [Re: John V6] #601897
01/11/19 05:48 PM
01/11/19 05:48 PM
Suffolk
John V6 Offline OP
John V6  Offline OP
Suffolk
Heinz,
this went at 44,500 miles. I never heard of other failures.
Re: 2006 Roadster Exhaust flange gasket [Re: John V6] #601900
01/11/19 05:50 PM
01/11/19 05:50 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Never had one let go in 50k miles on an S1, so for me that's reliable
John, I think Brands Hatch had them in stock for a fellow S2 owner last year
Re: 2006 Roadster Exhaust flange gasket [Re: John V6] #601905
01/11/19 06:08 PM
01/11/19 06:08 PM
Perthshire & London
flyfisher Offline
flyfisher  Offline
Perthshire & London
This went on my Dads Series 1, Simon at Sifab had them in stock if not it was from Revolutions in Perth
Re: 2006 Roadster Exhaust flange gasket [Re: John V6] #601930
01/11/19 10:36 PM
01/11/19 10:36 PM
SimonH Offline
SimonH  Offline
The gaskets are rubbish, I gave up in the end on the Roadster Lightweights as I was changing so many and glued the flanges with High Temperature Silicone...
Simon @ Sifab.co.uk
Re: 2006 Roadster Exhaust flange gasket [Re: John V6] #601932
01/11/19 10:54 PM
01/11/19 10:54 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
At that time I drove the Roadster very sporty. I was 14 years younger than now. Actually, I always demanded full power because it was a lot of fun. And on the motorway I liked to drive 190 km/h over a longer period of time, in dry conditions and without traffic. Mostly the gaskets got broken when I went in second gear to highest rpm. It can be that other experiences are more positive as described above in the posts. I always had trouble with these seals.
Re: 2006 Roadster Exhaust flange gasket [Re: Heinz] #601988
02/11/19 02:26 PM
02/11/19 02:26 PM
Aerdenhout, The Netherlands
BertR Online content
BertR  Online Content
Heinz, I share with you the joy of driving the Roadster at high speed, it is an adventure. I recall driving Munchen to Amsterdam couple of years ago. Earplugs are a must, what a noise!
2009 Roadster, Lancia midnight blue, cinnamon upholstery.
Re: 2006 Roadster Exhaust flange gasket [Re: John V6] #601994
02/11/19 03:35 PM
02/11/19 03:35 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
Yes I used ear plugs as well at that time when driving so fast, Bert. And I trusted the aluminum 5 bolt wheels. I am not sure if I would drive so fast with centre lock spoke wheels.
Moderated by  Aeroman, Simon
