15 registered members (Deejay, Gordon D, AAJ, Image, IcePack, John V6, PeterVD, MOG 615, RoyH, RedThree, Luddite, tmg513, Hamwich, MR11MOG, BLUE+4), 131 guests, and 15 spiders.
+8Rich 325
John V6 254
TBM 180
Alistair 151
Hamwich 146
Help needed
by Gambalunga. 24/09/20 11:36 AM
3.7 Roadster turn signal noise.
by John V6. 24/09/20 11:09 AM
Local dialect
by Gordon D. 24/09/20 10:23 AM
Inside the Spitfire Factory
by Ian Wegg. 23/09/20 08:45 PM
Inside the spitfire factory
by IMHO. 23/09/20 08:06 PM
Wots Your Grammer Like?
by Clipper. 23/09/20 07:58 PM
Creaking kingpins
by Grumpy2. 23/09/20 07:10 PM
wait for it
Stonor breakfast club - Oxfordshire
Cotswold Classic Tour 19/9/20
Rattray and Troup 4/4 80th
A grand day out
Koopz, hashluck, KennyW, David Stepanis, Malroy
7166 Registered Users
Topics39,449
Posts651,139
Members7,166
Most Online1,033
Dec 28th, 2019
No Birthdays
Page 5 of 5 1 2 3 4 5
Re: how does the heater work? [Re: Grumpy2] #601822
01/11/19 07:30 AM
01/11/19 07:30 AM
Petersfield, Hampshire
Ian Wegg Offline
Ian Wegg  Offline
It's not easy to see (or photograph) but I've just crawled under the dash to confirm what is engraved on my 1980's car heater control - and it says PUSH FOR HEATING.
Slightly surprised at that as I was sure the heater works when the knob is pulled out.
So no help there, sorry!
1980 Royal Ivory 4/4 4-seater.
Re: how does the heater work? [Re: Ian Wegg] #601849
01/11/19 12:24 PM
01/11/19 12:24 PM
Dutchman living near Roosendaa...
Anthony4/4 Offline
Anthony4/4  Offline
The same as mine 1980 Signal Red B4696. Noticed it after your message Ian! Many thanks, my feet where burning last summer :))
Mercedes Sprinter 308 2001
VW Passat Station 2011
Morgan 4/4 1980
Re: how does the heater work? [Re: Grumpy2] #602108
03/11/19 02:05 PM
03/11/19 02:05 PM
Cambridge UK
Stephen888 Offline
Stephen888  Offline
Cambridge UK
On my 1980 +8 it's Push for ON, Pull for OFF. Engraving has long since disappeared. Needed to fit a replacement ignition barrel a few years ago and that then fouled the operation of the Pull/Push cable so had to move it.
1980 +8 Blue
Stephen
Re: how does the heater work? [Re: Grumpy2] #602110
03/11/19 02:12 PM
03/11/19 02:12 PM
Staffordshire
IvorMog Offline
IvorMog  Offline
Staffordshire
I wonder when MMC stopped fitting the heater valve on the 4/4?
Certainly haven't got one on mine.
Bob
1999 4/4 2 litre Zetec
Re: how does the heater work? [Re: Grumpy2] #602565
07/11/19 08:59 AM
07/11/19 08:59 AM
The frozen North
Jack The Lad Offline
Posting Desperado
Posting Desperado
The frozen North
You lads down South must be getting soft a few miles in your Mog and the heat from the engine warms your legs . A good tip is a three zip ton cover stops some of the heat getting out or some of the rain getting in as much . Try up the Frozen North when the wind blows over from Russia, that is cold . Hence I purchased some German tank overalls with linings .
Re: how does the heater work? [Re: IvorMog] #602645
07/11/19 06:39 PM
07/11/19 06:39 PM
Buckinghamshire
Alexander Offline
Alexander  Offline
Buckinghamshire
Originally Posted by IvorMog
I'm going to add a valve so I can turn it off in hot weather as a bit of the hot air always finds it's way past the flap even in the off position.
I've been through a couple of these valves, and found that they all tend to leak hot water (through the valve), leading to the heater being permanently on.
Please see this topic, where I fit an electrically operated ball valve, that blissfully is leak free, and was good for the summer.
I'd recommend it over the originally fitted cable operated valves.
Re: how does the heater work? [Re: Grumpy2] #604455
21/11/19 01:45 PM
21/11/19 01:45 PM
Chester, UK
Grumpy2 Offline OP
Grumpy2  Offline OP
Chester, UK
I know its been a wile but I finally managed to get some time on a relatively dry day to try out my newly working heater.
I can confirm that the under dash knob is Push for ON. And now the fan blower works the footwell is particularly toasty. There is no control to alternate between footwell and screen demist, if I want hot air on the windscreen I have to close all four foot well vents.
Magic!
94 plus 8 in Westminster Green - I think!
Re: how does the heater work? [Re: Alexander] #604458
21/11/19 02:09 PM
21/11/19 02:09 PM
Staffordshire
IvorMog Offline
IvorMog  Offline
Staffordshire
That's a neat solution.
Can you use a standard 15mm copper pipe with these to connect into the heater circuit pipes?
Bob
Re: how does the heater work? [Re: IvorMog] #604597
22/11/19 03:41 PM
22/11/19 03:41 PM
Buckinghamshire
Alexander Offline
Alexander  Offline
Buckinghamshire
You probably could. I just clamped the heater hose onto a short length of 15mm copper fixed to the ball valve.
Works a treat!
Moderated by  Aeroman, Simon
