21 registered members (Graham, G4FUJ, +8Rich, John Winn, bmgermany, KR200, MJF, petemog, Eastertown, DCH, Snowden, TBM, byeck, Budster, Sinbad, Ian Wegg, Richard J, kar120c, John V6, Hawki, planenut, JCK), 128 guests, and 17 spiders.
John V6 435
+8Rich 402
Hawki 178
Seawolf in Port today
by +8Rich. 14/07/20 04:03 PM
Hi From Somerset
by Eastertown. 14/07/20 02:58 PM
Back with three wheels on my wagon
by donaldosaurus. 14/07/20 01:05 PM
indicators fault
by Paul F F. 14/07/20 11:41 AM
Do you remember.
by BLUE+4. 14/07/20 11:37 AM
Keeping cables tidy....
by TBM. 14/07/20 10:44 AM
WANTED - Plus 4 Supersports
by KR200. 14/07/20 08:09 AM
peek a boo
Donington Sunday (part 2)
Donington Sunday
My old Matt black Aero
No More Five Mile Limit
Brize, Kevin Hawkins, GJT, Don70, Eastertown
7062 Registered Users
Topics38,788
Posts637,839
Members7,062
Most Online1,033
Dec 28th, 2019
john humphreys
Offside lights gone out #602621
07/11/19 04:47 PM
07/11/19 04:47 PM
Surrey
Kevcaster Offline OP
Surrey
I arrived back from a run today to notice that both the offside front lamps had stopped working, wing lamps and headlamps/side lamps. I looked at the fuses but all seems fine, nearside lights are all working - this seems strange, any one out there with ideas on this?
Kevin
2009 Morgan Plus 4 4 seater
Re: Offside lights gone out [Re: Kevcaster] #602632
07/11/19 05:23 PM
07/11/19 05:23 PM
London
MOG 615 Offline
MOG 615  Offline
London
Have a look at the earth connections for the offside?
Andy G
1999 +8 , Indigo Blue.
Re: Offside lights gone out [Re: Kevcaster] #602634
07/11/19 05:40 PM
07/11/19 05:40 PM
Llanelli
sospan Offline
sospan  Offline
Llanelli
Also check the condition of the wiring under the wing. It is a tough environment. I replaced the bullet connectors on mine as they were badly corroded and intermittent lighting issues., I had to cut them off as they were solid. Replaced and sealed the new spade ones with shrink tubing.
Red Plus8
Re: Offside lights gone out [Re: Kevcaster] #602656
07/11/19 07:34 PM
07/11/19 07:34 PM
Cheltenham, Glos. UK
Graham, G4FUJ Online content
Graham, G4FUJ  Online Content
Proper electrical test of the relevant fuse necessary. Often visual checks are insufficient.
If it has blown you will want to find why - did you have anything plugged into the accessory socket (which may well be on the same fuse)?
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'07 MINI Cooper
Re: Offside lights gone out [Re: Kevcaster] #602666
07/11/19 08:32 PM
07/11/19 08:32 PM
East Harling, Norfolk UK
Richard Wood Offline
It's not the fuse if it affects both headlamp and sidelights, but likely a common earth. There is a four way connector behind offside headlamp bowl. The wiring diagram suggests this is in a bag taped to back of bowl. Check the black earth wire integrity here. If ok then check the actual chassis earth by tracing the black wire that runs to 5mm ring connector bolted to chassis/wing.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Offside lights gone out [Re: Kevcaster] #602678
07/11/19 09:52 PM
07/11/19 09:52 PM
Surrey
Surrey
OK much appreciate the information. I will take a look tomorrow morning and see if it might be within my limited capability, otherwise a trip to Bell and Colvill for a warranty fix.
Yesterday I took it to them for a diff leak investigation, on the way the engine warning light came on which they reset. Today it came on again and so I imagine that something is going on in the labyrinth.
As you can probably sense I’m less than a novice at anything to do with cars and especially electrics which of course is a form of magic.
Kevin
Re: Offside lights gone out [Re: Kevcaster] #602694
08/11/19 07:00 AM
08/11/19 07:00 AM
Austria, Vienna area
The Austrian Offline
Check the connections next to the wiper motor.
If connections got loose there some strange effects may be the result.
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Re: Offside lights gone out [Re: Kevcaster] #602751
08/11/19 02:49 PM
08/11/19 02:49 PM
Suffolk
John V6 Online content
John V6  Online Content
Suffolk
With mine it was the earths.
2006 Indigo Blue Roadster S1
Re: Offside lights gone out [Re: Kevcaster] #602753
08/11/19 03:20 PM
08/11/19 03:20 PM
Evergreen, Colorado, USA
britmog Offline
britmog  Offline
The Golden rule with Morgans regarding electrical issues is first check the Earths. The Prince of Darkness lurks everywhere!!
Bruce Marshall
1994 +8 (Maurice)
2013 M3W (Olga)
Re: Offside lights gone out [Re: Kevcaster] #603223
12/11/19 05:56 AM
12/11/19 05:56 AM
Kevin: did you find the bug?
Hannes
Moderated by  Aeroman, Simon
