7 registered members (HeadlessBlue, Rob Thornton, MOG 615, Alan Patterson, brownbaker, Fuel.inj, Image), 217 guests, and 18 spiders.
John V6 475
+8Rich 388
TBM 247
Heinz 200
Reassurance for the over 60s
by Peter J. 29/05/20 04:36 PM
Bonnet locks
by Marmota. 29/05/20 02:27 PM
What about Brexit/climate change etc.?
by Luddite. 29/05/20 02:17 PM
My Latest ‘Poverty’ Solution
by Budster. 29/05/20 10:03 AM
After sales.
by Obie. 29/05/20 09:24 AM
rear brakes - again
by Grumpy2. 29/05/20 08:34 AM
Covid-19 Lung Transplant
by Gambalunga. 29/05/20 08:03 AM
Plus four Test Drive
Engine running!
Slow progress
Social distancing
Somewhere in Scotland?
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,357
Posts628,518
Members6,938
Most Online1,033
Dec 28th, 2019
No Birthdays
Away with spare wheel, new trunk instead #602719
08/11/19 11:43 AM
08/11/19 11:43 AM
Rosenheim, germany
Fraenkie Offline OP
Fraenkie  Offline OP
Rosenheim, germany
Hi @All,
the search gave me no result, so i ask a funny question: i m missing a trunk for the side doors, because i ve got a spare wheel at the back of my 2009 Roadster. Is there anyone or are there any spare parts, so i could switch to a trunk for side doors and park my spare wheel at home?
Frank
Re: Away with spare wheel, new trunk instead [Re: Fraenkie] #602723
08/11/19 12:08 PM
08/11/19 12:08 PM
Luddite Offline
Luddite  Offline
Sorry not to fully understand your request Frank.... IF you are looking for a rack that provides side-screen storage, perhaps this might suit..?
http://shop.morgan-cars.com/product.php?productid=134
I am sure there will be other suppliers out there..
Re: Away with spare wheel, new trunk instead [Re: Fraenkie] #602726
08/11/19 12:15 PM
08/11/19 12:15 PM
Rosenheim, germany
Fraenkie Offline OP
Fraenkie  Offline OP
Rosenheim, germany
Sorry for my bad english. I think about putting the spare wheel complete off, closing the hole in the alloy, opening a new hole back the seats, to create a new "tray fold" for the side screens. I always thougt, that some cars, which have no spare wheel, are having this tray included?
Thanks Luddite!
Re: Away with spare wheel, new trunk instead [Re: Fraenkie] #602727
08/11/19 12:22 PM
08/11/19 12:22 PM
Vienna, Austria
Michael P Offline
Michael P  Offline
Vienna, Austria
Hi Frank,
The classic Morgans are produced ex works either with or without spare wheel. With a spare wheel, the side doors are stowed on the luggage carrier (they have their own compartment for this). See Link provided by Luddite.
Alternatively, the side windows can be stowed behind the seats, provided that the seats are not pushed all the way back (is a question of body size).
The Morgans without spare wheel have a compartment for the side doors and a complete different back panel (and different frames underneath).
To install such a compartment in a Morgan, which originally had a spare wheel, would mean a complete conversion of the rear. I don't know of any case where someone would have done that.
Michael
2018 Plus 4 Sport
Re: Away with spare wheel, new trunk instead [Re: Fraenkie] #602728
08/11/19 12:24 PM
08/11/19 12:24 PM
southwest France
meabh Offline
meabh  Offline
southwest France
And here am I thinking that I would like to open up the back of my Roadster Sport and putting a removable louvered panel there as per my P4. At least then I can get to the fuel pipe.
Re: Away with spare wheel, new trunk instead [Re: Fraenkie] #602731
08/11/19 12:35 PM
08/11/19 12:35 PM
Vienna, Austria
Michael P Offline
Michael P  Offline
Vienna, Austria
Here some pictures for explanation.
The middle frame in the stack shows the frame for the spare wheel attachment. This frame is missing on the Morgans without spare wheel:
This is what it looks like from the inside of a Morgan without a spare wheel (Plus 4 Sport 2018):
And so from the outside:
Michael
2018 Plus 4 Sport
Re: Away with spare wheel, new trunk instead [Re: Fraenkie] #602754
08/11/19 03:25 PM
08/11/19 03:25 PM
Cornwall
griffo Offline
griffo  Offline
Cornwall
Spookily I have just done finished this job on Possum (the 2014 exGDI turbo Plus 4). It's quite easy. Simply remove the spare wheel, the bracket that holds it and the ghastly "cyclops" high level brake light if you have not junked that already. Order a louvred aluminium spare wheel panel from VSM Malvern. Speak to Jeff -- you need to tell him the size of your hole (perhaps I should re-phrase that!). I then made up two alloy brackets with rivnuts for the bottom sides of the panel which comes fitted with a clip on the top edge. The cover needs a rubber U bead to prevent metal to metal paint damage. I then re-fitted the high level brake light. Since I've just finished mine it's still in the raw ally and I haven't decided to paint it (royal ivory or perhaps satin black) or just leave it. I shall only cart around the extra weight of a spare wheel when going on overseas trips or when I need to use the wheel to strap a case to. A couple of Finelec style pressure/sealer cans will have to suffice otherwise. If the image I've tried to attach above does not come out I'll put one in the photo forum. Photo does not seem to appear so please see general photo gallery.
Re: Away with spare wheel, new trunk instead [Re: Fraenkie] #602756
08/11/19 03:39 PM
08/11/19 03:39 PM
Evergreen, Colorado, USA
britmog Offline
britmog  Offline
Griffo: Looks good, did you create the new trunk space as I believe this is the main issue?
Bruce Marshall
1994 +8 (Maurice)
2013 M3W (Olga)
Re: Away with spare wheel, new trunk instead [Re: Fraenkie] #602763
08/11/19 04:27 PM
08/11/19 04:27 PM
Cornwall
griffo Offline
griffo  Offline
Cornwall
"did you create the new trunk space?"
No I think that would be a much bigger job because of the frame as per Michael's pictures. In any case I dont want to lose the option of re-fitting the spare wheel if at some point I need to use the luggage rack and a suitcase. The other
problem is that, with a louvred wheel cover, the trunk space would suffer from the wet unless it was completly sealed. My main motive was to reduce weight -- like Colin Chapman I hate excess weight in a car.
Re: Away with spare wheel, new trunk instead [Re: Fraenkie] #602772
08/11/19 05:13 PM
08/11/19 05:13 PM
southwest France
meabh Offline
meabh  Offline
southwest France
Re: not carrying a spare wheel. I have used Bike Seal. They are very helpful. Speak to Tracy or Dale.
Moderated by  Aeroman, Simon
