18 registered members (CooperMan, P964, JMcL, Jon G4LJW, Heinz, griffo, 2Sharp, FrancisD, MR11MOG, Richard Wood, TBM, Peter J, t50, thelastgizmo, Budster, yobtaf, Dada, +8Rich), 235 guests, and 22 spiders.
+8Rich 402
John V6 328
Alistair 128
Hawki 120
Roadster Radiator leak
by mal. 10/08/20 10:07 AM
1990 +8 Rear Brakes
by jeremylparker. 09/08/20 11:43 PM
Stub Axles -?repaint
by NelsonG. 09/08/20 11:27 PM
Visitor Centre
by wigmog. 09/08/20 07:18 PM
Ginetta Juniors
by Budster. 09/08/20 01:30 PM
Key transponder issue
by The Austrian. 09/08/20 10:46 AM
Steering balljoint torque
by MOG42. 08/08/20 06:39 PM
riding through the montains
SNOWDONIA B4407/A543
GTN Soft top re-fitted
GTN Visors
A Great Escape to Orford & Snape Maltings
WLPM, Lilliput, Andrew1806, RBooth, Martien
7087 Registered Users
Topics39,022
Posts642,494
Members7,087
Most Online1,033
Dec 28th, 2019
No Birthdays
Page 1 of 4 1 2 3 4
Painted or powdercoated front wheels #603342
12/11/19 09:33 PM
12/11/19 09:33 PM
Port Orchard, WA.
LightSpeed Offline OP
Port Orchard, WA.
Question: are the oem black wire wheels painted black or are they powdercoated black?
Stephen
2019 M3W piling on the Covid miles
Re: Painted or powdercoated front wheels [Re: LightSpeed] #603347
12/11/19 10:13 PM
12/11/19 10:13 PM
SW Iowa, U.S.A.
Bitsobrits Offline
Bitsobrits  Offline
SW Iowa, U.S.A.
Can't answer your question, but I have confirmed that they are made by MWS, so an email to them could likely get you an answer. Their website is mwsint.com and one email address I have is isabella@mwsint.com.
2012 M3W #458
Iowa, U.S.A.
Re: Painted or powdercoated front wheels [Re: LightSpeed] #603349
12/11/19 10:19 PM
12/11/19 10:19 PM
Rio Del Mar, CA
kankeL Offline
kankeL  Offline
Rio Del Mar, CA
2016 M3W, Army Green Matte/Tan Leather, 13k miles
Re: Painted or powdercoated front wheels [Re: kankeL] #603359
12/11/19 11:40 PM
12/11/19 11:40 PM
Port Orchard, WA.
Port Orchard, WA.
Originally Posted by kankeL
That must be it since I did spot the MWS logo on the rim and sticker on the hub. Thanks for steering me there, can’t believe it didn’t occur to me.
The local powdercoater asked me and I was not positive.
Stephen
Re: Painted or powdercoated front wheels [Re: Bitsobrits] #603360
12/11/19 11:42 PM
12/11/19 11:42 PM
Port Orchard, WA.
Port Orchard, WA.
I will ask her in the odd chance they did something special for Morgan, thanks.
Stephen
Re: Painted or powdercoated front wheels [Re: LightSpeed] #603396
13/11/19 12:40 PM
13/11/19 12:40 PM
Port Orchard, WA.
Port Orchard, WA.
For all of you that are curious, although their web site states the wheels are painted they are actually powdercoated.
This is MWS reply to my query.
Good morning Stephen,
Thank you for your request.
All our stock painted wheels (black and silver) are powder-coated.
The MWS wire wheels are primer coated using Cathodic Electrophoretic technology. This increases the corrosion resistance to very high levels. A topcoat of silver ash or black follows this.
The paint system provides salt spray resistance of 840 Hours when tested and evaluated on panels as per ASTM B117.
Please do not hesitate to contact me for any other question you may have.
Kind Regards,
Fatima Bouaziz
So, I asked the best/recommended method to powdercoat their wheels and pointed out their web site states “painted”. This is the response.
Hi Stephen,
Sorry you are right, the wheels are not powder coated but primed with electrodeposition coating, the topcoat is spray paint and finish with stove enamelling (wet paint).
Getting your wheels powder coated should be straight forward.
Our paint shop usually shot blast them first.
Your paint shop should be able to give you more information about their process.
Kind Regards,
Fatima Bouaziz
Stephen
Re: Painted or powdercoated front wheels [Re: LightSpeed] #603420
13/11/19 03:31 PM
13/11/19 03:31 PM
norfolk, UK
lowebird Offline
lowebird  Offline
norfolk, UK
My Morgan wheels were the standard silver and were starting to show signs of rust after 4 years despite regular cleaning.
Reg
Re: Painted or powdercoated front wheels [Re: LightSpeed] #603424
13/11/19 03:50 PM
13/11/19 03:50 PM
Port Orchard, WA.
Port Orchard, WA.
4 years and showing signs of degradation. Another reason to powder coat the wheels.
When I was prepping the wheels to take to the powdercoated I noticed that the wheel weights were covered by black vinyl electrical tape. Not bad and does perform a cosmetic function but, they took the tape past the end of the wheel weights and that formed a triangular pocket for water and dirt to collect= rust point possibility. Leaving the tape off the new coated wheel weights. Rather look at weights than think about it rusting away in seclusion.
Stephen
Re: Painted or powdercoated front wheels [Re: LightSpeed] #603444
13/11/19 05:57 PM
13/11/19 05:57 PM
Gods own county! Oop north
Dab of oppo Offline
Dab of oppo  Offline
Loose the wheel weights and use Dina Beads instead.
Re: Painted or powdercoated front wheels [Re: Dab of oppo] #603449
13/11/19 06:18 PM
13/11/19 06:18 PM
Staffordshire
IvorMog Offline
IvorMog  Offline
Staffordshire
Powder coating in very tight corners such as around the spoke nipples etc can be a real problem as the Faraday Effect can cause voids in the corners allowing the powder coat to crack and allow moisture in.
I've blagged the short article below from the internet but there is a lot about it if you look.
Not saying it's impossible to get good coverage with powder but ask the questions of your contractor or play safe and wet paint using a rust resistant primer.
By the way, this article came from an American website called powdercoatedtough.com which has an "agony aunt" called Joe Powder. Check it out.
"How do you prevent “Faraday”?
By “Faraday” you undoubtedly are referring to the “Faraday Cage” effect. This is the issue of penetrating a tight inside corner with electrostatically charged powder coating. The electric field produced by the corona charge delivered by the gun creates a dead space of charge within the corner. This dead space repels the deposition of powder. In addition the air volume exiting the gun creates blow-back the further impedes powder deposition. So not only do you get electrostatic repulsion but pneumatic repulsion as well.
So, how do we mitigate this common problem? A few actions will eliminate this issue. First, use a powder spray gun that has a charge limiter device. Most of the recent models have this feature. It essentially detects a build-up of excess charge in the Faraday Cage and automatically reduces the current of the corona charging tip. This diminishes electrostatic repulsion. If you do not have a gun with this feature simply reduce the current of the gun by about 30 percent. For example, if you are spraying at 18 microamps, cut back to 12 microamps. This can usually be accomplished by simply reducing the gun voltage.
Second, use a high volume/low air velocity powder pump system. The major powder gun suppliers have this option which conveys a very high concentration of powder with significantly less air velocity. This helps with Faraday penetration by delivering more powder and less air to the tight corner.
Third, use a slotted gun tip instead of a fan spray tip. This will concentrate the powder stream to the corner.
Fourth, ensure that you have a good connection from your parts to ground. You can check this visually and also with a megohm meter. You should measure less than 1.0 megohms. It is important to use a megohm meter and not a simple volt-ohm meter. Megohm meters actually put out voltage that more precisely ascertains if an acceptable ground is present.
Joe Powder"
Bob
1999 4/4 2 litre Zetec
Page 1 of 4 1 2 3 4
Moderated by  Aeroman
