18 registered members (Scrambledsignals, ChrisConvertible, Phil4/4, Craig Jezz, bmgermany, 3Gs, paulmog, John Robie, pandy, BobJ, teknome, Dean-Royal, bobar, kar120c, petemog, Rob8, +8Rich, Tim W),
177
guests, and 36
spiders. |
Topics36,756
Posts594,450
Members6,777
Most Online723 Dec 5th, 2019
Lucky wet escape
#603562
14/11/19 07:39 PM
14/11/19 07:39 PM
IcePack
Had to use Morgan today. No choice. Very wet drive & silly me took a risk through water under a bridge. I had assed it but obviously wrongly. Car got swamped & spluttered to a halt just the other side of the water. Interestingly seat belt light & h/brake light came on. Tried started engine “hydrauliced” mmmm wait tried again after a few mins. No start but turning over. Waited another few mins engine started but very unhappy. Clouds of steam from every where both sides front & rear. After about 30 secs drove off. Engine still rough but after about 10 miles smoothed out. Chickened out of next flood. Eventually seat belt light went out & H/brake light now on but very dim. Found carpets soaked so not surprised. But what I found interesting is no engine warning light and after being switched off for a couple of hours it has started first time. Sometimes I believe our cars have a soul. Bless her. Oh water can be deeper than it looks. Phew. Will drive it home tomorrow with the carpets on the back shelf.
4/4 Ivory 4.1:1 axle, Jaguar XE R-Sport.
Re: Lucky wet escape
[Re: IcePack]
#603617
15/11/19 10:17 AM
15/11/19 10:17 AM
Posts: 126 West Lancashire
RobCol
West Lancashire
I have a friend who's Golf sucked water into the engine through the air filter and wasn't so lucky. New engine required.
Rob
2012 Sport Grey 4/4
[Re: IcePack]
#603619
15/11/19 10:34 AM
15/11/19 10:34 AM
Posts: 11,790 Salisbury, UK
Peter J
Formerly known as Aldermog
Salisbury, UK
It all depends on where the air intake is. On the roadster it was high up, above the radiator. On the Plus 8 it is low down inside the O/S wing behind the wheel. So, I don't drive the Plus 8 through ANY standing water that is more than a normal puddle...
Peter, Tarka the 'Otter Mog 2014 Plus 8
[Re: IcePack]
#603658
15/11/19 04:04 PM
15/11/19 04:04 PM
PHZI
The newer Plus 8 only. Typical BMW engine layout low mounted air intake! Trad Plus 8 much higher mounted air intake.
[Re: PHZI]
#603674
15/11/19 05:52 PM
15/11/19 05:52 PM
Peter J
Salisbury, UK
The newer Plus 8 only. Typical BMW engine layout low mounted air intake! Trad Plus 8 much higher mounted air intake. what makes no sense is that the low mounted air filter sends air up to a large intake trunk at the top centre of the engine.
[Re: IcePack]
#603694
15/11/19 08:46 PM
15/11/19 08:46 PM
IcePack
Yes I was lucky. I thought the intake on the 4/4 was high enough. I suspect only a little water got past the filter(K&N) & it spluttered to a stop due water splashing over the coil packs etc. She. Hydrauliced on trying the starter. I was through the water but on a hill blocking the road. I guess the engine heat turned the water to steam & allowed it to turn over. Drove it home today 3 1/2 hours all well and seems happy up to 6500 rpm. The horn works too. I have just got to check that the cooling fan cuts in appropriately. Still surprised no engine warning light. Floor nearly dried out. Must think of something to treat the floor with to minimise any long term problems.
