Morgan Aero 8
13 registered members (Culminator, rockabilly john, OZ 4/4, BLUE+4, Chris99, petemog, TBM, blitzzz, Image, Graham, G4FUJ, James B W, Skalman, HeadlessBlue), 227 guests, and 58 spiders.
+8Rich 260
Hamwich 121
Peter J 116
John V6 111
Airborn Supersport
by Rovert. 28/01/20 10:11 AM
Serpentine belt
by Mick Annick. 28/01/20 08:45 AM
4/4 Sport Terrible Access Problems
by Spanner Juggler. 27/01/20 05:13 PM
Avonwood Developments
by Tim Crump. 27/01/20 02:41 PM
New +4 priced from ?
by titus. 27/01/20 11:22 AM
Joy Rainey
by brownbaker. 27/01/20 09:31 AM
Bus Lanes?
by Landy. 27/01/20 05:06 AM
Two Tone Plus 6
Avonwood Developments Box
New year walk
Seals and wreck of the Ythan estuary,
Saint Ex the Morgan in all its glory
craig123, Martin Medland, banjo2005, kailambers, Martin Peel
6812 Registered Users
Topics37,091
Posts601,940
Members6,812
Most Online1,033
Dec 28th, 2019
Hiwex
Page 3 of 3 1 2 3
Re: Battery Drain Rate [Re: Peter J] #601237
27/10/19 12:38 PM
27/10/19 12:38 PM
France
chanteclair Offline
chanteclair  Offline
France
Originally Posted by chanteclair
We had a friend with an Aero arrive here a couple of years back and it turned out that a seemingly good battery was going flat overnight however if he operated the inertia kill switch, thereby disconnecting the battery, it would start without problems the next morning. We went to the local auto electrician and discovered two things: 1) there was a constant drain on the battery that was enough to flatten any battery overnight, and 2) the battery was a little down on power and needed replacing.
It was too difficult to identify the source of the drain but when the battery was replaced the current drain dropped back to virtually normal for the various small items that had to remain live to some degree, central locking, radio, etc.
So it seems that if the battery is not fully up to the correct voltage some item in the car was not fully disconnecting when the ignition was turn off. With a fully charged battery the item turned off correctly. confused2 confused2 confused2
This friend it was me .... Chanteclair
Has the Plus 6 arrived yet smile
Not yet Ihope on December the 1 th
Re: Battery Drain Rate [Re: Peter J] #601240
27/10/19 12:41 PM
27/10/19 12:41 PM
France
chanteclair Offline
chanteclair  Offline
France
Not yet, I hope December the 1 th
Re: Battery Drain Rate [Re: Peter J] #603547
14/11/19 06:39 PM
14/11/19 06:39 PM
Dorset, UK
milligoon Offline
milligoon  Offline
Dorset, UK
Peter would you like me to come around with my FLIR camera and see what is hot! It'll be the various instrumentation adaption modules along with the Immobilizer, you'll probably find a hot CANBUS or LINBUS chip or two.
Alternately remove the fuses and see when it stops then investigate what is hanging off the end of said feed.
Mark - No Longer driving
Re: Battery Drain Rate [Re: Peter J] #603625
15/11/19 10:56 AM
15/11/19 10:56 AM
Hampshire
Alistair Offline
Smile, it confuses them
Alistair  Offline
Hampshire
Mark, that's a smart idea. May I ask what you are using for the FLIR ? Is it s bolt to a smart phone or some dedicated device.
Just time to burn a little more petrol before dinner.
Re: Battery Drain Rate [Re: milligoon] #603628
15/11/19 11:15 AM
15/11/19 11:15 AM
Salisbury, UK
Peter J Offline OP
Formerly known as Aldermog
Peter J  Offline OP
Salisbury, UK
I'd say Yes, if I had a car.
But it is still at Williams....
Should be back on Tuesday...... perhaps....
Tarka the 'Otter Mog
2014 Plus 8
Re: Battery Drain Rate [Re: Alistair] #603719
16/11/19 01:58 AM
16/11/19 01:58 AM
Dorset, UK
milligoon Offline
milligoon  Offline
Dorset, UK
Just the FLIR one add-on for my phone
Last thing I used it for was searching for a wasp nest at night in the hedge at the bottom of my garden!
Re: Battery Drain Rate [Re: Peter J] #603720
16/11/19 01:59 AM
16/11/19 01:59 AM
Dorset, UK
milligoon Offline
milligoon  Offline
Dorset, UK
Give me a shout when it's convenient Peter, maybe one weekend.
Re: Battery Drain Rate [Re: milligoon] #603731
16/11/19 08:57 AM
16/11/19 08:57 AM
Mandello del Lario, Lake Como,...
Gambalunga Offline
Gambalunga  Offline
Info at https://www.flir.com/flirone
Page 3 of 3 1 2 3
Moderated by  Aeroman, Simon
