Morgan Aero 8
15 registered members (Rich Elson, MarkR, DickJ, deano, rockabilly john, kar120c, Ian Wegg, rv6, PaulV, Rovert, Chris99, M3W55, hugo, CooperMan, Nig&Jun), 108 guests, and 26 spiders.
John V6 451
+8Rich 417
Hawki 181
E10 Fuel Parts
by DaveK. 09/07/20 02:23 PM
Group runs out.
by Hawki. 09/07/20 12:28 PM
MULFAB Panhard Rod
by Grumpy2. 09/07/20 08:13 AM
Brooklands Wheel from MMC
by Perry_P_M3W. 08/07/20 10:55 PM
Loose Marbles
by +8Rich. 08/07/20 06:46 PM
Spanish M3W - 2013 unit - with db problem
by Marmota. 08/07/20 05:32 PM
An interesting article on E10 from Moss
by +8Rich. 08/07/20 05:20 PM
Another Great Escape. Caister Motor Museum
RUY255 on Autosport Cover
why we love living in the mountains
Our 2020 Morgan Plus 4   110 Anniversary Model
My new Plus Four
Saxonian, GlenB 4475, Simon m wright, dominicalbarn, Sib8292
7053 Registered Users
Topics38,744
Posts636,914
Members7,053
Most Online1,033
Dec 28th, 2019
Gordon D
Page 3 of 3 1 2 3
Re: Battery Drain Rate [Re: Peter J] #601237
27/10/19 12:38 PM
27/10/19 12:38 PM
France
chanteclair Offline
chanteclair  Offline
France
Originally Posted by chanteclair
We had a friend with an Aero arrive here a couple of years back and it turned out that a seemingly good battery was going flat overnight however if he operated the inertia kill switch, thereby disconnecting the battery, it would start without problems the next morning. We went to the local auto electrician and discovered two things: 1) there was a constant drain on the battery that was enough to flatten any battery overnight, and 2) the battery was a little down on power and needed replacing.
It was too difficult to identify the source of the drain but when the battery was replaced the current drain dropped back to virtually normal for the various small items that had to remain live to some degree, central locking, radio, etc.
So it seems that if the battery is not fully up to the correct voltage some item in the car was not fully disconnecting when the ignition was turn off. With a fully charged battery the item turned off correctly. confused2 confused2 confused2
This friend it was me .... Chanteclair
Has the Plus 6 arrived yet smile
Not yet Ihope on December the 1 th
Re: Battery Drain Rate [Re: Peter J] #601240
27/10/19 12:41 PM
27/10/19 12:41 PM
France
chanteclair Offline
chanteclair  Offline
France
Not yet, I hope December the 1 th
Re: Battery Drain Rate [Re: Peter J] #603547
14/11/19 06:39 PM
14/11/19 06:39 PM
Dorset, UK
milligoon Offline
milligoon  Offline
Dorset, UK
Peter would you like me to come around with my FLIR camera and see what is hot! It'll be the various instrumentation adaption modules along with the Immobilizer, you'll probably find a hot CANBUS or LINBUS chip or two.
Alternately remove the fuses and see when it stops then investigate what is hanging off the end of said feed.
Mark - No Longer driving
Re: Battery Drain Rate [Re: Peter J] #603625
15/11/19 10:56 AM
15/11/19 10:56 AM
Hampshire
Alistair Offline
Smile, it confuses them
Alistair  Offline
Hampshire
Mark, that's a smart idea. May I ask what you are using for the FLIR ? Is it s bolt to a smart phone or some dedicated device.
Just time to burn a little more petrol before dinner.
Re: Battery Drain Rate [Re: milligoon] #603628
15/11/19 11:15 AM
15/11/19 11:15 AM
Salisbury, UK
Peter J Offline OP
Formerly known as Aldermog
Peter J  Offline OP
Salisbury, UK
I'd say Yes, if I had a car.
But it is still at Williams....
Should be back on Tuesday...... perhaps....
Tarka the 'Otter Mog
2014 Plus 8
Re: Battery Drain Rate [Re: Alistair] #603719
16/11/19 01:58 AM
16/11/19 01:58 AM
Dorset, UK
milligoon Offline
milligoon  Offline
Dorset, UK
Just the FLIR one add-on for my phone
Last thing I used it for was searching for a wasp nest at night in the hedge at the bottom of my garden!
Re: Battery Drain Rate [Re: Peter J] #603720
16/11/19 01:59 AM
16/11/19 01:59 AM
Dorset, UK
milligoon Offline
milligoon  Offline
Dorset, UK
Give me a shout when it's convenient Peter, maybe one weekend.
Re: Battery Drain Rate [Re: milligoon] #603731
16/11/19 08:57 AM
16/11/19 08:57 AM
Mandello del Lario
Gambalunga Offline
Gambalunga  Offline
Mandello del Lario
Info at https://www.flir.com/flirone
Page 3 of 3 1 2 3
Moderated by  Aeroman, Simon
