17 registered members (JMcL, Sinbad, SimonH, Rovert, Saxonian, Chilliblu, TBM, Perry_P_M3W, Paulxj, +8Rich, mph, NickCW, Ale_72, MarioCP, TalkMorgan, IcePack, dominicalbarn), 105 guests, and 22 spiders.
John V6 448
+8Rich 414
Hawki 180
MULFAB Panhard Rod
by Grumpy2. 09/07/20 08:13 AM
Brooklands Wheel from MMC
by Perry_P_M3W. 08/07/20 10:55 PM
Loose Marbles
by +8Rich. 08/07/20 06:46 PM
Spanish M3W - 2013 unit - with db problem
by Marmota. 08/07/20 05:32 PM
An interesting article on E10 from Moss
by +8Rich. 08/07/20 05:20 PM
Remember my 'anyone good at maths question ?
by Bonesie. 08/07/20 02:45 PM
Another Great Escape. Caister Motor Museum
RUY255 on Autosport Cover
why we love living in the mountains
Our 2020 Morgan Plus 4   110 Anniversary Model
My new Plus Four
Saxonian, GlenB 4475, Simon m wright, dominicalbarn, Sib8292
7053 Registered Users
Topics38,742
Posts636,832
Members7,053
Most Online1,033
Dec 28th, 2019
Gordon D
Page 1 of 15 1 2 3 14 15
M3W Homebuild #604170
19/11/19 05:05 PM
19/11/19 05:05 PM
PA, USA
Rob82 Offline OP
Rob82  Offline OP
PA, USA
Hello,
I am in the process of building what will be my version of a M3W. I am hoping some of the members here can help me with various bits about theirs. I would love to just purchase a real Morgan, but I don't see that being a financial possibility in my lifetime. I am, however, pretty handy with design and fabrication so I figured I could build my own for a fraction of the cost, and know I will be able to work on it and get the parts when the time arises. I have purchased and read the book, Build Your Dream!: The process and thinking behind building a replica Morgan 3-Wheeler. I would like my version to be quite a bit different though.
Base/Donor bike is a BMW R1100RT. I intend on using the factory Paralever (shaft drive), ABS and gauges.
Intermediate housing between engine and transmission is my design and will NOT use or require a compensator due to the engine selection
Transmission is a Mazda Miata NB 5 speed
Transfer case (in place of the M3W Bevel Box) is my own design
Basic vehicle dimensions will be similar to a M3W with the exception of mine being wider as I am a bit on the wide side myself and want to be comfortable.
frame will be steel tubing TIG welded and body panels will be aluminum and composite.
I'll post a few pics once I figure out a way to get the file size down to the 1kb limit.
If anyone on here has done what I am trying to do I would love to hear from you!
Re: M3W Homebuild [Re: Rob82] #604179
19/11/19 05:46 PM
19/11/19 05:46 PM
Devonshire
+8Rich Online content
+8Rich  Online Content
Devonshire
Welcome Rob, that is quite a project you have on there way beyond my level of knowledge or abilities, good luck it will be good to have pictures.
Have you tried the TM site for photographs, it downsizes automatically and walks you through each step of the way https://www.tm-img.com/login
Regards Richard
1994 Connaught Green +8 prev
Re: M3W Homebuild [Re: +8Rich] #604186
19/11/19 06:41 PM
19/11/19 06:41 PM
PA, USA
Rob82 Offline OP
Rob82  Offline OP
PA, USA
Re: M3W Homebuild [Re: Rob82] #604187
19/11/19 06:44 PM
19/11/19 06:44 PM
M3W55 Online content
M3W55  Online Content
Good luck. You will find a wealth of engineering expertise on the Three Wheeler section of the site. There is nothing that some of the boffins there cannot design and fabricate.
Re: M3W Homebuild [Re: Rob82] #604189
19/11/19 07:22 PM
19/11/19 07:22 PM
PA, USA
Rob82 Offline OP
Rob82  Offline OP
PA, USA
A few figures I know I am looking for are
Flywheel weight, with or without clutch pack
interior width across the seats
approximate width of center console
Re: M3W Homebuild [Re: Rob82] #604191
19/11/19 07:34 PM
19/11/19 07:34 PM
Devonshire
Devonshire
If I might make a suggestion Rob I think you will get a better response to your questions if posted in The Three Wheeler section of the forum thumbs
Regards Richard
Re: M3W Homebuild [Re: Rob82] #604194
19/11/19 07:48 PM
19/11/19 07:48 PM
Mandello del Lario
Gambalunga Offline
Gambalunga  Offline
Mandello del Lario
Re: M3W Homebuild [Re: Rob82] #604196
19/11/19 07:52 PM
19/11/19 07:52 PM
Mandello del Lario
Gambalunga Offline
Gambalunga  Offline
Mandello del Lario
That puts in the required img tags in square brackets - see above.
The forum software limits embedded images to 10 per post.
This is the last one.
Re: M3W Homebuild [Re: Rob82] #604197
19/11/19 07:57 PM
19/11/19 07:57 PM
Cumbria UK
Jays ex Nero Offline
Cumbria UK
You plan to use the shaft drive (Paralever) from the donor BMW. Any reason why you are not using the BMW bevel box rather than constructing a transfer box?
Intriguing project...I’m really looking forward to seeing some progress photos in time!
Jays. Ex Morgan owner. 1935 Austin Seven Ulster Replica
Re: M3W Homebuild [Re: Rob82] #604200
19/11/19 08:09 PM
19/11/19 08:09 PM
Mandello del Lario
Gambalunga Offline
Gambalunga  Offline
Mandello del Lario
John. If he is using the MX5 gearbox he needs to shift the output to one side to line up with the rear bevel drive. An easier option may be to use the BMW box but then you don't have a reverse gear. Some of the trike people use an electric motor for reverse and there is also a little reverse drive box available.
Moderated by  Aeroman, Simon
