17 registered members (TheRabbit, planenut, RedThree, M3W55, Clipper, Spanner Juggler, TBM, vincentvg, MOG 615, Richard Wood, John V6, Player99, DCH, James B W, PerG, Hamwich, MDS61), 143 guests, and 20 spiders.
John V6 427
+8Rich 412
TBM 238
Heinz 190
Cummings & Goings ;-)
by +8Rich. 03/06/20 08:20 PM
Novochock on TV
by Peter J. 03/06/20 05:43 PM
Happy Birthday
by CooperMan. 03/06/20 02:06 PM
Speedo issue...help!
by Perry. 03/06/20 12:57 PM
One for Rally & BMC fans
by CooperMan. 03/06/20 12:53 PM
Good News
by lowebird. 03/06/20 10:49 AM
Inherent danger with Three Wheelers
by TBM. 03/06/20 10:04 AM
sump/crossmember guard
The great escape
Sidescreen Mounting in Storage
Are There Any Keen Car Badge Collectors out there
Snow banks of Norway
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,410
Posts629,487
Members6,938
Most Online1,033
Dec 28th, 2019
No Birthdays
Re: Misfire on warm up [Re: PhilV] #605372
28/11/19 11:00 AM
28/11/19 11:00 AM
East Harling, Norfolk UK
Richard Wood Online NoMood
Originally Posted by PhilV
Hi IMHO. Not sure to be honest. When driving it feels like it is starving itself so I assumed both. Fuel pressure all checks out ok and they have changed the pump. I have not witnessed the issue in the workshop as it was dropped in for a service and I assumed a tweak to the mapping. They found a couple of other issues that we hoped had cured it but this warm up issue remains. I’ll ask them tomorrow as I am due my weekly update.
War Bird - Currently running on standard plugs but again they have been changed. Any recommendations on alternatives?
Iridium plugs may be worth a try. Same heat range used on my car, NGK DCPR7EIX. Due to fine tip they spark at lower voltage.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Misfire on warm up [Re: PhilV] #605412
28/11/19 04:10 PM
28/11/19 04:10 PM
Hampshire, UK
I
IMHO Offline
IMHO  Offline
I
Hampshire, UK
Some easy things to try before delving into more complex issues -
To see if it’s on one cylinder -
Start the engine and hold your hands over the exhaust outlets, they should feel the same or you could feel the colder blast of the miss-fire.
Swap over HT leads and see if the problem moves.
Check the pulley timing position Is correct on each cylinder.
If it’s on both, how old/good is your fuel?
M3W Brooklands (2015)
Norton Commando 750 (1971)
Moody 41 (2013)
Re: Misfire on warm up [Re: PhilV] #605431
28/11/19 05:10 PM
28/11/19 05:10 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
Wouldn’t swapping the spark plug lead mean the cylinders are trying to fire on exhaust instead of firing on compression?
Stephen
2019 M3W , 2Kmiles
Re: Misfire on warm up [Re: PhilV] #605433
28/11/19 05:16 PM
28/11/19 05:16 PM
Cheshire, UK
nippymog Offline
nippymog  Offline
Cheshire, UK
The way I read IMHO's post, is to exchange the complete lead left for the right to eliminate the leads themselves?
Not sure how that would help diagnose a misfire when cold though.
Re: Misfire on warm up [Re: PhilV] #605434
28/11/19 05:18 PM
28/11/19 05:18 PM
Hampshire, UK
I
IMHO Offline
IMHO  Offline
I
Hampshire, UK
You can unplug them from the coil pack and the spark plug.
Moody 41 (2013)
Re: Misfire on warm up [Re: PhilV] #605436
28/11/19 05:32 PM
28/11/19 05:32 PM
Hampshire, UK
I
IMHO Offline
IMHO  Offline
I
Hampshire, UK
Nippymog, I just wondered if one of the leads improved when hot. I know it’s a long shot but if the diagnostics isn’t picking it up then it sounds like something at the end of the process and physical?
Moody 41 (2013)
Re: Misfire on warm up [Re: PhilV] #605438
28/11/19 05:45 PM
28/11/19 05:45 PM
Hampshire, UK
I
IMHO Offline
IMHO  Offline
I
Hampshire, UK
Also could be a dodgy spark that’s not so problematic when the engine is hot.
PhilV, when running along with a hot engine do you get any intermittent backfires / popping from any of the exhausts? Could be a dodgy coil pack which is easy to check with a cheap spark indicator.
Good luck!
Moody 41 (2013)
Re: Misfire on warm up [Re: PhilV] #605449
28/11/19 06:31 PM
28/11/19 06:31 PM
Cheshire, UK
nippymog Offline
nippymog  Offline
Cheshire, UK
Someone has already asked is it just one cylinder misfiring - is this the case or is it both?
edit just seen this has been answered as unsure
Re: Misfire on warm up [Re: PhilV] #605451
28/11/19 06:41 PM
28/11/19 06:41 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Ask KH to run it on the rolling road whilst COLD with the ProTune connected & watch the live data
(was Furloughed - now Redundant)
Re: Misfire on warm up [Re: IMHO] #605460
28/11/19 08:12 PM
28/11/19 08:12 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
I once owned an AH Sprite that would not start or if it it did start when in the cold damp air of our beach community it would run very ragged until it got warmed up.
I found the problem when trying to start it ( someone else using the starter) while observing the wiring in the dark. There was arcing coming from degraded insulation and hairline cracks (invisible to naked eye) in the plastic parts. The UK can get pretty damp so it might be worth a check.
Stephen
2019 M3W , 2Kmiles
Moderated by  Aeroman
