16 registered members (CooperMan, Sir Percival, Clipper, LightSpeed, Ludo, +8Rich, M3W55, Alistair, Redfate, tommog, Peter J, GARYMYNARD, britmog, Deejay, HJP, PaulV), 149 guests, and 22 spiders.
+8Rich 423
John V6 421
TBM 237
Heinz 195
1981 +8 water pipes
by GARYMYNARD. 05/06/20 04:54 PM
Plus 4 Push Button Start?
by Nostalgiajohn. 05/06/20 02:45 PM
vdo speedo
by milliemollie. 05/06/20 12:50 PM
Interesting new hardtop
by +8Rich. 05/06/20 12:43 PM
the classic / collectors car market
by howard. 05/06/20 09:53 AM
ebay made me chuckle
by Grumpy2. 05/06/20 08:50 AM
How many grease nipples
by Philippo. 04/06/20 07:28 PM
Glove box net
sump/crossmember guard
The great escape
Sidescreen Mounting in Storage
Are There Any Keen Car Badge Collectors out there
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,422
Posts629,773
Members6,938
Most Online1,033
Dec 28th, 2019
Oldbill
Page 10 of 10 1 2 8 9 10
Re: Aquaplaning M3W's [Re: Laurens] #605890
02/12/19 03:51 AM
02/12/19 03:51 AM
SW Iowa, U.S.A.
Bitsobrits Offline
Bitsobrits  Offline
SW Iowa, U.S.A.
So if balancing using the wheel mounted to the hub, then one could just use the spindle bolt and a simple stand (or event he swingarm-assuming no brake assembly to cause drag). Centering cones and additional bearings seem a bit superfluous to me.
2012 M3W #458
Iowa, U.S.A.
Re: Aquaplaning M3W's [Re: Laurens] #605893
02/12/19 05:56 AM
02/12/19 05:56 AM
Furry Boots City
RedThree Offline
RedThree  Offline
Furry Boots City
No idea where I got my one (incidentally,not the one in the photo, that was just taken from the web) but from a quick look on the Bay of E there is a huge selection of them available and at the kind of prices that might put you off the idea of building one.
Re: Aquaplaning M3W's [Re: Laurens] #605934
02/12/19 12:32 PM
02/12/19 12:32 PM
Port Orchard, WA.
LightSpeed Online content
LightSpeed  Online Content
Port Orchard, WA.
Calum, you are correct, the prices are pretty good for that simple static stand balanced. Thanks for putting the thought into my brain👍
Stephen
2019 M3W , 2Kmiles
Re: Aquaplaning M3W's [Re: LightSpeed] #605935
02/12/19 12:35 PM
02/12/19 12:35 PM
West Sussex, UK
Chris99 Offline
Chris99  Offline
West Sussex, UK
Does the rear sprocket need to be removed to change the rear tire? Maybe a stupid question but not having doe it before I thought I would ask.
If you do decide to remove the sprocket check, and if necessary clean, any exposed bolt thread beforehand.
There is at least 1 case where a tyre fitter simply removed the bolt with an airgun and stripped the internal thread. Repaired with a helicoil but a few strokes with a wire brush would have avoided the problem.
Red Leader drive
Re: Aquaplaning M3W's [Re: Laurens] #605986
02/12/19 07:46 PM
02/12/19 07:46 PM
SW Iowa, U.S.A.
Bitsobrits Offline
Bitsobrits  Offline
SW Iowa, U.S.A.
So picked up my M3W rear wheel and new tire from the fitter and they were able to balance it despite the hub center of unusual size. Their centering cones were sufficiently large to handle it.
As for stripped threads in the hub, I've installed studs for both the road wheel and drive sprocket as I'm generally opposed to running steel fasteners into/ out of alloy on a repetitive basis.
48mm OAL M12 x 1.5 for the wheel, and M10 x 1.25 for the sprocket. Final installed length of the sprocket studs will vary with steel sprocket (shorter) vs alloy sprocket (longer) and care must be taken that the sprocket stud doesn't extend far enough to foul the axle adjuster.
This is some thread drift, btw.
2012 M3W #458
Iowa, U.S.A.
Re: Aquaplaning M3W's [Re: Laurens] #605992
02/12/19 09:46 PM
02/12/19 09:46 PM
Port Orchard, WA.
Port Orchard, WA.
Back on topic. Hydroplaning, this might go a long way to rectify the issue. It is not the best in the hot and dry for fast cornering, BUT, it will help keep the rear end planted in wet and mossy and icy conditions. I have driven it on a driveway that I could not walk up using these tires on my MINI Coopers.
I am hoping to get these put on next week.
Stephen
2019 M3W , 2Kmiles
Moderated by  Aeroman
