16 registered members (Ricardo, Stewart S, Rog, Ian B, spooner, Image, atalante83, jbk, Craig Jezz, Tresco, DickJ, JohnMat, Rovert, Spanner Juggler, GARYMYNARD, Hamwich), 363 guests, and 113 spiders.
+8Rich 260
Peter J 128
John V6 124
Hamwich 108
The French want their words back!
by Gambalunga. 24/01/20 03:43 PM
ARP4 Info urgently needed
by NeilPom. 24/01/20 10:23 AM
How to sell my M3W?
by Chris M3W. 23/01/20 06:03 PM
Bonnet Stays & Qtr Panel Protectors
by Nostalgiajohn. 23/01/20 03:33 PM
Replace Hazard switch
by Anthony4/4. 23/01/20 03:13 PM
WA13FWY - does anyone know this car?
by jackmorini. 23/01/20 12:07 PM
Plus 8 Coolant leak
by MGDave. 23/01/20 03:49 AM
New year walk
Seals and wreck of the Ythan estuary,
Saint Ex the Morgan in all its glory
Bevel box oil leak
Hogmanay Run
craig123, Martin Medland, banjo2005, kailambers, Martin Peel
6812 Registered Users
Topics37,069
Posts601,481
Members6,812
Most Online1,033
Dec 28th, 2019
No Birthdays
Alloy gators ? #606376
04/12/19 08:45 PM
04/12/19 08:45 PM
Yorkshireman living in Surrey
Bonesie Offline OP
Bonesie  Offline OP
Chatting to a chap while he was looking over my car I mentioned that I might have the alloys powder coated at some point or maybe buy a black set . He asked if I had heard of alloy gators . Basically rings that fit around the rim of the alloy not only protecting from curbing but add a tad of colour bling to the wheel.
Anybody tried them ?
https://alloygator.com/uk/
Bonesie
Re: Alloy gators ? [Re: Bonesie] #606379
04/12/19 09:03 PM
04/12/19 09:03 PM
Lancashire
RobCol Offline
RobCol  Offline
Lancashire
Yes quite a few driving instructors use them is that's any recommendation!
Rob
2012 4/4 Sport Grey
Re: Alloy gators ? [Re: Bonesie] #606382
04/12/19 09:13 PM
04/12/19 09:13 PM
Near Windsor Berkshire
Rog G Offline
Rog G  Offline
I put them on my mothers VW Polo, because she was forever scrapping the wheels. They were easy to fit but being plastic very quickly looked secondhand as soon as they touched the kerb.
2013 M3W
1971 4/4 2 Seater
1934 Sports
Re: Alloy gators ? [Re: Bonesie] #606391
04/12/19 10:15 PM
04/12/19 10:15 PM
Hampshire
Alistair Offline
Smile, it confuses them
Alistair  Offline
Hampshire
I have a set in the garage that I keep meaning to get fitted but forget. I did intend to put them on the Coupe to protect the lovely Rays "aeromax" alloys.
You have them put around the rim as the tyre is being fitted. They come in a long length and then they are cut to length. I have black so they hide but you can get colours to make them stand out.
I was told by the fitters that they don't survive a long rub in parallel but are good for clips/scuffs. To remove them you do need to have the wheel deflated and the bead broken (that pop sound). He said that once scuffed most people do have them taken off. Given the price it is a fine line between a repair and a set of gators.
Just time to burn a little more petrol before dinner.
Re: Alloy gators ? [Re: Alistair] #606392
04/12/19 10:30 PM
04/12/19 10:30 PM
Devonshire
+8Rich Offline
+8Rich  Offline
Devonshire
If memory serves me well I thought Peter J contemplated this on his Aero Plus 8 but didn't do it for some reason, I may have dreamed it but I don't think so it was quite a while ago about his rim repair time maybe.
Regards Richard
2009 4/4 Sport Green
1994 Connaught Green +8
Re: Alloy gators ? [Re: Bonesie] #606403
05/12/19 04:41 AM
05/12/19 04:41 AM
auckland new zealand
waikiore Offline
waikiore  Offline
The rental cars that I have used in the UK usually have them fitted, so I imagine they have done the costings..
99 plus 8 indigo
Re: Alloy gators ? [Re: Bonesie] #606407
05/12/19 06:52 AM
05/12/19 06:52 AM
Bonesie Offline OP
Bonesie  Offline OP
Ah cheers guys.
Maybe they are more hassle than they are worth and at £150 quid, that seems a tad steep for some metal clips and plastic tubing ?
Bonesie
Re: Alloy gators ? [Re: Bonesie] #606419
05/12/19 09:09 AM
05/12/19 09:09 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Peter J did fit them after kerbing a wheel in Wales at a TafMog event.
2006 Indigo Blue Roadster S1
Re: Alloy gators ? [Re: Bonesie] #606429
05/12/19 10:11 AM
05/12/19 10:11 AM
Beaumont de Lomagne, France
Philippo Offline
Philippo  Offline
Sounds a bit odd to me having great looking wheels that you then put plastic covers on to protect and at the same time making them look nowhere near as attractive. Isn't a better solution to make sure that the tyres flare out well of the wheels or fitting tyres with a protective triangular bead as I seem to recall I had on my S1 Aero.
Cheers
Philip
4/4 4 seater 1974 (to be replaced soon by in-build 1985 +8 4 seater)
Malone F1000
Re: Alloy gators ? [Re: Bonesie] #606434
05/12/19 10:52 AM
05/12/19 10:52 AM
Hampshire
Alistair Offline
Alistair  Offline
Hampshire
It is similar but the gator does give more direct coverage. I do usually buy tyres with the aptly titled rim-flange to try and protect against a little scuff but the gators are better than that. If you are careful then I would say the tyre walls are good as you will be feeling through the steering wheel. If you are in a rush, have nasty curbs etc then the gators do add a better job when the contact is made.
Moderated by  Aeroman, Simon
