14 registered members (xc68anc, Spanner Juggler, KEVFITZ, Wirewheel, Nostalgiajohn, marshalben, dmh, BobJ, +8Rich, IcePack, Hamwich, John Winn, John07, Image), 319 guests, and 88 spiders.
+8Rich 261
Peter J 128
John V6 124
Hamwich 108
Location
by Nostalgiajohn. 24/01/20 04:48 PM
The French want their words back!
by Gambalunga. 24/01/20 03:43 PM
ARP4 Info urgently needed
by NeilPom. 24/01/20 10:23 AM
How to sell my M3W?
by Chris M3W. 23/01/20 06:03 PM
Bonnet Stays & Qtr Panel Protectors
by Nostalgiajohn. 23/01/20 03:33 PM
Replace Hazard switch
by Anthony4/4. 23/01/20 03:13 PM
WA13FWY - does anyone know this car?
by jackmorini. 23/01/20 12:07 PM
New year walk
Seals and wreck of the Ythan estuary,
Saint Ex the Morgan in all its glory
Bevel box oil leak
Hogmanay Run
craig123, Martin Medland, banjo2005, kailambers, Martin Peel
6812 Registered Users
Topics37,070
Posts601,484
Members6,812
Most Online1,033
Dec 28th, 2019
No Birthdays
Page 1 of 5 1 2 3 4 5
Plus 8 1994: bleeding everything! #606455
05/12/19 02:26 PM
05/12/19 02:26 PM
Near Guildford
Lawson Offline OP
Lawson  Offline OP
Near Guildford
Hi All,
Would anyone be able to give me advice on the following please?
Bleeding clutch: how to do? any pictures? (clutch travelling to floor)
Bleeding/changing fluid for brakes: I gather this should be done every two years, so I'm assuming prior owner did not do it so plan to do for peace of mind. Any instructions/pointers? What should I buy to do it with?
Radiator flush: being a complete muppet, I put brakes fluid into the radiator (don't ask...). How do I flush this little fellow out please? Oh yes, and what type of coolant should I use?
Many thanks (in anticipation!)
Lawson
Re: Plus 8 1994: bleeding everything! [Re: Lawson] #606461
05/12/19 03:01 PM
05/12/19 03:01 PM
Cornwall
griffo Offline
griffo  Offline
Cornwall
Have you considered asking a local garage mechanic familiar with classic cars to do the job?
Re: Plus 8 1994: bleeding everything! [Re: Lawson] #606466
05/12/19 03:24 PM
05/12/19 03:24 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Brakes are something you need to be competent to do. It is not just the air you bleed off you need to remove the old fluid as it absorbs moisture.
A lot of advice is here
http://www.gomog.com/allmorgan/allmorgan.html
2006 Indigo Blue Roadster S1
Re: Plus 8 1994: bleeding everything! [Re: griffo] #606471
05/12/19 03:39 PM
05/12/19 03:39 PM
East Anglia
madmax Offline
madmax  Offline
East Anglia
banghead
Re: Plus 8 1994: bleeding everything! [Re: madmax] #606478
05/12/19 04:06 PM
05/12/19 04:06 PM
Near Guildford
Lawson Offline OP
Lawson  Offline OP
Near Guildford
LOL
I have but then I decided it would be much more satisfying (fun?) to do myself. It can't be rocket science, right?
Re: Plus 8 1994: bleeding everything! [Re: Lawson] #606481
05/12/19 04:14 PM
05/12/19 04:14 PM
Cotswolds
PJB Offline
PJB  Offline
Cotswolds
No, but it really is life and death. Read and understand before you do anything to the brakes, ideally work with somebody even then who really knows. Please. PJB.
Buckland B3 Mk2 (Development of F Type Morgan)
Re: Plus 8 1994: bleeding everything! [Re: Lawson] #606482
05/12/19 04:16 PM
05/12/19 04:16 PM
Luddite Offline
Luddite  Offline
Madmax... stop banging your head...(-: Though it does seem that the modern Morgan man is perhaps not a Morganeer as he used to be.and the GoMoG webmaster most certainly was/is ?... (-:
Lawson fear not there will be plenty of folk queuing up to provide you with all the info you might require to perform what should be a relatively simple task ..IF.. the bleed nipples are not corroded to the extent they break off when trying to unscrew them.
In an ideal world all the fluids should be replaced in time, though I have driven vehicles where the brake fluid was older than I was and it performed well.... I was younger then... (-: Thus do not get too excited about it..(-:
If you put the brake fluid in the expansion tank and not directly into the rad, then I suspect it will be floating around in there perhaps on the surface.... If you remove the tank and flush it out that will sort things out..... Do not be tempted to suck it out as brake fluid can damage kidneys let alone taste lousy....(-:
What never used the syphon technique for anything..? (-:
Good luck, happy to give you a step by step guide if required or desired.... HOWEVER all the usual disclaimers apply if you kill yourself or anybody else...(-:
Re: Plus 8 1994: bleeding everything! [Re: Lawson] #606484
05/12/19 04:26 PM
05/12/19 04:26 PM
Devonshire
+8Rich Online content
+8Rich  Online Content
Devonshire
Get a local fellow Morgan DIY owner to run you through the first time if you have no experience at all, running out of brakes can cause concern..
Regards Richard
2009 4/4 Sport Green
1994 Connaught Green +8
Re: Plus 8 1994: bleeding everything! [Re: John V6] #606485
05/12/19 04:36 PM
05/12/19 04:36 PM
Near Guildford
Lawson Offline OP
Lawson  Offline OP
Near Guildford
super helpful for brakes John V6 - thank you - anything similar for clutch per chance?
Re: Plus 8 1994: bleeding everything! [Re: Lawson] #606491
05/12/19 05:12 PM
05/12/19 05:12 PM
Luddite Offline
Luddite  Offline
Lawson GoMoG is many years of work and research to help Morganeers understand the operation of their cars and repair them, if you root around you will find the answer to pretty much everything Morgan related...If not, we are always around as back-up.. (-:
Moderated by  Aeroman, Simon
