13 registered members (ChrisP, +8Rich, Richard Wood, brownbaker, Fabi0000, DCH, Graham, G4FUJ, John Winn, Marmota, Rog G, Neptune, Image, 60Yards), 146 guests, and 17 spiders.
+8Rich 395
John V6 366
Hawki 139
Alone in my Garage!
by Budster. 03/08/20 12:06 PM
zetec 1.8 misfire
by byeck. 03/08/20 11:01 AM
Simple battery change - or not
by N22MOG. 03/08/20 10:35 AM
Tyres & wheel balancing
by croftmog. 03/08/20 08:45 AM
Grease recommendation
by BigLes. 03/08/20 06:50 AM
No bling-bling
by xc68anc. 03/08/20 06:13 AM
Headlamp issue 97 +8
by Fus969. 03/08/20 05:58 AM
SNOWDONIA B4407/A543
GTN Soft top re-fitted
GTN Visors
A Great Escape to Orford & Snape Maltings
Black Mesh Grill and painted headlight rings
WLPM, Lilliput, Andrew1806, RBooth, Martien
7087 Registered Users
Topics38,960
Posts641,234
Members7,087
Most Online1,033
Dec 28th, 2019
No Birthdays
Broken ignition key #606468
05/12/19 03:30 PM
05/12/19 03:30 PM
Leicestershire
Farmer Giles Offline OP
Leicestershire
When I took over my M3W the tip of the ignition key had broken off inside the barrel of the lock. This isn't a problem when using the damaged key but I'm concerned that a) I might loose or damage that key (so would have to cut a bit off the spare) or b) the broken off tip may move and jam the lock mechanism. Does anyone have any suggestions as to how I might 'rescue' the tip, alternatively has anyone had cause to remove the barrel of the lock as necessary to either shake out the piece(s) or fit a replacement? Comments and suggestions welcome!
Johnny Vans
Brooklands Edition M3W
1935 F2
2010 Mini Clubman
Re: Broken ignition key [Re: Farmer Giles] #606487
05/12/19 04:46 PM
05/12/19 04:46 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
Another thought would be to eliminate the wheel lock and the keyed ignition altogether and then you would not have to carry keys but just remember the sequence of hidden switches to turn ignition on and off.
I suspect it is a Puegeot locking system.
Stephen
2019 M3W piling on the Covid miles
Re: Broken ignition key [Re: Farmer Giles] #606545
05/12/19 09:07 PM
05/12/19 09:07 PM
Devon
Moggo Offline
Moggo  Offline
Devon
Try a 2" length of 18 gauge piano wire magnetized by touching the open end with a permanent magnet and very gently teasing out the broken piece of key. It might work - Just a thought.
Graham
1.8 4/4 Ivory.
Toyota Yarris
Volvo V70
Re: Broken ignition key [Re: Farmer Giles] #606684
06/12/19 04:31 PM
06/12/19 04:31 PM
nick w Offline
nick w  Offline
There is a tool especially for this situation. It is a thin sliver of metal with half an arrow head at the end. It's possible to insert this and hook the piece out.
Nick
Re: Broken ignition key [Re: Farmer Giles] #606696
06/12/19 05:27 PM
06/12/19 05:27 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
Farmer Giles, do you have any idea on how the key was broken like that? Was it the original Morgan Key?
And that brings up, how do you get a new MMC key?
Stephen
Re: Broken ignition key [Re: Farmer Giles] #606866
07/12/19 08:06 PM
07/12/19 08:06 PM
Leicestershire
Leicestershire
Thanks everybody for your suggestions, I'll give them all a try. Yes, it was the original key but I have no idea how it was damaged. And yes, it is apparently a Peugeot lock and another member was kind enough to obtain a key blank for cutting when extraction is completed.
Johnny Vans
1935 F2
2010 Mini Clubman
Moderated by  Aeroman
