13 registered members (ChrisP, Rob Thornton, Mr Mogoo, M3W55, Fus969, Island Mog, Image, Hamwich, +8Rich, cerealsurfer, Mike D, Paul F, jatinder dhesi), 171 guests, and 12 spiders.
+8Rich 318
John V6 256
TBM 167
Alistair 151
Hamwich 148
Front pictures as promised Ferrari TDF Plus 4
by jatinder dhesi. 22/09/20 08:20 PM
Webcon Retroject
by Gilles L.. 22/09/20 08:09 PM
1974 4/4 ...steering wheel
by thelastgizmo. 22/09/20 06:56 PM
Classic Motor Show
by PhilRoyle. 22/09/20 06:20 PM
Up, Up, and Away....
by Jon G4LJW. 22/09/20 05:08 PM
Car Insurance !!
by Alistair. 22/09/20 04:46 PM
parking brake adjustment
by rcmatt. 22/09/20 01:38 PM
wait for it
Stonor breakfast club - Oxfordshire
Cotswold Classic Tour 19/9/20
Rattray and Troup 4/4 80th
A grand day out
Koopz, hashluck, KennyW, David Stepanis, Malroy
7166 Registered Users
Topics39,437
Posts650,827
Members7,166
Most Online1,033
Dec 28th, 2019
Peter1062
New Engine at Last #606833
07/12/19 05:26 PM
07/12/19 05:26 PM
Staffordshire
IvorMog Offline OP
IvorMog  Offline OP
Staffordshire
At long last, I have finally replaced my old Silvertop 1.8L Zetec engine with a new crate 2.0L Blacktop Zetec engine. I've even updated my signature line on here.
Why?
Because I wanted the challenge and the new engine will give me a better base for future tuning work.
Although the 2 engines are very similar, it did present some problems to stop my now retired from useful employment brain from atrophying.
1 They moved the oil filter so it interferes with the right hand engine mount. I had to change which engine mounting bolts it used with a bit of cutting, grinding and welding.
2 The bottom hose and water pump is different and the inlet is a different size. The pump rotates in the opposite direction so an Idler is needed. Thankfully off the shelf at Retro-Ford.
3 Because of the water pump change, the alternator has to be moved to the other side of the engine. Again, Retro-Ford make a kit to do this but it then ended up very close to where the brake pipe goes through the inner wing and a whole clump of wires so modifications needed to make it work with a safe operating clearance.
4 The intake manifold is different so the vacuum take-offs for the MAP sensor and brake servo had to be modified to connect up. No kits available but not the biggest challenge.
5 The throttle body is different so it needed a new intake and filter system (which I'm still not happy with but it works) and changes to the throttle cable end.
6. I've used the 1.8L Silvertop flywheel which in effect is the same as a lightened 2.0L flywheel for better throttle response and acceleration. I used the old clutch so that will need looking at if I significantly up the torque.
7. The new Blacktop sump would not work with the standard gearbox bell housing and starter motor arrangement so I had to modify the old Silvertop sump to work on the Blacktop.
8. ECU mapping. The Blacktop uses different injectors and operates at 3.8 bar fuel pressure compared with 2.7 bar on the Silvertop. I had the flow rates checked for both types of injector and calculated what difference the pressure would make. (not linear but a wealth of data on the internet). I then modified an old Silvertop calibration to allow for the increased engine capacity and different injector flow rate.
This has all taken me about 6 weeks of intermittent work to actually do but many more weeks of thinking, planning and head scratching.
Yesterday I filled the engine with running in oil and fresh coolant and double checked (more like quadruple checked) everything. I had left the battery on charge overnight to make sure I had enough voltage for numerous engine starting attempts.
I offered up prayers to every God I could think of then cycled the fuel pump a few times to ensure full pressure in the unlikely event that the engine did start. I also hooked up the computer to the ECU to check all the vital information and provide some initial feedback from the data-logging
I turned the key and almost jumped out of my skin as the engine burst into life immediately on the first cranking attempt.
Don't panic I said, that's what was supposed to happen (at least in my dreams) but quick, check the oil pressure. Phew, 5 bar. Alternator charging Ok, rev counter (which works from the alternator) reading correctly.
I kept the engine between 2000 and 3000 rpm until the temperature started to get up to normal (another tick in the box, the revised cooling system seems to work) then with some trepidation I took my foot off the pedal and waited for the engine revs to die down and stall. To my great surprise and joy it didn't stall but sat nice and smooth at 950 rpm.
Engine now getting well up to temperature and the fan kicked in at precisely the correct temperature and then went off again at the hysteresis point. (Another tick in the box)
Turned it off and went looking for leaks but there were none and the computer logging showed that everything was working as it should although probably running a bit on the rich side.
Today I played with the fuel mapping and took some of the fuel out of the calibration to lean the mixture slightly but you can't really tell what it's doing on a static run up,. It was more of a gut feel at this stage.
So the BIG moment arrives. Time to get out on the road and see if it is actually drivable in the real world. I reconnected the computer, switched on the data-logging and turned the key. To my amazement it fired first time again so no messing around waiting for it to warm up, get out on the road and see what happens.
To my amazement ( I think I used that phrase before) it just pulled away and accelerated normally and even from that first moment I could tell this was going to be good.
I can already tell the throttle response is there and I'm sure I can feel much better bottom end torque.
After about 15 minutes I stopped to check the computer was not showing any untoward signs and had a quick look under the bonnet for signs of leaks or other nasties.
Started up again and set off on another lap of my test track and started to get a warm satisfied feeling as I gradually opened her up a bit more. Pulled out of a junction, 1st gear, 2nd gear, go on give it a bit more welly.
Accelerating smoothly at about 3/4 throttle then "OH S**T", the engine started to misfire. I lifted the throttle and tried again but no joy, it was still misfiring.
It wouldn't rev past 4000 rpm, it just kept misfiring. Then I remembered that I had set the rev limit to 4000 in case I had a runaway at start up and I had forgotten to reset it for the road test. "Stupid boy".
Pulled over, reset the rev limit to 6000 and tried again. Wow. Clean all the way past 5000 albeit only using 3/4 throttle.
So in this Christmas festive season It seems that dreams can come true so I'll get it on the dyno this coming Wednesday and give it a couple more hours of braking in then set about refining the fuel and ignition map.
At this stage I'll limit it to 6000 rpm and won't spend long sessions at full throttle but I am so excited as I'm convinced this engine is a big set forward for Mog
If only Brexit was this simple.
Bob
1999 4/4 2 litre Zetec
Re: New Engine at Last [Re: IvorMog] #606837
07/12/19 05:31 PM
07/12/19 05:31 PM
Costock, South Nottinghamshire...
Paul F Online happy
Paul F  Online Happy
Sounds like someone has had a very productive few weeks.
Have you done anything to the brakes or suspension?
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Re: New Engine at Last [Re: Paul F] #606839
07/12/19 05:37 PM
07/12/19 05:37 PM
Staffordshire
IvorMog Offline OP
IvorMog  Offline OP
Staffordshire
Yes, refurbished the calipers, new rear slave cylinders and braided hose.
Fitted Suplex SSL front suspension. Panhard rod waiting in the wings.
Bob
Re: New Engine at Last [Re: IvorMog] #606840
07/12/19 05:37 PM
07/12/19 05:37 PM
Gloucestershire, UK
Hamwich Online content
Hamwich  Online Content
Gloucestershire, UK
Well done Bob, sounds like a major success!
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Re: New Engine at Last [Re: Hamwich] #606843
07/12/19 05:49 PM
07/12/19 05:49 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
+1
Re: New Engine at Last [Re: IvorMog] #606844
07/12/19 06:21 PM
07/12/19 06:21 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
+1. Photos please .
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle"
Re: New Engine at Last [Re: IvorMog] #606847
07/12/19 06:31 PM
07/12/19 06:31 PM
Mandello del Lario
Gambalunga Offline
Gambalunga  Offline
Mandello del Lario
Congratulations. It is a great satisfaction to achieve such a success. Was the ECU the original Morgan ECU or something aftermarket? I am fascinated by the fact that you were able to adjust the fuel map and log the ECU which, of course, I have done with the Omex ECU.
I am also a little curious as to why you did not fit individual throttle bodies while you were at it. Omex have kits available for the Blacktop.
http://omextechnology.co.uk/tb-kits-zetec-blacktop.html
Re: New Engine at Last [Re: IvorMog] #606849
07/12/19 06:37 PM
07/12/19 06:37 PM
Paul F Online happy
Paul F  Online Happy
Yes, refurbished the callipers, new rear slave cylinders and braided hose.
Excellent stuff. When run-in, you will have a wonderful car. And it will still be the best kind of Morgan - a narrow 4/4.
Costock, UK
Disco 4
Re: New Engine at Last [Re: IvorMog] #606859
07/12/19 07:34 PM
07/12/19 07:34 PM
Surrey
Kevcaster Offline
Kevcaster  Offline
Surrey
Awesome
I’m totally impressed
Kevin
2009 Morgan Plus 4 4 seater
Re: New Engine at Last [Re: IvorMog] #606868
07/12/19 08:10 PM
07/12/19 08:10 PM
Devonshire
+8Rich Online content
+8Rich  Online Content
Devonshire
Good work that man, well done thumbs
Regards Richard
1994 Connaught Green +8 prev
Moderated by  Aeroman, Simon
