1 registered members (Trw), 182 guests, and 14 spiders.
+8Rich 240
John V6 142
Hamwich 126
Image 120
Wanted M3W
by Gambalunga. 23/02/20 11:07 PM
Driveline Information
by Rob82. 23/02/20 09:51 PM
Fog stirrer
by nick w. 23/02/20 09:42 PM
Roadster ground clearance
by Richard Wood. 23/02/20 08:00 PM
Copy of warrentee
by Bluesman. 23/02/20 07:57 PM
Starter Motor - which one
by DaveK. 23/02/20 06:32 PM
Inner track rod end - bush O/D
by teknome. 23/02/20 05:09 PM
Garage art
near eccleston VA
FolkMog lunch
well..
Today at Krazy Horse
Tipracer, George Okuda, Alice, ahdguy, Colin725
6829 Registered Users
Topics37,315
Posts606,351
Members6,829
Most Online1,033
Dec 28th, 2019
No Birthdays
Re: New Engine at Last [Re: Gambalunga] #606873
07/12/19 09:29 PM
07/12/19 09:29 PM
Staffordshire
IvorMog Offline OP
IvorMog  Offline OP
Staffordshire
Congratulations. It is a great satisfaction to achieve such a success. Was the ECU the original Morgan ECU or something aftermarket? I am fascinated by the fact that you were able to adjust the fuel map and log the ECU which, of course, I have done with the Omex ECU.
I am also a little curious as to why you did not fit individual throttle bodies while you were at it. Omex have kits available for the Blacktop.
http://omextechnology.co.uk/tb-kits-zetec-blacktop.html
I have the Omex ECU, same as yours.
Started with one of my old Silvertop maps and modified it.
I have some ideas of my own for the intake system but for now I will just run the standard manifold and throttle body then decide what route to take.
Bob
1999 4/4 2 litre Zetec
Re: New Engine at Last [Re: IvorMog] #606877
07/12/19 09:53 PM
07/12/19 09:53 PM
Luddite Offline
Luddite  Offline
I really enjoyed reading your Story Bob, Most impressed with your skills and can do attitude....Sooooperb.
Re: New Engine at Last [Re: IvorMog] #606885
07/12/19 11:16 PM
07/12/19 11:16 PM
Mandello del Lario, Lake Como,...
Gambalunga Offline
Gambalunga  Offline
A lot of fun isn't it. I was given an updated version of the calibration for the Duratec but the table was for different points on both the RPM and throttle opening. It had an ignition map that was somewhat different to mine. I inserted the new ignition map and then created a spread sheet with an algorithm to change the fuel map to line up with the new grid. Once the new fuel map, essentially the same but on a different grid, was inserted I did a few runs logging the ECU and corrected a couple of minor deviations. The result was a much improved mid-range. The other thing that I have been working on is the cold fuelling adjustment that gives additional fuel between 0° and 70°C, when the sonda lambda reading starts to control the feedback loop. I went for a run this morning with an initial temperature of 5°C and I have decided I am happy with the result. drive
Re: New Engine at Last [Re: IvorMog] #606911
08/12/19 10:11 AM
08/12/19 10:11 AM
Northamptonshire UK
Stringers Best Mate Offline
Northamptonshire UK
Cracking post, Bob..!
Well done, you.
Happy Christmas, matey.
Re: New Engine at Last [Re: IvorMog] #606943
08/12/19 02:54 PM
08/12/19 02:54 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
Well done Bob.
You now qualify for a five star hands on badge.
How many skinned knuckles? grin2
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: New Engine at Last [Re: IvorMog] #606969
08/12/19 04:08 PM
08/12/19 04:08 PM
YORK
KEVFITZ Offline
KEVFITZ  Offline
YORK
Well done Bob...great work..better than working for a living !!!
Remember your car parked in front of the Dakota on our trip to Lincolnshire
Re: New Engine at Last [Re: KEVFITZ] #606982
08/12/19 05:02 PM
08/12/19 05:02 PM
Aerdenhout, The Netherlands
BertR Offline
BertR  Offline
Impressed by your posting, quite an achievement to get everything to work!
2009 Roadster, Lancia midnight blue, cinnamon upholstery.
Re: New Engine at Last [Re: IvorMog] #606993
08/12/19 05:57 PM
08/12/19 05:57 PM
howard Offline
howard  Offline
How did you adjust the mixture without a means of measuring the fuel air ratio. Or did you have such a means. Were you able to check exhaust pipe output
Re: New Engine at Last [Re: IvorMog] #607007
08/12/19 07:16 PM
08/12/19 07:16 PM
Staffordshire
IvorMog Offline OP
IvorMog  Offline OP
Staffordshire
Thanks for your comments guys.
It's one of the great joys of Morgan ownership that there is such a diverse bunch of enthusiasts, all in it for different reasons but still appreciative of others efforts.
I'll post some more information after the dyno run on Wednesday and I'll fish out a couple of photo's
Bob
Re: New Engine at Last [Re: howard] #607010
08/12/19 07:40 PM
08/12/19 07:40 PM
Staffordshire
IvorMog Offline OP
IvorMog  Offline OP
Staffordshire
With the Omex ECU there is a closed loop system that gives feedback from the Narrowband Lambda sensor.
It does not give a direct reading of the air fuel ratio but it does tell you how much fuel the computer is adding or subtracting to get back to Lambda 1, i.e. the stoichiometric AFR of 14.7:1
If for example the ECU was showing minus 10% on the Oxygen Feedback (OXFB) readout, that means that the computer is deducting 10% fuel to get back to Lambda1.
That therefore means that the mixture is approximately 10% too rich in that particular load / speed site so simply reduce that mapping site number by 10% and play with it until the OXFB is as close to Zero as possible.
It's not ideal at the higher load and speed sites on the fuel grid as it is better to have a lambda of somewhere between 0.85 to 0.90 (i.e a richer mixture with an AFR between 12.5 and 13.2) for best torque and the Narrowband sensor will only read Lambda1.
However it does give a reasonably reliable indication of the mixture as a good starting point.
From there one can either work through a range of road tests using the data logging process ( which is what I think Gambalunga does) until the best overall configuration is found or use a wideband lambda sensor on a dyno to give a fairly accurate map and then refine it slightly after the road testing.
Both are equally valid but the wideband dyno system gets there a bit faster.
As Gambalunga will attest to, I think, this adds a whole extra dimension to Morgan ownership and engine tuning in general.
Bob
Moderated by  Aeroman, Simon
