17 registered members (James B W, ChrisConvertible, StevieMac, AlexKnoll, IcePack, Phil4/4, Gambalunga, Richard Wood, JohnS, +8Rich, milligoon, SALMO, Rob Thornton, Uther, RedThree, TBM, PeterG), 172 guests, and 16 spiders.
+8Rich 322
John V6 256
TBM 167
Alistair 151
Hamwich 148
Plus Four Fiat numbers
by Mkiss. 22/09/20 09:16 PM
Front pictures as promised Ferrari TDF Plus 4
by jatinder dhesi. 22/09/20 08:20 PM
Webcon Retroject
by Gilles L.. 22/09/20 08:09 PM
1974 4/4 ...steering wheel
by thelastgizmo. 22/09/20 06:56 PM
Classic Motor Show
by PhilRoyle. 22/09/20 06:20 PM
Up, Up, and Away....
by Jon G4LJW. 22/09/20 05:08 PM
wait for it
Stonor breakfast club - Oxfordshire
Cotswold Classic Tour 19/9/20
Rattray and Troup 4/4 80th
A grand day out
Koopz, hashluck, KennyW, David Stepanis, Malroy
7166 Registered Users
Topics39,439
Posts650,843
Members7,166
Most Online1,033
Dec 28th, 2019
Peter1062
Waterlogged foglight and indicator housings #606926
08/12/19 01:10 PM
08/12/19 01:10 PM
Surrey
Kevcaster Offline OP
Surrey
My foglamp and offside front indicator light housings were both waterlogged. The foglamp was inoperative, rusted solid and terminal but I managed to clean and renovate the front indicator housing which was working. I have ordered a new front indicator light unit and will replace the old one once it arrives. The foglamp will be fixed/replaced by Bell and Colvill under warranty.
My question is. How can I ensure that water is kept out of the light units? It seems to me that the ingress is from the back and that the covers, such as they are, failed to keep out the road spray from underneath the wings. What do people do as a fix on this?
Kevin
Kevin
2009 Morgan Plus 4 4 seater
Re: Waterlogged foglight and indicator housings [Re: Kevcaster] #606928
08/12/19 01:25 PM
08/12/19 01:25 PM
Solihull
Spanner Juggler Offline
Solihull
Not a satisfactory answer I know but after years of trying to prevent water ingress to
BL/Lucas lamps I quickly learnt that drilling a tiny pin hole (burn a pin hole through if a plastic lens is the lowest point) and a decent application of petroleum jelly (Vaseline) on the bulb holder contacts is often the best work around. 40 years later I still used this method on a tin top when 5 warranty returns failed to solve the problem. It was so bad I asked if the dealer sold goldfish as it was seemed a waste to not use the fishbowl that the rear light cluster had become (Ford Kuga).
BR Colin
Re: Waterlogged foglight and indicator housings [Re: Kevcaster] #606931
08/12/19 02:16 PM
08/12/19 02:16 PM
Staffordshire UK
Calypso Red Offline
Calypso Red  Offline
Staffordshire UK
Hi Kevcaster, I made sure the gasket under the lens was fitted correctly with no gaps then made sure the lens screws had effective rubber seals, (I might have made my own, can,t remember) then plastered the back of the lamp fitting under the wing with under seal. No trouble since!
Calypso Red
1994 +8 BMW Calypso Red.
2002 4/4 4 seater BMW Calypso Red.
Re: Waterlogged foglight and indicator housings [Re: Spanner Juggler] #606933
08/12/19 02:20 PM
08/12/19 02:20 PM
Surrey
Surrey
Excellent!
Thanks for the advice
Kevin
Kevin
Re: Waterlogged foglight and indicator housings [Re: Calypso Red] #606934
08/12/19 02:25 PM
08/12/19 02:25 PM
Surrey
Surrey
OK thanks, this looks like another solution. I wondered about fashioning my own gaskets/covers and this seems to be the route I'll take and replace the bolts with stainless steel items
Kevin
Re: Waterlogged foglight and indicator housings [Re: Kevcaster] #606937
08/12/19 02:44 PM
08/12/19 02:44 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
All the above is good advice. A simple neoprene patch over the back of the unit under the wing might be enough, but the seal in the front is crucial.
Also if replacing the two setscrews, there is more than one thread in use, and most alternatives I've tried are very tight in the top hat brass female nuts.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Waterlogged foglight and indicator housings [Re: Kevcaster] #606944
08/12/19 02:56 PM
08/12/19 02:56 PM
norfolk, UK
lowebird Offline
lowebird  Offline
norfolk, UK
I have suffered from this problem also and just like Colin I used copious amounts of Vaseline ( other petroleum based products are available ) this seemed to hold the water at bay.
Reg
Re: Waterlogged foglight and indicator housings [Re: Kevcaster] #606979
08/12/19 04:51 PM
08/12/19 04:51 PM
Huntingdon
Scrambledsignals Offline
Huntingdon
Vaseline gets my vote, I smear on both sides of the sealing gasket and it keeps the water at bay.
From bitter experience, have found that overtightening the lamp screws does not provide a better seal just distorts the gasket and lets water get in.
Re: Waterlogged foglight and indicator housings [Re: Kevcaster] #606996
08/12/19 06:32 PM
08/12/19 06:32 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Vaseline as stated plus waxoyling the underside.
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle"
Re: Waterlogged foglight and indicator housings [Re: DaveW] #609704
25/12/19 10:17 AM
25/12/19 10:17 AM
Surrey
Surrey
All very good advice Dave.
I am still uncertain if the water ingress was from the front seals or the back. Here the new L691 bulb holder is installed with replacement stainless hex-head bolts. This unit comes with a new internal soft seal and a rear seal. Dave, as you predicted the captive nuts for the lens mounting screws were a different thread from the originals, I just switched them over. The new unit's mounting bolts were captive (by a crimp) and too short. I punched them out and used new stainless hex bolts.
The seal that backs the bulb holder and sits between it and the tubular mount, may well have been the point of water entry. This seal has a shallow relief for the lens retaining nuts that protrude slightly from the backplate - see top right. I think it is important for the integrity of there seal that it is positioned correctly - front to back.
I bought 60mm od 20mm id neoprene seals for the rear, they are seated behind the wing.
The neoprene seals are backed by nylon washers
Here is the view at the back of the wing. The spade connectors are temporary until I source proper sealed automotive connectors. I wrapped the leads in tape for now.
Final assembly prior to fitting the lens.
Kevin
Moderated by  Aeroman, Simon
