9 registered members (CLPlusFour, MATTMOG, RichardV6, OZ 4/4, Montegue, bmgermany, John Winn, TBM, Karlosfandango), 136 guests, and 16 spiders.
+8Rich 235
John V6 136
OZ 4/4 114
CooperMan 107
RichardV6 105
Modesto, Wheelybin, Bonnie66, RichT56, Morgandave
8324 Registered Users
Owners Handbook Surprise
by Ron C. 31/03/23 07:13 PM
Rest shock absorber adjustment
by Topline123. 31/03/23 05:55 PM
rear shocks
by Grumpy2. 31/03/23 04:33 PM
Super Duper 3 launch tomorrow..
by +8Rich. 31/03/23 02:52 PM
Smart Meter Fun
by DaveW. 31/03/23 11:52 AM
Roadtax tip
by CooperMan. 31/03/23 11:05 AM
M3W season '23 started! (@ 7 °C), 12.02.2023
Rat Rod style Threewheeler
Bimble to the New Forest
Brum by the sea
LM62
Topics44,894
Posts759,837
Members8,324
Most Online1,033
Dec 28th, 2019
Wingman
BS939 grade B #607071
09/12/19 09:38 AM
09/12/19 09:38 AM
Renfrewshire
BobtheTrain Offline OP
Renfrewshire
Hello All,
I'm buying an engineer's square to set up some woodworking machines and I am wondering what the accuracy of the title standard is?
BTW - Any recommendations on which square to buy? Thanks.
Best Regards
Lang may yer lum reek
Re: BS939 grade B [Re: BobtheTrain] #607077
09/12/19 10:52 AM
09/12/19 10:52 AM
Salem, Llandeilo
Scrambledsignals Offline
Salem, Llandeilo
If you want one that is very accurate, get a Moore and Wright square. These will be more than sufficient for engineering purposes.
As you will be using it to set up woodworking machines then companies like RDG Tools sell good quality squares.
It is important to know that a square may not be accurate on both it's inner and outer edge, usually just the outer edge, so if it is important that both edges are accurate, check the Conformance Certificate.
I would avoid buying a second hand square as if they are dropped it can knock the accuracy.
Re: BS939 grade B [Re: BobtheTrain] #607078
09/12/19 10:58 AM
09/12/19 10:58 AM
Monmouthshire, Wales
Fuel.inj Offline
Fuel.inj  Offline
As stated get a quality manufactured item M&W or Starrett and you won’t go far wrong. Avoid Chinese etc.
Re: BS939 grade B [Re: Scrambledsignals] #607095
09/12/19 01:18 PM
09/12/19 01:18 PM
Renfrewshire
Renfrewshire
Thank you SS. I have been looking at M&W as I know they are a well established firm, I knew of them when I was doing my apprenticeship at Linwood. How do I see the Conformance Certificate?
I certainly wouldn't buy second hand,
Best Regards
Re: BS939 grade B [Re: BobtheTrain] #607105
09/12/19 02:15 PM
09/12/19 02:15 PM
Salem, Llandeilo
Salem, Llandeilo
Am fairly sure that M&W give full details on their products on their website.
Have a look at:
https://www.bowersgroup.co.uk/product-range/moore-wright/4003-traditional-engineers-square.html
Re: BS939 grade B [Re: Scrambledsignals] #607114
09/12/19 03:06 PM
09/12/19 03:06 PM
Renfrewshire
Renfrewshire
Thank you Scrambled. This doesn't give angle tolerances but I have phoned Bowers and two very helpful people are looking into BS939 for me. The details on the site you sent give the parallelism of the blade and handle which is good but not quite what I was looking for. Cheers.
Best Regards
Re: BS939 grade B [Re: BobtheTrain] #607120
09/12/19 04:02 PM
09/12/19 04:02 PM
Renfrewshire
Renfrewshire
Bowers have just got back to me. The tolerance at the blade end is six tenths of a thou., so should be accurate enough!
Best Regards
Re: BS939 grade B [Re: BobtheTrain] #607196
09/12/19 10:57 PM
09/12/19 10:57 PM
Salem, Llandeilo
Salem, Llandeilo
Good enough for anything I do on a milling machine!
