9 registered members (RichB, lez, +8Rich, planenut, Clipper, Spanner Juggler, marshalben, B3MOG, xc68anc), 178 guests, and 30 spiders.
+8Rich 261
Peter J 128
John V6 124
Hamwich 108
Location
by Nostalgiajohn. 24/01/20 04:48 PM
The French want their words back!
by Gambalunga. 24/01/20 03:43 PM
ARP4 Info urgently needed
by NeilPom. 24/01/20 10:23 AM
How to sell my M3W?
by Chris M3W. 23/01/20 06:03 PM
Bonnet Stays & Qtr Panel Protectors
by Nostalgiajohn. 23/01/20 03:33 PM
Replace Hazard switch
by Anthony4/4. 23/01/20 03:13 PM
WA13FWY - does anyone know this car?
by jackmorini. 23/01/20 12:07 PM
New year walk
Seals and wreck of the Ythan estuary,
Saint Ex the Morgan in all its glory
Bevel box oil leak
Hogmanay Run
craig123, Martin Medland, banjo2005, kailambers, Martin Peel
6812 Registered Users
Topics37,070
Posts601,484
Members6,812
Most Online1,033
Dec 28th, 2019
No Birthdays
Sigma Engine Sump Plug & Fuel Filter #607420
11/12/19 12:10 PM
11/12/19 12:10 PM
Lancashire
RobCol Offline OP
RobCol  Offline OP
Lancashire
Does anyone know the part number of the Sigma engine oil sump plug as I believe this needs changing when doing an oil change.
Also how often should the fuel filter be changed and does anyone have the part number for this?
Rob
2012 4/4 Sport Grey
Re: Sigma Engine Sump Plug & Fuel Filter [Re: RobCol] #607541
11/12/19 07:59 PM
11/12/19 07:59 PM
dherdebart Offline
dherdebart  Offline
I had a Morgan 4/4 Sport (2009) for 9 years. I changed the oil sump plug every time during the oil and oil filter change (every 15000kms)..
The original Ford Motor Company (FOMOCO) oil sump plug, purchased in an official Ford dealership garage for the Ford Focus range did not fit right!
Since then, I always used a much cheaper oil sump plug from the aftermarket range for a Ford Focus Sigma engine, which fitted exactly right ( in Belgium).
I never changed the fuel filter ( I drove about 70000km before selling the Morgan).
Re: Sigma Engine Sump Plug & Fuel Filter [Re: RobCol] #607544
11/12/19 08:09 PM
11/12/19 08:09 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
Same here re the fuel filter, no need of change after 75.000 km.
Re: Sigma Engine Sump Plug & Fuel Filter [Re: RobCol] #607548
11/12/19 08:35 PM
11/12/19 08:35 PM
Cat302 Offline
Cat302  Offline
According to the Manuel, ref. Page 97
Fuel filter change every 15,000 miles. I have over 30000 miles and no problem with my filter and sump plug,Why would the sump plug require changing if it’s not leaking?
Re: Sigma Engine Sump Plug & Fuel Filter [Re: Cat302] #607550
11/12/19 08:44 PM
11/12/19 08:44 PM
Oxon
Craig Jezz Offline
Craig Jezz  Offline
Oxon
I’m assuming it’s because they have crushed washers, so they need to be replaced after an oil change
Craig Jezz
Morgan 4/4 Sports Sand (Williams & Wolf Tuned)
Re: Sigma Engine Sump Plug & Fuel Filter [Re: Cat302] #607551
11/12/19 08:44 PM
11/12/19 08:44 PM
Lancashire
RobCol Offline OP
RobCol  Offline OP
Lancashire
Thanks to everyone for the replies so far.
On my cars previous Dealer services they have charged £5.95 plus VAT for a new sump plug each time. I assumed that it has an integral crushable washer and this was the reason for its replacement.
Rob
2012 4/4 Sport Grey
Re: Sigma Engine Sump Plug & Fuel Filter [Re: RobCol] #607552
11/12/19 08:46 PM
11/12/19 08:46 PM
Lancashire
RobCol Offline OP
RobCol  Offline OP
Lancashire
Telepathy Craig?
Rob
2012 4/4 Sport Grey
Re: Sigma Engine Sump Plug & Fuel Filter [Re: RobCol] #607556
11/12/19 09:04 PM
11/12/19 09:04 PM
Mercia, UK
SALMO Offline
SALMO  Offline
Mercia, UK
Hi Rob,
If your car is anything like my Duratec the sump is specially made and nothing standard will fit. The plug is a shouldered bolt M12x1.75 from memory and the washer is a bonded washer (which can be used several times) and cost pennies
Here are a couple of piccies.
If I can help more let me know.
Regards
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
Re: Sigma Engine Sump Plug & Fuel Filter [Re: RobCol] #607584
11/12/19 10:54 PM
11/12/19 10:54 PM
Lancashire
RobCol Offline OP
RobCol  Offline OP
Lancashire
Hi Geof
The sump plug on my Sigma is a shouldered bolt but doesn't have a separate washer.
I've seen some Fiesta plugs on the internet which are M14 x 35mm long though not sure if this is the correct one. I think the best thing for me to do is to drain the oil which will give me the chance to identify & get a new sump plug if need be whilst the car isn't being used.
Thanks for the photos though as It shows that there are differences.
Rob
Rob
2012 4/4 Sport Grey
Re: Sigma Engine Sump Plug & Fuel Filter [Re: RobCol] #607603
12/12/19 08:54 AM
12/12/19 08:54 AM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
The sump plug on my Roadster, previous Duratec, and GDI all have a bonded rubber washer on the plug. I haven't changed one yet and they don't seem to leak.
In the first year I got a Mondeo plug as a replacement, but it was different so I never used it. It's still kicking about somewhere.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) Plus 4
Moderated by  Aeroman, Simon
