15 registered members (DCH, St Eve, Franko, petemog, JMcL, rainbowj, Rog G, Richard Wood, TBM, Grumpy2, Ian Wegg, N22MOG, Stringers Best Mate, Eddie, 60Yards), 131 guests, and 13 spiders.
+8Rich 261
John V6 141
Peter J 126
Hamwich 94
Off the Road
by PhilRoyle. 21/01/20 05:49 PM
M3W gathering southern Virginia June 12-14
by rcmatt. 21/01/20 05:06 PM
New Tyres
by Spanner Juggler. 21/01/20 04:00 PM
Grease is the word
by Fat Wolfie. 21/01/20 03:58 PM
Glassware Aero 8
by Flipsterbaby. 21/01/20 03:58 PM
Door Roundels
by RobCol. 21/01/20 03:22 PM
Bonnet Stays
by RobCol. 21/01/20 03:19 PM
New year walk
Seals and wreck of the Ythan estuary,
Saint Ex the Morgan in all its glory
Bevel box oil leak
Hogmanay Run
craig123, Martin Medland, banjo2005, kailambers, Martin Peel
6812 Registered Users
Topics37,056
Posts601,168
Members6,812
Most Online1,033
Dec 28th, 2019
Graeme Morrison, Kaou
Page 1 of 5 1 2 3 4 5
High-output LED Brake light bulbs #607861
13/12/19 02:29 PM
13/12/19 02:29 PM
Gloucestershire, UK
Hamwich Offline OP
Hamwich  Offline OP
Gloucestershire, UK
Years ago, when they first became available, I switched to LED stop/tail bulbs in my car, mainly to preserve the brake light switch which is known to fail, especially with the additional current of a 3rd bulb.
They've been fine, but recently I was alerted to the availability of high-output versions by a fellow Morgan owner and lurker on TM. They are available from www.bettercarlighting.co.uk and I fitted a set today. They really are significantly brighter than the original ones I was using, it's quite impressive how the technology has advanced so fast in a few years.
Here they are half-way through fitting, so you can see the difference.
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Re: High-output LED Brake light bulbs [Re: Hamwich] #607868
13/12/19 02:38 PM
13/12/19 02:38 PM
Mandello del Lario, Lake Como,...
Gambalunga Offline
Gambalunga  Offline
What I would really like would be complete LED replacements for all the brake, position and indicator lights. Not just replacements for the bulbs but for the complete units. The originals are really quite crappy.
Re: High-output LED Brake light bulbs [Re: Gambalunga] #607875
13/12/19 02:48 PM
13/12/19 02:48 PM
Gloucestershire, UK
Hamwich Offline OP
Hamwich  Offline OP
Gloucestershire, UK
Yes, I replaced mine years ago. Chromed brass mounting tubes with decent quality bulb holders, I also drilled out the original threaded holes and replaced them with M3 rivnuts and stainless hex bolts rather than those rubbish cross-headed fasteners.
Re: High-output LED Brake light bulbs [Re: Hamwich] #607878
13/12/19 02:51 PM
13/12/19 02:51 PM
norfolk, UK
lowebird Offline
lowebird  Offline
norfolk, UK
Tim H, There has been a lot of chat about LED lamps on other classic car sites with warnings that in some circumstances, they are deemed to be illegal due to the lack of an "E" rating and therefore one could fall foul of the MOT. I haven't found a definitive answer yet and I keep on trying, any ideas please?
Reg
Re: High-output LED Brake light bulbs [Re: lowebird] #607887
13/12/19 03:19 PM
13/12/19 03:19 PM
Gloucestershire, UK
Hamwich Offline OP
Hamwich  Offline OP
Gloucestershire, UK
As far as I'm aware the level of illumination from a bulb is left to the tester's discretion as to whether it is adequate or not. If anyone has got documented evidence of an MOT tester removing E-marked light lenses in order to check that the bulbs are also so marked, and failing the car as a result I would be very interested to see it. The internet is full of people who love to pontificate endlessly over issues that which for any normal human being would be considered completely irrelevant.
The only comment I have ever received from a tester (and I always make sure I am present during the testing process) was a couple of years ago when he looked at my wing sidelights and said "They are a bit bluish, have you put LEDs in there?"
When I replied yes, he said "Very sensible. Anything that helps visibility in these cars is good".
Re: High-output LED Brake light bulbs [Re: Hamwich] #607899
13/12/19 03:51 PM
13/12/19 03:51 PM
London
MOG 615 Offline
MOG 615  Offline
London
I am with Tim here , our cars are low and in these days of the ubiquitous SUV our rear lights are difficult to see, especially in conditions of reduced visibility.
Anything that improves this is a good thing, and I have taken the same route , also with Better Car Lighting. The guy who runs it is very helpful and a real source of knowledge about almost all forms of vehicle lighting.
Andy G
1999 +8 , Indigo Blue.
Re: High-output LED Brake light bulbs [Re: Hamwich] #607917
13/12/19 05:31 PM
13/12/19 05:31 PM
Aberdeenshire
E
Eddie Cairns Offline
E
Aberdeenshire
I thought it was only headlamp buldbs thatwere E marked. Never checked any non H type bulbs.
Re: High-output LED Brake light bulbs [Re: Hamwich] #607921
13/12/19 05:41 PM
13/12/19 05:41 PM
Arwyn Williams Offline
From memory, Authorised Testers are not permitted to undertake any dismantling work during the test.. Hence 'advisories' regarding engine covers, uundertrays and body kits being fitted often appear on MoT certificates.
Arwyn
Re: High-output LED Brake light bulbs [Re: Hamwich] #607937
13/12/19 07:38 PM
13/12/19 07:38 PM
norfolk, UK
lowebird Offline
lowebird  Offline
norfolk, UK
Well that seems to be good news. I am in total agreement that LED's provide a greater level of safety but have always been worried about the "legality" of them as retro fits.
Reg
Re: High-output LED Brake light bulbs [Re: Hamwich] #607943
13/12/19 08:04 PM
13/12/19 08:04 PM
Surrey
Kevcaster Offline
Kevcaster  Offline
Surrey
A large garage might be the ultimate luxury and this is a fine one.
Kevin
Kevin
2009 Morgan Plus 4 4 seater
Moderated by  Aeroman, Simon
