23 registered members (Paul F, Island Mog, Mr Mogoo, John Winn, Jon G4LJW, Viper, Gilles L., R1NGA, HJP, M3W55, cerealsurfer, PaulV, Morgan Atlanta, Grumpy2, IvorMog, Dab of oppo, hashluck, mise303, John07, JohnMat, mph, PhilRoyle, How), 100 guests, and 11 spiders.
+8Rich 318
John V6 256
TBM 167
Alistair 151
Hamwich 148
1974 4/4 ...steering wheel
by thelastgizmo. 22/09/20 06:56 PM
Classic Motor Show
by PhilRoyle. 22/09/20 06:20 PM
Up, Up, and Away....
by Jon G4LJW. 22/09/20 05:08 PM
Car Insurance !!
by Alistair. 22/09/20 04:46 PM
parking brake adjustment
by rcmatt. 22/09/20 01:38 PM
Outdoor temperature sensor
by peterd. 22/09/20 11:10 AM
Fitting LED lights in the under tray
by John V6. 22/09/20 11:01 AM
wait for it
Stonor breakfast club - Oxfordshire
Cotswold Classic Tour 19/9/20
Rattray and Troup 4/4 80th
A grand day out
Koopz, hashluck, KennyW, David Stepanis, Malroy
7166 Registered Users
Topics39,435
Posts650,823
Members7,166
Most Online1,033
Dec 28th, 2019
Peter1062
3.0 Roadster oil sump #607947
13/12/19 08:18 PM
13/12/19 08:18 PM
Billingham
mal Offline OP
mal  Offline OP
Billingham
Hi, I'm looking to change the oil sump on my 3.0 roadster, and can anybody tell me what the torque settings are for the sump bolts, and any hints to do the change
and do I silicone gasket sealant on the new gasket ???
Thanks in advance
Mal
3.0 Roadster 2007
Re: 3.0 Roadster oil sump [Re: mal] #607949
13/12/19 08:28 PM
13/12/19 08:28 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
The gasket is a solid rubber circular profile which sits inside a groove in the sump casting, so shouldn't need any sealer. There are some images on my Roadster sump thread.
Check the Mondeo or Jaguar S or X type for torque settings. At a guess...16 - 22 lbs ft.
http://www.talkmorgan.com/ubbthreads.php//topics/43365/Series_1_Roadster_Sump#Post43365
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: 3.0 Roadster oil sump [Re: mal] #607952
13/12/19 08:36 PM
13/12/19 08:36 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
mal, take the last page of Dave‘s post from above. He has insert again the pics at the end of the thread.
Re: 3.0 Roadster oil sump [Re: mal] #608024
14/12/19 09:22 AM
14/12/19 09:22 AM
Billingham
mal Offline OP
mal  Offline OP
Billingham
Thanks for the replies, Job will be done after xmas
Mal
3.0 Roadster 2007
Re: 3.0 Roadster oil sump [Re: mal] #608031
14/12/19 09:52 AM
14/12/19 09:52 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Mal,
my Haynes manual for the Ford Mondeo states:-
Stage 1 7 Nm 5 lbf ft
Stage 2 14 Nm 10 lbf ft
The sump drain plug is torqued to 23 Nm or 17 lbf ft
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle"
Re: 3.0 Roadster oil sump [Re: John V6] #608053
14/12/19 12:06 PM
14/12/19 12:06 PM
returned OggieMogger
Roady Offline
Roady  Offline
When my sump got broken I bought a Mondeo one. Be warned that they are not the same as the Mondeo one has a flat gasket and not the one that sits in the groove. I ended up importing a Chinese sump from America with Lorne Goodman's help. This was a direct replacement for the one used by the Ford escape of that period.
I can't find any reference number for the sump but I was able to buy the gasket locally. The part number is FMU 4802294 bought from a Ford main dealer for £49.86 in 2010.
Hope this helps
Re: 3.0 Roadster oil sump [Re: mal] #608056
14/12/19 12:52 PM
14/12/19 12:52 PM
Dubai
Steve19 Offline
Steve19  Offline
Dubai
Very simple job i did it to my 2010 3.0l roadster not long after i bought it, from memory there are 2 different bolt sizes in terms of length just note which ones go where as you remove them.
Steve Grisdale
Morgan 3.0l Roadster 2010 aka BORIS
Triumph Thunderbird 2000
Volvo XC 60 x 3
Volvo C30
Re: 3.0 Roadster oil sump [Re: mal] #608059
14/12/19 01:24 PM
14/12/19 01:24 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
The US Escape sump is available on ebay with a bit of searching.
Re: 3.0 Roadster oil sump [Re: DaveW] #608064
14/12/19 01:32 PM
14/12/19 01:32 PM
Billingham
mal Offline OP
mal  Offline OP
Billingham
Thanks Dave, I`ve got the modified sump, but no gasket, just need gasket and torque settings, didn`t want to damage the new sump when fitting (always like to torque the bolts rather than just tighten them)
the sump has the groove in it
Mal
3.0 Roadster 2007
Re: 3.0 Roadster oil sump [Re: mal] #608065
14/12/19 01:37 PM
14/12/19 01:37 PM
Billingham
mal Offline OP
mal  Offline OP
Billingham
Thanks again for all replies, different bolts (will make a Template out of cardboard and put the bolts in it as a remove them) and will contact my local ford dealership for a gasket
Mal
3.0 Roadster 2007
Moderated by  Aeroman, Simon
