17 registered members (James B W, ChrisConvertible, StevieMac, AlexKnoll, IcePack, Phil4/4, Gambalunga, Richard Wood, JohnS, +8Rich, milligoon, SALMO, Rob Thornton, Uther, RedThree, TBM, PeterG), 172 guests, and 16 spiders.
+8Rich 322
John V6 256
TBM 167
Alistair 151
Hamwich 148
Plus Four Fiat numbers
by Mkiss. 22/09/20 09:16 PM
Front pictures as promised Ferrari TDF Plus 4
by jatinder dhesi. 22/09/20 08:20 PM
Webcon Retroject
by Gilles L.. 22/09/20 08:09 PM
1974 4/4 ...steering wheel
by thelastgizmo. 22/09/20 06:56 PM
Classic Motor Show
by PhilRoyle. 22/09/20 06:20 PM
Up, Up, and Away....
by Jon G4LJW. 22/09/20 05:08 PM
wait for it
Stonor breakfast club - Oxfordshire
Cotswold Classic Tour 19/9/20
Rattray and Troup 4/4 80th
A grand day out
Koopz, hashluck, KennyW, David Stepanis, Malroy
7166 Registered Users
Topics39,439
Posts650,843
Members7,166
Most Online1,033
Dec 28th, 2019
Peter1062
Replacement fog light unit 2009 plus 4 #608092
14/12/19 04:25 PM
14/12/19 04:25 PM
Surrey
Kevcaster Offline OP
Surrey
Hello everybody
Bell and Colvill have my car captive while they sort out (under warranty) the rear fog light that had become waterlogged and rusted solid. It’s been there for a few days awaiting parts that finally proved to be unavailable from the factory. The unit is the one that screws into the cylindrical rubber mounting on a course thread formed into the light housing. I cannot imagine that Morgan commissioned this and guess that it is sourced from others - Landrover/BMC etc. - where could I find this part?
B&C have apparently used the bulb holder from another type of unit to fix the problem and assure me that I will not notice the difference, they still have the car and so I cannot inspect it. I am curious as to where this part is sourced for possible future issues. They have had the car for 5 days to fix this and fit a grub screw to the heater fan knob that had fallen off and disappeared. I’m not impressed with all this and, while I have some empathy regarding the hunt for parts, they have apparently fitted a new heater switch which was not the problem. Anyway, the fog light is my main concer and where I might get one.
Kevin
Kevin
2009 Morgan Plus 4 4 seater
Re: Replacement fog light unit 2009 plus 4 [Re: Kevcaster] #608096
14/12/19 04:31 PM
14/12/19 04:31 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Melvyn Rutters would be a good starting point.
2006 Indigo Blue Roadster S1
2014 Brooklands Edition Roadster "Brookland's Belle"
Re: Replacement fog light unit 2009 plus 4 [Re: Kevcaster] #608100
14/12/19 04:37 PM
14/12/19 04:37 PM
Yorkshire
CooperMan Offline
CooperMan  Offline
Yorkshire
Kevin, when you get your car back can you post a photo ? As lots of bits are interchangeable
There is a little known Co called Charlesworth & Sons Ltd, in the West Mids, who make several Mog specific injection moulded bits for MMC like the rear light pods for the 3W and I think the black tapered bases for the other lights
Re: Replacement fog light unit 2009 plus 4 [Re: Kevcaster] #608246
15/12/19 03:45 PM
15/12/19 03:45 PM
Surrey
Surrey
OK thanks I'll look at these options and also post pictures once the car is retuned
Kevin
Kevin
Re: Replacement fog light unit 2009 plus 4 [Re: Kevcaster] #608364
16/12/19 03:04 PM
16/12/19 03:04 PM
norfolk, UK
lowebird Offline
lowebird  Offline
norfolk, UK
Kevin, once you have seen what is now fitted, get a copy of the "Carbuilders" catalogue, you may very well find it in there. www.carbuilder.co. or 01580 991309. Good luck.
Reg
Re: Replacement fog light unit 2009 plus 4 [Re: Kevcaster] #608376
16/12/19 04:29 PM
16/12/19 04:29 PM
Surrey
Surrey
OK I have looked around quite a lot and eventually took a chance on the Lucas L691 unit. It is very similar, diameter correct and generally the same type of unit. The internals are different, better quality that the Morgan and the lens a different shape - also better quality. The mounting screws for the Lucas unit are too short and are captive in the bulb holder and so will need a connector bolt to lengthen them sufficiently to fit to the wings through the cylindrical mount.
For now I will keep the old unit, it is working, and consider if I might swap both the front ones for the better Lucas units.
Thanks again for all the help
Kevin
Kevin
Moderated by  Aeroman, Simon
