11 registered members (DavidR, SimonH, Spanner Juggler, CasaLobo, Robbie, Alan Patterson, DaveW, IvorMog, flyfisher, Helfinger, How), 122 guests, and 16 spiders.
John V6 289
+8Rich 281
Peter J 170
Image 139
Morgan Plus 8 / Speedster Air Filter
by Helfinger. 14/04/21 11:12 AM
S1 side glass.
by Viper. 14/04/21 08:17 AM
Leicestershire sighting
by Farmer Giles. 13/04/21 09:47 PM
Leaking master cylinder
by auster. 13/04/21 08:04 PM
Morgan 4/4 for sale
by Spanner Juggler. 13/04/21 07:40 PM
alternative bevel box - bb replacement ?
by thono. 13/04/21 07:29 PM
Good news for Rhino's in Nepal
by +8Rich. 13/04/21 04:36 PM
2017 Sport Blue M3W
Front spoiler
My M3W
Spring has sprung at Hintlesham...
Rebuilds begin
JFPlus4, Garry4, Steven Cheong, Ben25855, Scott G
7473 Registered Users
Topics40,987
Posts685,828
Members7,473
Most Online1,033
Dec 28th, 2019
missprint, p8mog
Gearbox removal #609430
22/12/19 09:47 PM
22/12/19 09:47 PM
Calgary Alberta Canada
Dave Turner Offline OP
Over the last couple of years my 1997 plus 8 (short door) has been developing a rattle in the gearbox (R380) I have checked and replaced the gear oil with syncromax synthetic but no improvement .
It’s time to think about having a look inside it at the bearings etc , my question is can the gearbox be removed without removing the engine either from below or by removing the tunnel and extracting it through the passenger compartment?
Normally I would just pull the engine / gearbox as a unit but I am currently 2500 Kilometres away from home and have limited tools and equipment with me .
Thanks Dave
Re: Gearbox removal [Re: Dave Turner] #609435
22/12/19 10:24 PM
22/12/19 10:24 PM
Never mind , I just crawled under the car and there is no way the bell housing would clear the bulkhead , so I guess it will have to wait untill I return home in the spring .
Cheers Dave
Re: Gearbox removal [Re: Dave Turner] #609438
22/12/19 10:34 PM
22/12/19 10:34 PM
Llanelli
Ray Offline
Ray  Offline
Llanelli
Unfortunately it's an engine out job if you can get enough height on the chain and block the engine and box can be tillted enough to lift out together. I have done it in the past.
Re: Gearbox removal [Re: Dave Turner] #609445
22/12/19 11:39 PM
22/12/19 11:39 PM
Andrew Green Offline
Hi Dave
Just a thought. Are you sure that the rattle comes from inside the gearbox?
All my gearbox rattles have come from the remote gearchange rather than the box itself.
Lots of information to be found on gomog.com
Best of luck
Andrew Green
Glorious Devon
2002 Plus 8
Re: Gearbox removal [Re: Dave Turner] #609459
23/12/19 08:23 AM
23/12/19 08:23 AM
Luddite Offline
Luddite  Offline
Sorry to read of your gearbox issue Dave. My +8`s engine ran less than smoothly when brought back into use after a lengthy lay-up, at which time my gearbox really rattled when the engine was trying to idle, though seemed fine while under load, I found a split in the diaphragm of one of the carbs and a few other issues that once resolved, removed the rattle from the gearbox..! If nothing as simple as that then perhaps this link might help...
https://www.ashcroft-transmissions.co.uk/manual-gearboxes/r-380.html
I think some +8 folk changed to Toyota gear boxes..
Good luck.
Re: Gearbox removal [Re: Dave Turner] #609476
23/12/19 11:06 AM
23/12/19 11:06 AM
Solihull
Spanner Juggler Online content
Spanner Juggler  Online Content
Solihull
I was just about to type what Andrew has above. First port of call is the rubber bushings for the remote.
Good luck it’s just those.
Colin
BR Colin
Re: Gearbox removal [Re: Dave Turner] #609477
23/12/19 11:31 AM
23/12/19 11:31 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Check both the bushes but also the spring loaded cup on the gear shift. On my 97 +4 the securing tab on the cup broke. This caused a rattle & made gear changes difficult..
http://www.gomog.com/allmorgan/remoteissues.html
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Gearbox removal [Re: Dave Turner] #609480
23/12/19 11:45 AM
23/12/19 11:45 AM
Luddite Offline
Luddite  Offline
Given Andrew & Colin`s input, I just thought it might be worth adding that during my +8`s lay-up, I had replaced all the rubber bushes on the remote mounting, which was prior to the gearbox rattle I experienced and was fortunate enough to resolve with an engine tune up..!
Re: Gearbox removal [Re: Dave Turner] #609521
23/12/19 04:27 PM
23/12/19 04:27 PM
Evergreen, Colorado, USA
britmog Offline
britmog  Offline
I had a rattle emanating from the gear box in my 94 +8 which turned out to be grub screw coming loose on the remote gear shifter. Certainly make sure you have eliminated all the easy fixes before you start taking the engine and gearbox out.
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
Re: Gearbox removal [Re: Dave Turner] #609530
23/12/19 06:43 PM
23/12/19 06:43 PM
Wow guys thanks for all the input .
I have been fooled before with rattles and squeaks coming from different places , I will dig into the remote linkage and see what’s to be found .
While I have your attention what oil are you running in the R380 the land rover gearbox manual calls for ATF M2C33 F or G which I read as type F ATF but Land Rover discovery guys have lots of ideas for alternatives
Thanks Dave
