15 registered members (Grumpy2, Rog, Bluebricked, Alan Patterson, teifistar, Steve +8, Rog G, John V6, SimonH, 1950sCol, Dave Collis, brian battersby, Socalm3w, M3W55, DJC),
151
guests, and 25
spiders. |
Topics40,987
Posts685,831
Members7,473
Most Online1,033 Dec 28th, 2019
Re: Gearbox removal
[Re: Dave Turner]
#609532
23/12/19 06:55 PM
23/12/19 06:55 PM
Posts: 27,096 Devonshire
Devonshire
I use a Comma ATF over here in my R380, as you suggest there are many different opinions on this one. This is what Gomog has to say on the matter.
Regards Richard
1999 Indigo Blue +8 2009 4/4 Sport Green prev 1994 Connaught Green +8 prev
Re: Gearbox removal
[Re: Dave Turner]
#609549
24/12/19 12:02 AM
24/12/19 12:02 AM
Posts: 1,943 Seattle, USA
Button
Seattle, USA
Don't get talked into converting to a Borg Warner T-5 Transmission. That is what I used when I built My +8 Bitsa. My T-5 works well but I had a mis match of parts to start with. I have driven +8's with the Rover transmission and it worked very well. Maybe better than the T-5 at least as good. I think some +8 Racers in the UK like the T-5 for some reason I am not sure why.
Button
Re: Gearbox removal
[Re: Dave Turner]
#609635
24/12/19 04:40 PM
24/12/19 04:40 PM
Posts: 7,850 Llanelli
sospan
Llanelli
John...replacement “cups” for the gearshift are rarer than hen’s teeth. Even rarer than a politician who answers questions! UKC 3159 is the part number. They have a weakness where the tab snaps due to fatigue. Mine had been welded by a previous owner but strengthening tabs need to be added. I made a small bracket to beef up mine and bolted it above the fixing tab. I also dribble a bit of oil down to reduce friction against the gear lever ball that sits under it. The gear hange is much better with the repaired cup. A thought........ it appears anyone with the R380 or LT77 box seems to have the issue long term so I wonder if some could be made by an enterprising engineer with access to a suitable press. I guess set up cost and volume are limiting factors though.
Red Plus8
Re: Gearbox removal
[Re: Dave Turner]
#609674
24/12/19 10:41 PM
24/12/19 10:41 PM
Posts: 242 Sandhurst, Berks
teknome
Sandhurst, Berks
There is also the UKC8764 dust cap which is basically the same as the UKC3159 but the UKC8764 needs some slots cut in it to match those in the UKC3159. I think the UKC8764 was used on the LT77 remote. I used one on my R380 box last year. It is listed by http://mgrovergenuine.co.uk/ but currently out of stock, may be worth asking them if they will get stock.
--------------------------- Mike Smith
1995 +8 2007 +4
Re: Gearbox removal
[Re: Dave Turner]
#609698
25/12/19 08:50 AM
25/12/19 08:50 AM
Posts: 19,567 Suffolk
Suffolk
Yep, I built a tab from some scrap metal and pop rivetted it on. 6 months later Rimmers finally sent me a new one.
JohnV6 2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Gearbox removal
[Re: Dave Turner]
#610130
29/12/19 09:08 AM
29/12/19 09:08 AM
Suffolk
Sorry to hear that Dave. Good luck.
