5 registered members (RobNW, StevieMac, Chris99, LightSpeed, Heinz), 189 guests, and 15 spiders.
John V6 294
+8Rich 293
Peter J 177
Scrap a ship in Scotland
by ewn. 17/04/21 07:23 PM
John Dawes
by Scrambledsignals. 17/04/21 06:42 PM
Bell Huey & Cobra choppers
by DaveW. 17/04/21 05:32 PM
3 WHEELER REAR MUD GUARD KIT Instructions
by Bigpoppapump. 17/04/21 05:03 PM
Rod Mirror - Easy Up Hood
by Paul F. 17/04/21 03:46 PM
750 miles, made an inspection hole, surprises...
by GregA10. 17/04/21 11:31 AM
Indicator / Wiper stalk bending?
by TimB. 17/04/21 11:30 AM
Lap of the Cairngorms
2017 Sport Blue M3W
Front spoiler
My M3W
Spring has sprung at Hintlesham...
JFPlus4, Garry4, Steven Cheong, Ben25855, Scott G
7473 Registered Users
Topics41,018
Posts686,420
Members7,473
Most Online1,033
Dec 28th, 2019
BobTyers, tom+4
Voltmètre or Ampmeter? #610333
30/12/19 10:15 PM
30/12/19 10:15 PM
Touraine, France
Toucan Offline OP
Toucan  Offline OP
Touraine, France
Hi all,
On my dashboard l have an indicator posted as a Volt meter round shaped, last on the right side.
On the wiring diagram for 1981 4/4 it is suposed to be an Ammeter.... Needle on 14 (+++) nearly all the time. is this a real Voltmeter, and wiring diagram wrong, or an Ammeter indicating the charging status poetically posted as Voltmeter by the factory? wine
Has anybody got a wiring diag with a Voltmeter? confused2
Toucan 1981 4/4 Kent
Re: Voltmètre or Ampmeter? [Re: Toucan] #610338
30/12/19 10:36 PM
30/12/19 10:36 PM
Aberdeenshire
Image Offline
Image  Offline
Aberdeenshire
An ammeter should have brown and brown/white wires going to it and be between your alternator and solenoid.... It should also read both ways from the centre + and -
A voltmeter goes from something to earth, reads one way, and 14 ish volts would be good high charging volts for your battery
Try turning your ignition on... If the meter comes up to 12/13 without the engine running it's a voltmeter (and may rise to 14+with the engine running)
An ammeter will sit (pretty much) with the ignition turned on.... Go negative if you put the headlights on.... Go really negative when you hit the starter... And come back up when it's running (pretty much to the middle if your batteries good or into the plus if it's putting back what you just took out)
PS... welcome Toucan... I also have a crossflow engined car.... Gradually being reduced to a chassis before coming back better than ever hopefully
Re: Voltmètre or Ampmeter? [Re: Toucan] #610341
30/12/19 10:42 PM
30/12/19 10:42 PM
Aberdeenshire
E
Eddie Cairns Offline
E
Aberdeenshire
Yes it is thought for normal use the voltmeter confirms that the electics are working.
A true ammeter in the circuit is a possible failure point in the electrical system and with modern alternator equiped cars since the late 1970's there is no advantage to be gained by having an ammeter.
Only a place for things to go wrong.
Re: Voltmètre or Ampmeter? [Re: Toucan] #610342
30/12/19 10:46 PM
30/12/19 10:46 PM
Devonshire
+8Rich Offline
+8Rich  Offline
Devonshire
As has been said it will be a Voltmeter, Ammeters went out with dynamo's if I recall correctly, think sixties.
Never forget however that it is a Morgan and many owners like adding modifications including to electrics.
A simple definition of the Ammeter is that it has to be in series with the battery whereas the Voltmeter is in parallel with the battery and that can be easily traced. Your reading of 14 does sound very much like the charging voltage to me this is a little high but these instruments are fairly agricultural tbh.
Here is a diagram with Voltmeter courtesy of Lorne.
Regards Richard
1994 Connaught Green +8 prev
Re: Voltmètre or Ampmeter? [Re: Toucan] #610344
30/12/19 11:10 PM
30/12/19 11:10 PM
Aberdeenshire
Image Offline
Image  Offline
Aberdeenshire
My '75 has an alternator and an ammeter in the 'multi' instrument big dial.... As you say, ammeters are more of a dynamo thing so that is probably a transition thing.... With the voltmeter taking over by the time Toucan's '81 came along.... You can't rush these thing you know! :-)
Re: Voltmètre or Ampmeter? [Re: Toucan] #610345
30/12/19 11:12 PM
30/12/19 11:12 PM
Devonshire
+8Rich Offline
+8Rich  Offline
Devonshire
You are right it is a Morgan after all.
I guess as you say yours is a transition set up.
Regards Richard
Re: Voltmètre or Ampmeter? [Re: Toucan] #610347
30/12/19 11:21 PM
30/12/19 11:21 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
The Gomog website will have wiring diagrams
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Voltmètre or Ampmeter? [Re: +8Rich] #610350
30/12/19 11:29 PM
30/12/19 11:29 PM
Aberdeenshire
Image Offline
Image  Offline
Aberdeenshire
The 'transition' was probably as long as it took them to run out of the big box of dynamo 'multi dials' they had out back. :-)
Re: Voltmètre or Ampmeter? [Re: Toucan] #610351
30/12/19 11:33 PM
30/12/19 11:33 PM
Devonshire
+8Rich Offline
+8Rich  Offline
Devonshire
laugh2 thumbs
Regards Richard
Re: Voltmètre or Ampmeter? [Re: Toucan] #610356
31/12/19 01:35 AM
31/12/19 01:35 AM
Taffmog Offline
Taffmog  Offline
Ammeters were still use with alternators. +/- 30 for dynamos and +/- 50 for alternators.
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
