Morgan Aero 8
2 registered members (Heinz, AZJowett), 122 guests, and 14 spiders.
+8Rich 525
John V6 445
TBM 179
Heinz 170
Stuck Indoors?
by Clipper. 30/03/20 09:07 PM
Bread in the USA
by +8Rich. 30/03/20 06:03 PM
4/4 4 seater car cover
by Tim W. 30/03/20 03:18 PM
Kop Hill Climb
by Ricardo. 30/03/20 12:57 PM
V10 Aero 8
by V10 Morgan aero. 30/03/20 09:56 AM
Car SOS
by James B W. 30/03/20 08:48 AM
Rural Virgina
Forrestburn track day
Updated-Bafflectomy Procedure
Suffolk in the sun
Ver.2 Morgans at Knockhill
Cuna2016, TonyRH, Kriado, MorganDriver, Andy Morris
6893 Registered Users
Topics37,667
Posts614,607
Members6,893
Most Online1,033
Dec 28th, 2019
PhilRoyle
Rear ABS rings on S2 #612071
11/01/20 12:12 PM
11/01/20 12:12 PM
Hampshire
Alistair Offline OP
Smile, it confuses them
Alistair  Offline OP
Hampshire
I was reminded by another PlusSix thread about a conversation during the last MoT and thought it might be worth sharing on the Aero thread.
I had been hearing what sounded like a ting-ting-ting noise from the back end which was road speed related. Not loud and sounding like metal clicking against metal. I wondered if it was something related to the handbrake as they are always an interesting optional extra !
During the last MoT the engineer pointed out that the ABS sensors on the back wheels use metal rings which are around the back of the hub/half-shaft. These are like a large toothed ring and have high/low islands which is what passes the sensor and generates the pulses the braincells read for road speed.
These rings can corrode, swell or warp over time. I was told they are from a 1Series BMW and this car is known for the same problem. It is not a huge problem swapping them however I think you do have to take the halfshaft out and take thm off in the direction of the diff not the wheel but I may have remembered that incorrectly.
If you have the car up in the air it is worth looking at the sensor rings on the back axle.
Just time to burn a little more petrol before dinner.
Re: Rear ABS rings on S2 [Re: Alistair] #612093
11/01/20 03:08 PM
11/01/20 03:08 PM
Salisbury, UK
Peter J Offline
Formerly known as Aldermog
Peter J  Offline
Salisbury, UK
Interesting: are they the same on all versions of the Aero, I wonder?
If the half shaft has to be removed from the diff then it would make sense to do that when the LSD fluid has to be changed.
Something for November, I think, when the next service is due.
Tarka the 'Otter Mog
2014 Plus 8
Re: Rear ABS rings on S2 [Re: Alistair] #612175
12/01/20 11:47 AM
12/01/20 11:47 AM
Newcastle Upon Tyne
James B W Offline
James B W  Offline
Newcastle Upon Tyne
- just had these replaced on the little Smart car - like the BMW, it's a known problem.
Mine had a small crack in the ring.In normal use this was not a problem.
When the weather was freezing ,the water in the crack froze and expanded and threw up the ABS light.
New rings were cheap (about £20...) but the shafts had to be released ,all the rust/crud cleaned off and new rings slid into place.
I understand that the rings used to be interference fit and had to be heated before installing.Now they are just large enough to slide on and are then secured with a little Araldite or similar. innocent
Mercedes (Smart) want several hundred pounds for complete shafts and ABS rings..... swear
James
Range Rover Evoque S
Smart Brabus Convertible
Moderated by  Aeroman, Simon
