Morgan Aero 8
21 registered members (taffy, xc68anc, Gordon D, Island Mog, Snowden, BLUE+4, howard, MJF, docock, TBM, mph, M3W55, nippymog, Hawki, Morph, Gerhard, RJW, Richard Wood, ewn, Rovert, Dougie), 114 guests, and 22 spiders.
John V6 443
+8Rich 425
Hawki 174
Statues - worth a read
by recycled-teenager. 05/07/20 05:36 PM
Bought a couple of new Morgans..
by NickCW. 05/07/20 04:02 PM
Trivia
by nick w. 05/07/20 02:23 PM
Alternaive to Morgan..?
by Luddite. 05/07/20 11:40 AM
Immobiliser key fob code
by planenut. 05/07/20 10:31 AM
Ferrari Monaco recently
by ewn. 05/07/20 06:08 AM
Check this lass out - massive talent
by Bonesie. 05/07/20 05:38 AM
Lots of Bread
My new Plus Four
Back from professional washing and waxing
A trip to Essex
Illuminated Morgan wings homemade
Sharpm, Wil, LouStar, J Mck, Per Mattsson
7039 Registered Users
Topics38,713
Posts636,143
Members7,039
Most Online1,033
Dec 28th, 2019
No Birthdays
Rear ABS rings on S2 #612071
11/01/20 12:12 PM
11/01/20 12:12 PM
Hampshire
Alistair Online happy OP
Smile, it confuses them
Alistair  Online Happy OP
Hampshire
I was reminded by another PlusSix thread about a conversation during the last MoT and thought it might be worth sharing on the Aero thread.
I had been hearing what sounded like a ting-ting-ting noise from the back end which was road speed related. Not loud and sounding like metal clicking against metal. I wondered if it was something related to the handbrake as they are always an interesting optional extra !
During the last MoT the engineer pointed out that the ABS sensors on the back wheels use metal rings which are around the back of the hub/half-shaft. These are like a large toothed ring and have high/low islands which is what passes the sensor and generates the pulses the braincells read for road speed.
These rings can corrode, swell or warp over time. I was told they are from a 1Series BMW and this car is known for the same problem. It is not a huge problem swapping them however I think you do have to take the halfshaft out and take thm off in the direction of the diff not the wheel but I may have remembered that incorrectly.
If you have the car up in the air it is worth looking at the sensor rings on the back axle.
Just time to burn a little more petrol before dinner.
Re: Rear ABS rings on S2 [Re: Alistair] #612093
11/01/20 03:08 PM
11/01/20 03:08 PM
Salisbury, UK
Peter J Offline
Formerly known as Aldermog
Peter J  Offline
Salisbury, UK
Interesting: are they the same on all versions of the Aero, I wonder?
If the half shaft has to be removed from the diff then it would make sense to do that when the LSD fluid has to be changed.
Something for November, I think, when the next service is due.
Tarka the 'Otter Mog
2014 Plus 8
Re: Rear ABS rings on S2 [Re: Alistair] #612175
12/01/20 11:47 AM
12/01/20 11:47 AM
Newcastle Upon Tyne
James B W Offline
James B W  Offline
Newcastle Upon Tyne
- just had these replaced on the little Smart car - like the BMW, it's a known problem.
Mine had a small crack in the ring.In normal use this was not a problem.
When the weather was freezing ,the water in the crack froze and expanded and threw up the ABS light.
New rings were cheap (about £20...) but the shafts had to be released ,all the rust/crud cleaned off and new rings slid into place.
I understand that the rings used to be interference fit and had to be heated before installing.Now they are just large enough to slide on and are then secured with a little Araldite or similar. innocent
Mercedes (Smart) want several hundred pounds for complete shafts and ABS rings..... swear
James
Range Rover Evoque S
Smart Brabus Convertible
Moderated by  Aeroman, Simon
