11 registered members (Viper, BuyBritish, Treesurveyor, GRB, P Dron, John07, Arwyn Williams, NiddMog, yobtaf, Image, TBM), 157 guests, and 11 spiders.
+8Rich 328
John V6 258
TBM 166
Alistair 150
Hamwich 146
Plus Four Fiat numbers
by Mkiss. 22/09/20 09:16 PM
Front pictures as promised Ferrari TDF Plus 4
by jatinder dhesi. 22/09/20 08:20 PM
Webcon Retroject
by Gilles L.. 22/09/20 08:09 PM
1974 4/4 ...steering wheel
by thelastgizmo. 22/09/20 06:56 PM
Classic Motor Show
by PhilRoyle. 22/09/20 06:20 PM
Up, Up, and Away....
by Jon G4LJW. 22/09/20 05:08 PM
wait for it
Stonor breakfast club - Oxfordshire
Cotswold Classic Tour 19/9/20
Rattray and Troup 4/4 80th
A grand day out
Koopz, hashluck, KennyW, David Stepanis, Malroy
7166 Registered Users
Topics39,439
Posts650,920
Members7,166
Most Online1,033
Dec 28th, 2019
greenteagod
Bevel box oil leak #612343
13/01/20 10:13 PM
13/01/20 10:13 PM
Derby
lord-richfield Offline OP
Derby
My M3W has an oil leak from the bevel box input shaft seal. Just wondering if this is a known issue, or if anyone else has had similar ? M3W has done 600 miles from new. I'll try to upload some photos to the Morgan Photo Gallery. Any insights gratefully received !
2019 M3W
Re: Bevel box oil leak [Re: lord-richfield] #612347
13/01/20 10:22 PM
13/01/20 10:22 PM
Taffmog Offline
Taffmog  Offline
Sorry can’t help but it shouldn’t leak !
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
Re: Bevel box oil leak [Re: Taffmog] #612349
13/01/20 10:36 PM
13/01/20 10:36 PM
Derby
Derby
Thanks, that's what I was hoping for - the last thing I want to hear is 'they all do that', but wanted to check !
2019 M3W
Re: Bevel box oil leak [Re: lord-richfield] #612355
13/01/20 11:07 PM
13/01/20 11:07 PM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
This has happened to other M3W's but is not "normal" or acceptable. There should be 330 ml of oil in the bevel box, if it is overfilled this can cause leaks. If the input shaft seal needs replacing it can be done in situ, the big retaining nut is a LH thread and you will need to make a gag to hold the flange. Use a Viton seal with a higher temperature rate than the original failed one, size is 55x42x8mm R23 double lip but check dimensions as there are possibly two different sizes used. Mark the nut in relation to the shaft so you can refit to the same position and preload. It all worked well when I did it. Use some silicone sealant on the splines on assembly.
Re: Bevel box oil leak [Re: lord-richfield] #612357
13/01/20 11:15 PM
13/01/20 11:15 PM
Cheshire, UK
nippymog Offline
nippymog  Offline
Cheshire, UK
Happened to mine three times, twice under warranty then out of warranty when had a new oil seal fitted.
I dont overfill the box.
On this basis, I am expecting it to happen again - any chance of a detailed write up for the Bulletin please Ian?
Re: Bevel box oil leak [Re: lord-richfield] #612358
13/01/20 11:17 PM
13/01/20 11:17 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
Mine has no leaks at 1750 miles.
Stephen
2019 M3W piling on the Covid miles
Re: Bevel box oil leak [Re: lord-richfield] #612364
14/01/20 06:22 AM
14/01/20 06:22 AM
atalante83 Offline
atalante83  Offline
40000 miles without leak.
Re: Bevel box oil leak [Re: lord-richfield] #612371
14/01/20 07:38 AM
14/01/20 07:38 AM
Leicestershire, UK
Bunny Offline
Bunny  Offline
Leicestershire, UK
No jaw marks on the input shaft then Planenut? innocent
Andy
Re: Bevel box oil leak [Re: Bunny] #612398
14/01/20 11:29 AM
14/01/20 11:29 AM
planenut Offline
planenut  Offline
Only top quality engineering here laugh2. I will give it a go Nippy.
Re: Bevel box oil leak [Re: lord-richfield] #612480
14/01/20 09:37 PM
14/01/20 09:37 PM
Derby
Derby
Thanks for the info everyone, awaiting dealer response now.
2019 M3W
Moderated by  Aeroman
