2 registered members (Graham, G4FUJ, ChrisConvertible), 262 guests, and 34 spiders.
+8Rich 380
John V6 323
CooperMan 137
Alistair 123
Carry On Camping
by Clipper. 14/08/20 09:59 PM
M3W North Devon Day Trip
by chocadoodledoo. 14/08/20 05:47 PM
Mg midget and Morgans
by nick w. 14/08/20 03:07 PM
Rosie`s Pig
by PhilRoyle. 14/08/20 02:30 PM
Aero8 s4
by Simon m wright. 14/08/20 02:17 PM
Image posting
by Image. 14/08/20 01:37 PM
Changing colour of Mohair hood cover?
by PaulJ. 14/08/20 01:24 PM
Sunnier times ahead
riding through the montains
SNOWDONIA B4407/A543
GTN Soft top re-fitted
GTN Visors
Paul Johnson, Jim5961, Renat, StephanCarstens, Allthegearnoidea
7100 Registered Users
Topics39,080
Posts643,497
Members7,100
Most Online1,033
Dec 28th, 2019
Richard - Aus
Rear Drum brake nipples #612423
14/01/20 03:42 PM
14/01/20 03:42 PM
Crewe
Andy Penn Offline OP
Crewe
On my 1984 4/4 car I can only find one bleed nipple on one wheel (rear nearside), the other rear wheel doesn't seem to have a bleed nipple. Is this right??
Re: Rear Drum brake nipples [Re: Andy Penn] #612424
14/01/20 03:45 PM
14/01/20 03:45 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
It should have, but often they seize and get snapped off by a hamfisted hobbyist! They can be drilled out with care, or you can replace the rear brake cylinder fairly easily.
1972 4/4 4 seater
Too many ratty motorbikes
Re: Rear Drum brake nipples [Re: Andy Penn] #612425
14/01/20 03:45 PM
14/01/20 03:45 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
Does the rear brake pipe go into the offside cylinder then out and across to the nearside? That's the only way one bleed nipple would work.
Otherwise look closely at the offside, because it may have been sheared off.
2005 Corsa Red Roadster S1
2016 Saffron Yellow (Narrow) AR Plus 4
Re: Rear Drum brake nipples [Re: DaveW] #612434
14/01/20 04:02 PM
14/01/20 04:02 PM
Crewe
Crewe
Yes that's right, two pipes are going into the offside cylinder and then across to the nearside cylinder where there is a bleed nipple. I can't find any reference to there being only one bleed point for both wheels though??
Re: Rear Drum brake nipples [Re: Andy Penn] #612437
14/01/20 04:21 PM
14/01/20 04:21 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
It's unusual, but back in the mists of time I do remember this being used on some cars, but I don't know if that's normal for Morgans of that era.
It could be changed to a conventional T piece to each side.
Re: Rear Drum brake nipples [Re: Andy Penn] #612438
14/01/20 04:27 PM
14/01/20 04:27 PM
Leicestershire
TigerTim Offline
TigerTim  Offline
Leicestershire
That's the system on my 1980 Plus 8. One pipe form the front to the offside slave cylinder and then another across the axle to the near side where there IS a bleed nipple.
Re: Rear Drum brake nipples [Re: TigerTim] #612441
14/01/20 04:53 PM
14/01/20 04:53 PM
Powick
tmg513 Offline
tmg513  Offline
Powick
Same on my 1972 4/4.
1972 4/4 2 Seater
Re: Rear Drum brake nipples [Re: Andy Penn] #612445
14/01/20 05:11 PM
14/01/20 05:11 PM
Solihull
Spanner Juggler Offline
Solihull
Totally normal and very common back in the day. Not as good as a pipe and nipple to each in theory but in practice makes no difference when you think of the brake pipe run from the master cylinder to the rear axle it makes little if any difference to plumb the rear brakes in series rather than parallel. It was as a common thing with BL cars of the day (not that that’s an endorsement of sound engineering practice ;-)).
BR
Colin
BR Colin
Re: Rear Drum brake nipples [Re: Andy Penn] #612452
14/01/20 05:43 PM
14/01/20 05:43 PM
Salisbury, UK
Peter J Offline
Formerly known as Aldermog
Peter J  Offline
Salisbury, UK
I guess split braking systems ended this sort of plumbing. My Ford 107E had something like that.
Tarka the 'Otter Mog
2014 Plus 8
Re: Rear Drum brake nipples [Re: Andy Penn] #612454
14/01/20 06:05 PM
14/01/20 06:05 PM
Touraine, France
Toucan Offline
Toucan  Offline
Touraine, France
Same on mine!
Toucan 1981 4/4 Kent
Moderated by  Aeroman, Simon
