3 registered members (rossocorsa, 3Gs, RB1), 186 guests, and 13 spiders.
+8Rich 232
John V6 175
Peter J 128
Hamwich 121
How to properly launch the M3W
by Bluesman. 28/02/20 04:31 AM
Shifters to the fore!
by Bitsobrits. 28/02/20 12:48 AM
My 3 wheeler build started
by JohnMat. 27/02/20 11:15 PM
Fear & Greed
by IcePack. 27/02/20 10:32 PM
Seat base construction- 4/4
by thelastgizmo. 27/02/20 08:51 PM
Show us your GPS / Phone mount
by Landy. 27/02/20 08:03 PM
Little red roadster...just got it home
by thelastgizmo. 27/02/20 01:45 PM
Velsheda at Croabh
A day out at Ipswich docks
Garage art
near eccleston VA
FolkMog lunch
Tipracer, George Okuda, Alice, ahdguy, Colin725
6829 Registered Users
Topics37,345
Posts607,034
Members6,829
Most Online1,033
Dec 28th, 2019
No Birthdays
How often do you suffer a puncture? #612813
17/01/20 12:34 AM
17/01/20 12:34 AM
Madrid, Spain
Marmota Offline OP
Marmota  Offline OP
Madrid, Spain
I see from the threads related to the spares and tools to carry in the 3 wheeler, that many have inner tubes for the front tires, Slime or other tire repair kit and a small 12V compressor… confused2
In decades driving I’ve had only two flat tires!
Is the 3 wheeler really so prone to punctures?
Javier - Madrid, Spain - Commander of the Speedy Marmots Bomb Squadron
Re: How often do you suffer a puncture? [Re: Marmota] #612816
17/01/20 01:16 AM
17/01/20 01:16 AM
Taffmog Offline
Taffmog  Offline
Same here but I carry a spare tube for the front, as they are an unusual size and no tyre dealer will have them in stock, and a couple of those cartridges for the rear which I have always found to work well. I don’t bother with a compressor, perhaps I should...
‘Carry a couple of those cartridges in the tintops too. If you have a puncture you can guarantee it’s dark, wet etc.
If all else fails it’s a trip home on the back of a recovery truck! I don’t think the M3W is susceptible to punctures but I suppose the chance is greater as one wheel is in the middle.
Re: How often do you suffer a puncture? [Re: Marmota] #612820
17/01/20 05:33 AM
17/01/20 05:33 AM
atalante83 Offline
atalante83  Offline
Renforced tu be from cross bike
Re: How often do you suffer a puncture? [Re: Marmota] #612822
17/01/20 06:03 AM
17/01/20 06:03 AM
Austria, Vienna area
The Austrian Offline
I had a flat front tyre after two days of hillclimb activities.
One inner tube got damaged by the bottoms of the wire spokes and the second tube had already marks from spokes.
After replacing both tubes I fitted rim bands inside the front wheels and never had a problem again
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
Re: How often do you suffer a puncture? [Re: Marmota] #612824
17/01/20 06:49 AM
17/01/20 06:49 AM
M3W55 Offline
M3W55  Offline
I recommended a compressor more for checking and topping up pressure when covering significant mileage on tour than for puncture repair. The best mitigator for punctures is OKO sealant.
Re: How often do you suffer a puncture? [Re: Marmota] #612831
17/01/20 08:15 AM
17/01/20 08:15 AM
Oxon
PaulV Offline
PaulV  Offline
Oxon
Two. Likely due to spoke damage, repaired abroad - therefore not subject to root cause analysis wink
Keep 2 spare tubes and a foot pump smile as my battery is a Banner (annoyingly replaced by dealer as a Banner last Summer)...
Re: How often do you suffer a puncture? [Re: Marmota] #612846
17/01/20 12:05 PM
17/01/20 12:05 PM
Madrid, Spain
Marmota Offline OP
Marmota  Offline OP
Madrid, Spain
Well, apparently punctures are not a day-to-day business with the 3 wheeler. I was scared! So I believe I'll buy one inner tube just in case (as Taffmog says they nor usual, so better have one onboard) and carry a Slime or similar puncture cartridge just in case.
Does a small car jack makes sense, cosidering that I'll not be repairing / replacing a tire on the side of the road?
Re: How often do you suffer a puncture? [Re: Marmota] #612847
17/01/20 12:09 PM
17/01/20 12:09 PM
M3W55 Offline
M3W55  Offline
Put Slime/OKO into your rear tyre now. If the rear is punctured, they may help but you will probably need a recovery service as a roadside fix is very difficult.
Re: How often do you suffer a puncture? [Re: Marmota] #612849
17/01/20 12:15 PM
17/01/20 12:15 PM
West of Seattle, USA
LightSpeed Offline
LightSpeed  Offline
Have you ever tried getting the tire bead broken and used the spoons to just undo one side of the tire to allow you to replace a tube? Just as a test I bought some spoons, rim protectors and tried to do it when I was getting my front wheels powdercoated. What a pita. It would have taken many hands and maybe another set of spoons to do it. I gave up and took them to the local motorcycle shop to do it.
The older M3W were barrel backs and I believe for good reason. A spare tire on a luggage rack would be the easiest way to go.
Stephen
2019 M3W
Re: How often do you suffer a puncture? [Re: Marmota] #612852
17/01/20 12:43 PM
17/01/20 12:43 PM
Derby
PhilRoyle Offline
PhilRoyle  Offline
Derby
As I posted the other day on another thread - have a look at autoseal or Bikeseal - same thing. Can be used with or without tubes & does not gunk up the tyres. Immediately repairs tyres as the puncture happens(if in the tread area) and is a permanent fix.Look it up in your browser. I add that I`m not on commission. MSCC members get discount.
Moderated by  Aeroman
