2 registered members (AZJowett, Edwin), 135 guests, and 12 spiders.
+8Rich 525
John V6 445
TBM 179
Heinz 170
Stuck Indoors?
by Clipper. 30/03/20 09:07 PM
Bread in the USA
by +8Rich. 30/03/20 06:03 PM
4/4 4 seater car cover
by Tim W. 30/03/20 03:18 PM
Kop Hill Climb
by Ricardo. 30/03/20 12:57 PM
V10 Aero 8
by V10 Morgan aero. 30/03/20 09:56 AM
Car SOS
by James B W. 30/03/20 08:48 AM
Rural Virgina
Forrestburn track day
Updated-Bafflectomy Procedure
Suffolk in the sun
Ver.2 Morgans at Knockhill
Cuna2016, TonyRH, Kriado, MorganDriver, Andy Morris
6893 Registered Users
Topics37,667
Posts614,607
Members6,893
Most Online1,033
Dec 28th, 2019
PhilRoyle
Re: Trad Aerial fitting. [Re: NeilL] #512420
09/05/18 03:25 PM
09/05/18 03:25 PM
Arwyn Williams Offline
Any holes bigger than 3/8" (10mm) in sheet metal, I prefer to use a Q-Max hole cutter for a nice, clean, burr free hole.
Arwyn
Re: Trad Aerial fitting. [Re: NeilL] #512580
10/05/18 03:29 PM
10/05/18 03:29 PM
Perthshire & London
flyfisher Offline
flyfisher  Offline
Perthshire & London
Rather than drill holes in the body, has anyone found a Ariel that you can fit inside the car that works?
Re: Trad Aerial fitting. [Re: NeilL] #512585
10/05/18 04:00 PM
10/05/18 04:00 PM
Warks
NeilL Offline OP
NeilL  Offline OP
Warks
I did try that - and thought I had found the answer. But reception was very sporadic and not at all consisten - hence abandoning that idea and going conventional!
Neil
Re: Trad Aerial fitting. [Re: NeilL] #512592
10/05/18 04:33 PM
10/05/18 04:33 PM
Salisbury, UK
Peter J Offline
Formerly known as Aldermog
Peter J  Offline
Salisbury, UK
Neil,
I did the job on Aldermog...you are right, making the hole for the cable is a bit scary. I had all the inside trim off so it was easier.
The Morgan antenna is not very good.. I purchased a Hirschman one, 4 x the price and it seems 4 times as efficient at pulling in a signal!
Tarka the 'Otter Mog
2014 Plus 8
Re: Trad Aerial fitting. [Re: NeilL] #513017
14/05/18 08:51 AM
14/05/18 08:51 AM
Co Wexford, Ireland
Robbie Offline
Robbie  Offline
Co Wexford, Ireland
I drilled a pilot hole fo the ariel from the inside -- saves getting it wrong from the outside!!!! Remember to drill through a bit of masking tape if drilling the paint -stops the paint cracking around the hole
Cheers!
Robbie
2018 Plus4 - The Black Pearl
181-WX-3082
Re: Trad Aerial fitting. [Re: NeilL] #612804
16/01/20 11:26 PM
16/01/20 11:26 PM
Luddite Offline
Luddite  Offline
My old Mog had a radio fitted in it when I bought it, the radio is mounted on top of the gearbox tunnel, the speakers are mounted in the trim panels just below the hood frame swivel points on each side and I am very pleased that the aerial is not mounted through a hole drilled in the bodywork but mounted on a bracket fixed to the rear bumper. happy to take some pics if thought to be helpful.
Re: Trad Aerial fitting. [Re: NeilL] #612819
17/01/20 03:18 AM
17/01/20 03:18 AM
Manitoba, Canada
BertL Offline
BertL  Offline
Manitoba, Canada
thumbs "aerial is not mounted through a hole drilled in the bodywork but mounted on a bracket fixed to the rear bumper"
That was also my solution Luddite.... cheers
Bert & B1800
Re: Trad Aerial fitting. [Re: NeilL] #613355
21/01/20 10:36 AM
21/01/20 10:36 AM
haverfordwest
Nostalgiajohn Offline
haverfordwest
Neil, Am in the same boat as bought an aerial to fit and am new to Morgans!! Could you send some useful measurements from any reference point and maybe a photo to assist?
Thanks,
Re: Trad Aerial fitting. [Re: NeilL] #613507
22/01/20 08:59 AM
22/01/20 08:59 AM
East Harling, Norfolk UK
Richard Wood Offline
Unlikely a rear bumper mounted whip aerial would have an adequate ground plane to maximise received signal. It would probably work with the strongest radio signals, but so would a piece of wet string innocent
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Trad Aerial fitting. [Re: NeilL] #613581
22/01/20 04:49 PM
22/01/20 04:49 PM
Luddite Offline
Luddite  Offline
Richard I bow to your superior knowledge of the likely performance of my bumper mounted aerial when compared to wet string... Though in truth had no radio been fitted to my car when I bought it then I suspect I may not have fitted one. I also have to admit I have made use of the radio on a few occasions such as while working on the Mog and while waiting for my good lady to return from shopping etc, thus can confirm that it does indeed operate well enough, though the idea of drilling a largish hole in the bodywork in order to have areal or imagined improvement in radio performance would not have been considered a desirable option. I have no memory of ever trying to make use of the radio on the move, the sound of the old Mog providing quite enough pleasure (-:
Moderated by  Aeroman, Simon
