2 registered members (Bonesie, JohnMat), 198 guests, and 19 spiders.
+8Rich 232
John V6 175
Peter J 128
Hamwich 121
How to properly launch the M3W
by Bluesman. 28/02/20 04:31 AM
Shifters to the fore!
by Bitsobrits. 28/02/20 12:48 AM
My 3 wheeler build started
by JohnMat. 27/02/20 11:15 PM
Fear & Greed
by IcePack. 27/02/20 10:32 PM
Seat base construction- 4/4
by thelastgizmo. 27/02/20 08:51 PM
Show us your GPS / Phone mount
by Landy. 27/02/20 08:03 PM
Little red roadster...just got it home
by thelastgizmo. 27/02/20 01:45 PM
Velsheda at Croabh
A day out at Ipswich docks
Garage art
near eccleston VA
FolkMog lunch
Tipracer, George Okuda, Alice, ahdguy, Colin725
6829 Registered Users
Topics37,345
Posts607,035
Members6,829
Most Online1,033
Dec 28th, 2019
No Birthdays
New Chassis for a 2013 #612873
17/01/20 03:22 PM
17/01/20 03:22 PM
Barrythebrave Offline OP
Hi everyone,
I was having a little fun and the consequence is I need to have new chassis fitted. banghead
I'm not sure if I would still have to fit the bevel box mounting with the new chassis. I was going to have it fitted as a retro fit on the 2013 but will I still need it now?
Any other mods related to the chassis that might be worth doing while it's in bits?
Re: New Chassis for a 2013 [Re: Barrythebrave] #612888
17/01/20 05:01 PM
17/01/20 05:01 PM
atalante83 Offline
atalante83  Offline
Clutch perhaps
Re: New Chassis for a 2013 [Re: Barrythebrave] #612889
17/01/20 05:07 PM
17/01/20 05:07 PM
M3W55 Offline
M3W55  Offline
Unless you fit the kit yourself, Stage 1/2 upgrades are significantly cheaper because everything has to come off anyway. If I remember correctly, the factory waived the normal fitting cost when mine went in for a new chassis last year.
Re: New Chassis for a 2013 [Re: Barrythebrave] #612897
17/01/20 05:36 PM
17/01/20 05:36 PM
West Sussex, UK
Chris99 Offline
Chris99  Offline
West Sussex, UK
I assume this is as a result of your fun rather than cracks.
You will get the 2014/16 hybrid chassis which has the newer bevel box mount built in. It will also have the side mounting for the regulator.
The stage1/2 upgrades are air filter and exhaust so there's not that much saving in fitting them with the new chassis, but if you've not done them already then you should.
Whilst you have the engine out - If you have the Centa compensator then replace the rollers (approx. £30 for 4) and check the clutch.
Consider beefing up the fuel tank mounts and definitely carry out the Walbro mod to the fuel pump
Take the opportunity to dynamat or similar at least the rear bulkhead and transmission tunnel.
Maybe change things such as the rear gearbox mount, rear wheel bearings.
Good luck!
Red Leader drive
Re: New Chassis for a 2013 [Re: Barrythebrave] #612904
17/01/20 06:11 PM
17/01/20 06:11 PM
Cheshire, UK
nippymog Offline
nippymog  Offline
Cheshire, UK
Whats the rear gearbox mount mod you are recommending Chris?
Not heard of this one.
Re: New Chassis for a 2013 [Re: nippymog] #612914
17/01/20 07:36 PM
17/01/20 07:36 PM
Leicestershire, UK
Bunny Offline
Bunny  Offline
Leicestershire, UK
Just a standard gearbox mount Nippy.
They have been known to start de-laminating so probably worth replacing as a precaution.
Andy
Re: New Chassis for a 2013 [Re: Barrythebrave] #612924
17/01/20 08:50 PM
17/01/20 08:50 PM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
It's a Ford Cortina Mk1 item p/n 113E6068 or EM-429. It will require a bit trimming off one corner and maybe the mounting holes opening, you will see from the old one. They can go a bit soft, split or disbond.
Re: New Chassis for a 2013 [Re: Barrythebrave] #612925
17/01/20 09:03 PM
17/01/20 09:03 PM
Cheshire, UK
nippymog Offline
nippymog  Offline
Cheshire, UK
Thanks chaps, I will check it out.
Re: New Chassis for a 2013 [Re: Barrythebrave] #613123
19/01/20 11:59 AM
19/01/20 11:59 AM
Aberdeenshire
TimG Offline
TimG  Offline
Aberdeenshire
When my 2013 had a new chassis following cracks it got the NVH bevel box mount ( just ballast) & I had the centa compensator fitted & clutch checked. I just paid centa parts & MMC picked up labour cost.
Re: New Chassis for a 2013 [Re: Barrythebrave] #613189
20/01/20 05:53 AM
20/01/20 05:53 AM
atalante83 Offline
atalante83  Offline
Same for me
Moderated by  Aeroman
