0 registered members (),
139
guests, and 23
spiders. |
Topics40,614
Posts678,719
Members7,397
Most Online1,033 Dec 28th, 2019
Re: Mx5 Gearbox Oil Level
[Re: Lowflyer]
#612650
16/01/20 08:09 AM
16/01/20 08:09 AM
Posts: 754 North Somerset, UK
Deejay
North Somerset, UK
Jacked the passenger side of the car up today until my little spirit level placed on the "flange" (which is not absolutely flat, there's a casting "edge" on it) indicated that the box was level. There was a slight see saw action on the spirit level due to the aforementioned casting "edge" but it resulted in only half a bubble either side of the spirit level centre line and so was considered "level". I removed the fill plug, i had already ascertained that the oil level was upto the fill plug whilst the car was parked on leve ground. I topped up the gearbox oil whilst it was "level" (car jacked up) and was able to get 270ml additional fluid into the box at which point it overflowed. I've left it at that level. I originally put in 2 US quarts of Redline 75 90 equating to 1.892 litres when the car was on level ground. Gearbox capacity to filler plug leve would appear to be 2.162 litres or there abouts. Did you happen to measure how far it was jacked up to save using level in the future, as that may be useful for others. I struggled to find a suitable location for the level so merely increased height by 2 inches by driving onto a length of 7 x 2. That resulted in just an extra 150 ml going in. I note from your experience that you now have a little over the 2 litres that Mazda specify. I guess if it is a lot over, then seepage could occur through external shafts? worth keeping an eye on it especially when moving the car after a longer period of rest.
Doug
2011 +4 in Rich Maroon 1972 750 “ComDom” sprinter 1958 Triton 650 1992 Triumph Trophy 900
[Re: DaveW]
#612998
18/01/20 03:44 PM
18/01/20 03:44 PM
Posts: 1,943 Seattle, USA
Button
Seattle, USA
Ha Ha - I just bought a 2003 Mazda Miata yesterday. After reading this I thought I should check My new Miata. Went outside to check this morning? - I have an Automatic!!!!!!!!!
Button
[Re: Lowflyer]
#613003
18/01/20 04:21 PM
18/01/20 04:21 PM
Posts: 19,205 South Yorkshire
South Yorkshire
I thought about that afterwards and i didn't measure the amount of lift. I will do that imminantly. I did think about the internal oil level at the shaft seals but decided rightly or wrongly) that modern seals should withstand it. The gearbox will be canted around the input/output shaft alignment, so the oil level should not impact on the seals
DaveW 2005 Corsa Red Roadster S1 2016 Saffron Yellow (Narrow) AR Plus 4
[Re: DaveW]
#613092
19/01/20 09:05 AM
19/01/20 09:05 AM
Deejay
North Somerset, UK
BUT, if it were tilted over a bit TOO much allowing more than the recommended 2 litre volume to be filled, then surely the level could possibly be above the shafts. That’s why I was interested in exactly how high Lowflyer had raised it off the ground to get about 8% more in than recommended.
Doug
[Re: Deejay]
#613126
19/01/20 01:03 PM
19/01/20 01:03 PM
South Yorkshire
BUT, if it were tilted over a bit TOO much allowing more than the recommended 2 litre volume to be filled, then surely the level could possibly be above the shafts. That’s why I was interested in exactly how high Lowflyer had raised it off the ground to get about 8% more in than recommended. True. I should have added, providing the level plug is not above the horizontal...………….
