2 registered members (Bonesie, RB1), 182 guests, and 15 spiders.
+8Rich 232
John V6 175
Peter J 128
Hamwich 121
How to properly launch the M3W
by Bluesman. 28/02/20 04:31 AM
Shifters to the fore!
by Bitsobrits. 28/02/20 12:48 AM
My 3 wheeler build started
by JohnMat. 27/02/20 11:15 PM
Fear & Greed
by IcePack. 27/02/20 10:32 PM
Seat base construction- 4/4
by thelastgizmo. 27/02/20 08:51 PM
Show us your GPS / Phone mount
by Landy. 27/02/20 08:03 PM
Little red roadster...just got it home
by thelastgizmo. 27/02/20 01:45 PM
Velsheda at Croabh
A day out at Ipswich docks
Garage art
near eccleston VA
FolkMog lunch
Tipracer, George Okuda, Alice, ahdguy, Colin725
6829 Registered Users
Topics37,345
Posts607,035
Members6,829
Most Online1,033
Dec 28th, 2019
No Birthdays
Page 1 of 6 1 2 3 4 5 6
Drive Belt #613136
19/01/20 02:50 PM
19/01/20 02:50 PM
Leesburg, Virginia
2Sharp Offline OP
2Sharp  Offline OP
Leesburg, Virginia
I just installed the Bleazey bevel box kit and it was a bit of a choir but not too difficult. I certainly know my Morgan better though still scratching my head on the rear shocks and how difficult it is to get the lower shock tower bolt through the hole. It is very difficult for me to get the bottom bolt into the shocks as the swing arm does not lower enough at least on my Morgan.
On the drive belt I don't know how many people check their belt but my was surprising slack before the install and would move 1 1/2" and was rubbing the swing arm a little. Easy enough to fix and I guess I should have paid more attention to it. For the belt itself it seems to stay all the way on the left side/drivers side. I adjusted it some and it stayed there so figured this is where it is meant to be. Is that where the belt is suppose to reside? My recollection for motorcycles they always want the belts to run on the right side closer to the wheel though the Morgan and a motorcycle are very different animals so it makes sense for the belt to run where it is as there is not a ring on the inside of the front pulley.
Another item I found interesting is how much drag there is to spin the wheel. Maybe because when you turn the wheel you are spinning the wheel, belt, bevel box and drive shaft. Doesn't take extreme force or anything just a fair amount of drag.
2017 M3W Sport Green
Re: Drive Belt [Re: 2Sharp] #613177
20/01/20 12:10 AM
20/01/20 12:10 AM
New River Valley, VA
rcmatt Offline
rcmatt  Offline
I found my belt was way top slack when arrived from the dealer.... and would cause incredibles noises on deceleration
Rodger
2004 Plus 8 (wife's)
Re: Drive Belt [Re: 2Sharp] #613245
20/01/20 01:01 PM
20/01/20 01:01 PM
West Sussex, UK
Chris99 Offline
Chris99  Offline
West Sussex, UK
The drivebelt runs quite tight.
As a rule of thumb, you should be able to twist the lower section of the drivebelt about 45 - 90 degrees.
Red Leader drive
Re: Drive Belt [Re: 2Sharp] #613297
20/01/20 06:13 PM
20/01/20 06:13 PM
Leesburg, Virginia
2Sharp Offline OP
2Sharp  Offline OP
Leesburg, Virginia
Thanks Chris. I used a belt tension gauge with 10lbs yielding <1/2 inch deflection of the belt. The gauges are $15 so worth the investment as the belt is hard to twist or judge how much pressure to twist.
It is very hard to figure out if the back wheel is aligned since there is not any measuring points and even if there were I doubt they would be exact.
My belt is running to the drivers side of the front bevel box pulley which from the pictures I have seen they all seem to be on that side.
Re: Drive Belt [Re: 2Sharp] #613327
20/01/20 11:14 PM
20/01/20 11:14 PM
West of Seattle, USA
LightSpeed Offline
LightSpeed  Offline
This is where mine runs.
Stephen
2019 M3W
Re: Drive Belt [Re: 2Sharp] #613331
21/01/20 12:53 AM
21/01/20 12:53 AM
Leesburg, Virginia
2Sharp Offline OP
2Sharp  Offline OP
Leesburg, Virginia
Wow that is centered like a work of art. From the pictures I could find all the belts were all on the ring. Personally if the belt is tight to the ring you have no idea how much it is pushing on the ring.
Re: Drive Belt [Re: 2Sharp] #613332
21/01/20 12:55 AM
21/01/20 12:55 AM
Leesburg, Virginia
2Sharp Offline OP
2Sharp  Offline OP
Leesburg, Virginia
You have a picture you can share that shows the room you have between the swing arm on the drivers side and the bevel box ring? Appreciate the help.
Re: Drive Belt [Re: 2Sharp] #613335
21/01/20 02:20 AM
21/01/20 02:20 AM
LightSpeed Offline
LightSpeed  Offline
That is the extent of my photos of the belt. Might not be what you are looking for but the next time I take out the boot liner I will document more.
Stephen
2019 M3W
Re: Drive Belt [Re: 2Sharp] #613336
21/01/20 03:27 AM
21/01/20 03:27 AM
Leesburg, Virginia
2Sharp Offline OP
2Sharp  Offline OP
Leesburg, Virginia
Awesome thank you!
Re: Drive Belt [Re: 2Sharp] #613340
21/01/20 07:40 AM
21/01/20 07:40 AM
Gods own county! Oop north
Dab of oppo Offline
Dab of oppo  Offline
This is mine in motion.
https://youtu.be/ZKTt3i1cmQg
Moderated by  Aeroman
