6 registered members (PaulJ, Rainer Duell, DJC, DaveW, Stewart S, Elcyd), 195 guests, and 19 spiders.
+8Rich 232
John V6 175
Peter J 128
Hamwich 122
How to properly launch the M3W
by Bluesman. 28/02/20 04:31 AM
Shifters to the fore!
by Bitsobrits. 28/02/20 12:48 AM
My 3 wheeler build started
by JohnMat. 27/02/20 11:15 PM
Fear & Greed
by IcePack. 27/02/20 10:32 PM
Seat base construction- 4/4
by thelastgizmo. 27/02/20 08:51 PM
Show us your GPS / Phone mount
by Landy. 27/02/20 08:03 PM
Little red roadster...just got it home
by thelastgizmo. 27/02/20 01:45 PM
Velsheda at Croabh
A day out at Ipswich docks
Garage art
near eccleston VA
FolkMog lunch
Tipracer, George Okuda, Alice, ahdguy, Colin725
6829 Registered Users
Topics37,345
Posts607,040
Members6,829
Most Online1,033
Dec 28th, 2019
No Birthdays
Grease is the word #613407
21/01/20 03:58 PM
21/01/20 03:58 PM
West Yorkshire
Fat Wolfie Offline OP
West Yorkshire
A bit of a daft question on grease for the kingpins...
So far I’ve been using Castrol LM grease, it’s what I had and seemed to be ok for the application.
But I’ve now run out of it so have ordered on line some Silkolene RG2 red lithium grease.
There is still some (maybe a third) of the reservoir on the Wanner grease gun that’s still got LM in it.
The question is- Can I just top up the gun with the Silkolene, and of course have a mix of grease types in the kingpins, or do I need to use up all the LM first and then just charge the gun up with the RG2? I’m guessing it will be fine but I read somewhere about “purging the old grease out if you change the grease type” . I’m not sure if this is sound advice, a theoretical ideal that nobody does, or just someone on another forum who actually knows nothing.
Personally I think it would be a theoretical idea but mixing won’t cause any problems in reality..
Thoughts from the learned collective awaited please!
Re: Grease is the word [Re: Fat Wolfie] #613439
21/01/20 06:39 PM
21/01/20 06:39 PM
Cornwall
griffo Offline
griffo  Offline
Cornwall
You might be over thinking this. I would opt for any grease rich in molybdenum disulfide.
Re: Grease is the word [Re: Fat Wolfie] #613440
21/01/20 06:41 PM
21/01/20 06:41 PM
Huntingdon
Scrambledsignals Offline
Huntingdon
Mixing grease in a low temperature environment like the King Pins should not be a problem.
If it was going in to wheel bearings I think I would clean out as much as I could but would not bother on the King Pins.
Re: Grease is the word [Re: Fat Wolfie] #613449
21/01/20 07:09 PM
21/01/20 07:09 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
I cant see an issue if they are similar products.
2006 Indigo Blue Roadster S1
Re: Grease is the word [Re: Fat Wolfie] #613455
21/01/20 07:18 PM
21/01/20 07:18 PM
Staffordshire
IvorMog Offline
IvorMog  Offline
Staffordshire
I switched from multipurpose lithium based grease to lithium moly about a year ago with no ill effects.
Both lithium based so they will mix ok.
Not sure whether your Silkolene is Lithium based.
I did remove most of the old grease from the gun but wasn't too fussy with it and certainly didn't clean the old grease out of the stub axles.
I'd be very surprised if you had a problem.
Bob
1999 4/4 2 litre Zetec
Re: Grease is the word [Re: Fat Wolfie] #613478
21/01/20 09:46 PM
21/01/20 09:46 PM
SteveT Offline
SteveT  Offline
I doubt if mixing greases will cause any issues at all. I've mixed grease with some 90 gear oil in the past and its a better lube if you can get it to stay in the right places.
I'm using red 'n' tacky at the moment.. seems good stuff and they do a green version for hubs. Much better in my view than LM.
110th +4 AM Chiltern Green
1939 Cammy Velo
1959 BSA GS DBD34
LR 90 SW
Fellow of the Wild Mogs
Re: Grease is the word [Re: Fat Wolfie] #613490
22/01/20 12:53 AM
22/01/20 12:53 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
I use red and tacky.
Re: Grease is the word [Re: Fat Wolfie] #613526
22/01/20 10:09 AM
22/01/20 10:09 AM
West Yorkshire
West Yorkshire
Thanks for all the replies.
I’ll just top up the grease gun and crack on, as Griffo says, been over thinking this one smile
And while typing this, postie has arrived with said grease. Only ordered it yesterday through the Bay of E..
Re: Grease is the word [Re: Fat Wolfie] #613593
22/01/20 05:42 PM
22/01/20 05:42 PM
Dorset
Jads Offline
Jads  Offline
Dorset
Grease is not just grease, in my opinion get some XG 279, Fuchs do it. It is used by the FAA for high wear applications on the Helicopters I've flown for thousands of hours, and the Pongoes use it on their artillery pieces ! Sorry, if you've not been in the military, you won't understand the banter. Cheers.
Re: Grease is the word [Re: Fat Wolfie] #613594
22/01/20 05:44 PM
22/01/20 05:44 PM
Dorset
Jads Offline
Jads  Offline
Dorset
Although Spanner Juggler might as he mentioned the 'Tyre Bay' in a different thread ???
Moderated by  Aeroman, Simon
