5 registered members (brownbaker, M3W55, Heinz, Stewart S, ChrisConvertible), 191 guests, and 17 spiders.
+8Rich 232
John V6 175
Peter J 128
Hamwich 122
How to properly launch the M3W
by Bluesman. 28/02/20 04:31 AM
Shifters to the fore!
by Bitsobrits. 28/02/20 12:48 AM
My 3 wheeler build started
by JohnMat. 27/02/20 11:15 PM
Fear & Greed
by IcePack. 27/02/20 10:32 PM
Seat base construction- 4/4
by thelastgizmo. 27/02/20 08:51 PM
Show us your GPS / Phone mount
by Landy. 27/02/20 08:03 PM
Little red roadster...just got it home
by thelastgizmo. 27/02/20 01:45 PM
Velsheda at Croabh
A day out at Ipswich docks
Garage art
near eccleston VA
FolkMog lunch
Tipracer, George Okuda, Alice, ahdguy, Colin725
6829 Registered Users
Topics37,345
Posts607,040
Members6,829
Most Online1,033
Dec 28th, 2019
No Birthdays
Bonnet Stays & Qtr Panel Protectors #613698
23/01/20 03:33 PM
23/01/20 03:33 PM
haverfordwest
Nostalgiajohn Offline OP
haverfordwest
Hi all, Have just ordered from "Williams", the Wolf Bonnet Stays and the stainless Quarter Panel Protectors, If anyone has fitted these to their Mog and can profer advice it will be more than welcome!!!
My first Morgan, after Porsches and Jaguar so on a steep learning curve but it makes me smile everytime I look at it.
Re: Bonnet Stays & Qtr Panel Protectors [Re: Nostalgiajohn] #613712
23/01/20 04:52 PM
23/01/20 04:52 PM
Thatcham
Tresco Offline
Tresco  Offline
Thatcham
The Wolf bonnet stays are easy to fit, had them on our last Morgan and have taken them off and installed on our new Morgan in December. Don't know about the panel protectors.
Ian
2019 +4 110 Anniversary Bentley Velvet Red.
Re: Bonnet Stays & Qtr Panel Protectors [Re: Nostalgiajohn] #613717
23/01/20 05:19 PM
23/01/20 05:19 PM
Solihull
Spanner Juggler Offline
Solihull
Don’t know if your aware but check out top right corner of screen and you should see a flashing red envelope. It’s because I replied to a question you asked and sent you a private message. Just click on it ;-)
It took me a week and a Graham telling me what it was so been there and own the shirt ;-)
BR
Colin
BR Colin
Re: Bonnet Stays & Qtr Panel Protectors [Re: Nostalgiajohn] #613719
23/01/20 05:24 PM
23/01/20 05:24 PM
Huntingdon
Scrambledsignals Offline
Huntingdon
Panel protectors work well, pretty easy to fit but you might need some slightly longer stainless steel screws to fit in to the existing holes.
From memory 3 screws go into existing holes and 2 go into new holes. Use a small drill to make a pilot hole and you will not crease the leather.
Took me less than an hour to fit mine.
Re: Bonnet Stays & Qtr Panel Protectors [Re: Tresco] #613721
23/01/20 05:38 PM
23/01/20 05:38 PM
Gloucestershire, UK
Hamwich Offline
Hamwich  Offline
Gloucestershire, UK
Unless, that is, you have bought a set of the stainless steel bonnet catch brackets from Heart of England. The brackets are beautifully made, finely crafted from a steel that is indubitably shiny and stainless, but which also has the property of being harder than a very hard thing that's been through a special additional hardening process.
You're supposed to drill the brackets to install the lower mounting of the prop, but even my sooper-dooper tungsten drills in a beefy drill press couldn't touch them, so I had to make up a couple of additional brackets that utilised the existing mounting holes. Not exactly a difficult task, but worth bearing in mind.
1986 4/4 VVTi Sport, 2002 LR Defender, 1957 R4 CV, 2005 Ferrari Vipar
Re: Bonnet Stays & Qtr Panel Protectors [Re: Nostalgiajohn] #613730
23/01/20 07:29 PM
23/01/20 07:29 PM
SteveT Offline
SteveT  Offline
The screws that came with the protectors were 'orrible and the heads the wrong shape. I had to deepen the countersunk bit in the protectors with er..a bit and found some nicer stainless screws.
Worth easing the threads with a little wax, tallow or soap, its kinder to the ash.
110th +4 AM Chiltern Green
1939 Cammy Velo
1959 BSA GS DBD34
LR 90 SW
Fellow of the Wild Mogs
Re: Bonnet Stays & Qtr Panel Protectors [Re: Nostalgiajohn] #613739
23/01/20 08:44 PM
23/01/20 08:44 PM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
You may find that the quarter panel protectors are not quite a “glove fit” round the curvature, so do a dry fit to get best compromise before driving any screws home. They are not easy to bend!
Doug
2011 +4 in Rich Maroon
Re: Bonnet Stays & Qtr Panel Protectors [Re: Nostalgiajohn] #613740
23/01/20 08:45 PM
23/01/20 08:45 PM
Angus, UK
Bervie1 Offline
Bervie1  Offline
Angus, UK
When I fitted the quarter panel protectors I found I had to do a little profiling with soft hammer to get them close into the panels also had a job getting the screws flush and would agree the countersinking could be a little deeper.
Re: Bonnet Stays & Qtr Panel Protectors [Re: Nostalgiajohn] #613744
23/01/20 09:17 PM
23/01/20 09:17 PM
Bergen, Norway
Robbie Mathisen Offline
Bergen, Norway
When you drill the bonnet catch brackets, you produce a lot of metal grain (is "chaff" what you call it?) that will scratch the paintwork when you try to buff it off. So cover up the wing as much as you can, only to let the catch iself poke out. Some of the metal grain from the drilling will still find it's way down to the paint. And here is the trick: DO NOT try to buff it away, scoop it up with a magnet without touching the bodywork!
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Re: Bonnet Stays & Qtr Panel Protectors [Re: Robbie Mathisen] #613746
23/01/20 09:40 PM
23/01/20 09:40 PM
Gloucestershire, UK
Hamwich Offline
Hamwich  Offline
Gloucestershire, UK
Good advice Robbie. We call it 'swarf' by the way.
Moderated by  Aeroman, Simon
