14 registered members (Quicksilver, Gordon D, John V6, Rob82, Jon G4LJW, Richard M Sharpe, SFG, Peter J, John07, Spanner Juggler, LightSpeed, Budster, Alistair, madmax), 211 guests, and 13 spiders.
+8Rich 240
John V6 146
Hamwich 128
Image 121
Wanted M3W
by Gambalunga. 23/02/20 11:07 PM
Driveline Information
by Rob82. 23/02/20 09:51 PM
Fog stirrer
by nick w. 23/02/20 09:42 PM
Roadster ground clearance
by Richard Wood. 23/02/20 08:00 PM
Copy of warrentee
by Bluesman. 23/02/20 07:57 PM
Starter Motor - which one
by DaveK. 23/02/20 06:32 PM
Inner track rod end - bush O/D
by teknome. 23/02/20 05:09 PM
Garage art
near eccleston VA
FolkMog lunch
well..
Today at Krazy Horse
Tipracer, George Okuda, Alice, ahdguy, Colin725
6829 Registered Users
Topics37,315
Posts606,384
Members6,829
Most Online1,033
Dec 28th, 2019
No Birthdays
bie Oscar fitting with Over Riders? #617078
13/02/20 02:16 PM
13/02/20 02:16 PM
haverfordwest
Nostalgiajohn Offline OP
haverfordwest
Has anyone installed a pair of Cibie Oscars on their Mog (Fitted with Over Riders)? If so where did you get suitable mounting brackets as Librands only do them for their 5" & 6" spots.
John 2011 Plus 4
Re: bie Oscar fitting with Over Riders? [Re: Nostalgiajohn] #617149
13/02/20 08:52 PM
13/02/20 08:52 PM
Taffmog Offline
Taffmog  Offline
I’ve got Oscars on mine using the Factory/Librands Wipac brackets but I don’t have overiders though. Work ok and no shake.
I can’t see that overiders would make a difference? 🤔
Re: bie Oscar fitting with Over Riders? [Re: Nostalgiajohn] #617180
14/02/20 06:58 AM
14/02/20 06:58 AM
Bergen, Norway
Robbie Mathisen Offline
Bergen, Norway
I am sure the brackets mentioned above would work. However, if you retain the overriders, there is not much space left for the Oscars between the headlamps, grill and overriders. I suggest you take a disc 7" wide (made out of cardbord, a dinner plate or whatever) hold it in the desired position of the Oscar and see what you think. Now Brands Hatch makes a badge bar that is wider so it almost touches the overriders, and Stafford Vehicle Components makes a nice bracket that fixes a spot to the bar. This might be a solution, and you don't have to drill the wing. Still, for my taste an Oscar is a bit too large for a Morgan, and moreso with retained overriders. For the moment I have discarded the spot idea, but if I take it up again I will investigate the Brands Hatch/Stafford path, most likely with 5 3/4" Lucas 576 or even something smaller. This is if looks is what you are after. If functionality - i.e. better lightning at all times is your priority, I would suggest changing the OE (Lucas or Wipac?) headlamp insert to Cibie 180 (Librands has them) with better optics, and/or putting in a H4 LED bulb. Tremendous light, but it might give you a MOT problem - don't know the UK regulations. If so, this of course could be overcome with a discrete back-and-forth change of bulbs in connection with the MOT....
Robbie the Norseman
2004 V6 Roadster
Sherwood green
Re: bie Oscar fitting with Over Riders? [Re: Nostalgiajohn] #618736
23/02/20 11:28 PM
23/02/20 11:28 PM
Nth. Bucks, England
minikeefy Offline
minikeefy  Offline
Nth. Bucks, England
Here is a thread on what I made for my car. These allowed me to fit the smaller Cibie Tango lights but work very well. I can forward a drawing of the template if you PM me.
http://www.talkmorgan.com/ubbthreads.php/topics/72823/1
Keith
Moderated by  Aeroman, Simon
