19 registered members (Gambalunga, 240d, RJW, jrt, AndyrIch, Gordon D, M3W55, Image, BLUE+4, ChrisConvertible, Uther, AAJ, tmg513, Phil+8, Spanner Juggler, Luddite, RedThree, mise303, Jon G4LJW), 132 guests, and 14 spiders.
+8Rich 325
John V6 254
TBM 180
Alistair 151
Hamwich 146
Help needed
by Gambalunga. 24/09/20 11:36 AM
3.7 Roadster turn signal noise.
by John V6. 24/09/20 11:09 AM
Local dialect
by Gordon D. 24/09/20 10:23 AM
Inside the Spitfire Factory
by Ian Wegg. 23/09/20 08:45 PM
Inside the spitfire factory
by IMHO. 23/09/20 08:06 PM
Wots Your Grammer Like?
by Clipper. 23/09/20 07:58 PM
Creaking kingpins
by Grumpy2. 23/09/20 07:10 PM
wait for it
Stonor breakfast club - Oxfordshire
Cotswold Classic Tour 19/9/20
Rattray and Troup 4/4 80th
A grand day out
Koopz, hashluck, KennyW, David Stepanis, Malroy
7166 Registered Users
Topics39,449
Posts651,133
Members7,166
Most Online1,033
Dec 28th, 2019
No Birthdays
M3W electrical gremlin #617108
13/02/20 04:40 PM
13/02/20 04:40 PM
Ben Sures Offline OP
My M3W has decided to have an electrical gremlin. The running lights and dash lights seem to be throttle dependent and flicker non stop when throttle is applied, the more it rattles the more it flickers. I'm safely assuming there's a loose wire, but I'll be darned if I can find it and don't know where to look. I've been through the fuse box and made sure everything is snug, but have not been able to source the problem. Any help is appreciated.
Re: M3W electrical gremlin [Re: Ben Sures] #617110
13/02/20 04:56 PM
13/02/20 04:56 PM
SW Iowa, U.S.A.
Bitsobrits Offline
Bitsobrits  Offline
SW Iowa, U.S.A.
I would start with checking the battery voltage when running. See if it varies with RPM.
As for wiring, check the main grounding points for the battery (back of battery tray) as well as those in front of the oil tank. The back of battery tray grounding via a recessed head screw is a really poor decision on the part of MMC, IMHO. They really should have provided a welded to chassis stud for this purpose. One should probably remove the screw and clean the contact points annually to prevent issues.
2012 M3W
Uncracked chassis, still!
Re: M3W electrical gremlin [Re: Ben Sures] #617113
13/02/20 05:13 PM
13/02/20 05:13 PM
New River Valley, VA
rcmatt Offline
rcmatt  Offline
I agree, often it is the grounding that is the cause of such gremlins. Never hurts to clean all connections as well.
Rodger
2004 Plus 8 (wife's)
Re: M3W electrical gremlin [Re: Ben Sures] #617182
14/02/20 07:48 AM
14/02/20 07:48 AM
Paris (France)
Chocodent Offline
Chocodent  Offline
Paris (France)
Thank you guys for your quick and educated answers. You're real gentlemens and and I wanted to see it in black and white smile
Morgan 3 Wheeler Mandarine & Black interior
Moderated by  Aeroman
