10 registered members (TimG, MOGSWE, bilibib, bmgermany, M3W55, SCX358G, Aeromax51, brownbaker, mphcarpaintings, Alan Patterson), 71 guests, and 12 spiders.
+8Rich 558
John V6 463
TBM 188
Visors or NO visors
by SeaTacTom. 04/04/20 02:26 AM
Sweet dreams.
by Gambalunga. 03/04/20 09:22 PM
Racing Plus 4 Video
by rid967. 03/04/20 07:47 PM
It's Doom Bar time yipee
by +8Rich. 03/04/20 06:26 PM
COWL MASCOT ?
by KEVFITZ. 03/04/20 04:37 PM
Help Needed with a Roadster!
by Aeroman. 03/04/20 04:37 PM
Eurotunnel Tip
by CooperMan. 03/04/20 04:28 PM
V10 MORGAN
Spike Milligan
Rural Virgina
Forrestburn track day
Updated-Bafflectomy Procedure
Cuna2016, TonyRH, Kriado, MorganDriver, Andy Morris
6893 Registered Users
Topics37,708
Posts615,583
Members6,893
Most Online1,033
Dec 28th, 2019
mmueller.gl, pheasant
Starter Motor - which one #618665
23/02/20 06:32 PM
23/02/20 06:32 PM
Salisbury, England
DaveK Offline OP
DaveK  Offline OP
Salisbury, England
I'm going to start putting the MOG back together and my thinking has turned to my starter motor. The MOG is fitted with a Crossflow engine. It currently has a classic
'Bendix ' style starter motor with a separate starter solenoid. The problem with this is that it is bolted onto the bulkhead. Can I fit a 'Actuated' which has the solenoid built onto thar the starter motor. Is it possible to get a updated starter? If yes does anyone out in Talk Morgan world know which one?
Navy Dave
1976 Morgan 4/4
Re: Starter Motor - which one [Re: DaveK] #618668
23/02/20 06:46 PM
23/02/20 06:46 PM
Arwyn Williams Offline
I've recently changed the starter motor from inertia to pre engagedon my 1971 4/4 following a 5 speed gearbox conversion.
The ring gear on my inertia starter ring gear (105 teeth) was pretty chewed up plus the face was a bit scored.
In my spares pile I had a late Crossflow flywheel of the right weight but with a 135 teeth pre engaged ring gear.
I was able to get an upgraded Sierra/Capri pre engaged starter motor for less than £80 quid from AAP in Oldham
I left the solenoid on the bulkhead and ran a wire from the starter motor feed to the starter motor solenoid with absolutely no problems!
Drop us a PM and I'll send a couple of photos to explain!
Arwyn
Re: Starter Motor - which one [Re: DaveK] #618670
23/02/20 07:08 PM
23/02/20 07:08 PM
East Harling, Norfolk UK
Richard Wood Offline
If changing over to pre-engaged piggy back solenoid style starter it's far better to remove the old remote solenoid if only electrically. If you don't you have an extra unnecessary link in the high current chain, increasing unreliability from extra connections and undoubtedly causing a volt drop of some degree.
When adding cable for solenoid trigger ensure its around 5-6mm2, as the solenoid alone takes around 30 amps.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Starter Motor - which one [Re: DaveK] #618671
23/02/20 07:12 PM
23/02/20 07:12 PM
Luddite Offline
Luddite  Offline
Been a long time since I messed with an old style starter, though the bendix engages from the gearbox side of the ring gear which as best as I can I remember the teeth had chamfered edges to match a similar chamfer on the bendix. Changing to a pre-engage starter would perhaps equate to the starter dog meeting square edged teeth and thus perhaps inducing a bit of wear...?
Re: Starter Motor - which one [Re: Luddite] #618675
23/02/20 07:29 PM
23/02/20 07:29 PM
I don't think its possible to run a standard Ford pattern pre engaged starter motor on an inertia ring gear.
My bad - a standard Ford crossflow ring gear with an inertia starter has 110 teeth, pre engaged types have either 132 or 135 teeth.
At best the damage will be to the starter motor pinion, at worst to the ring gear, which means an engine out job to change
I doubt the solenoid on my new starter motor draws as much as 30 amp. I know, I checked when I span the engine over on the starter to get the oil pressure up prior to start up. The body of the motor got slightly warm but the solenoid trigger cable was unaffected.
Not too sure about the WOSP type starters!
Arwyn
Re: Starter Motor - which one [Re: DaveK] #618688
23/02/20 08:19 PM
23/02/20 08:19 PM
Northants, UK
TBM Online NoMood
TBM  Online NoMood
Northants, UK
This will do the job, but at a price....
Powerlite Starter
1972 4/4 4 seater
Too many ratty motorbikes
Re: Starter Motor - which one [Re: DaveK] #618689
23/02/20 08:27 PM
23/02/20 08:27 PM
Powick
tmg513 Offline
tmg513  Offline
Powick
https://www.burtonpower.com/parts-b...ation/starter-motors.html?appl_engine=17
I fitted a Burtonpower item about a dozen years ago.
1972 4/4 2 Seater
Re: Starter Motor - which one [Re: Arwyn Williams] #618702
23/02/20 09:18 PM
23/02/20 09:18 PM
Arwyn
The piggy back solenoid has in fact two coils. One to engage starter pinion against return spring and a second to hold the engagement whilst maintaining current to starter motor itself. I just wanted to make clear that the current required by the solenoid is not insignificant and benefits from having a heavier than elsewhere gauge cable.
Regarding the loop from main starter feed to trigger, whilst this works it's bad practice for reasons given. My Land Rover when converted to diesel by a previous owner had similar mod, now corrected.
Moderated by  Aeroman, Simon
