5 registered members (kankeL, P964, Graham, G4FUJ, teifistar, rockabilly john), 61 guests, and 17 spiders.
+8Rich 558
John V6 463
TBM 187
Visors or NO visors
by SeaTacTom. 04/04/20 02:26 AM
Sweet dreams.
by Gambalunga. 03/04/20 09:22 PM
Racing Plus 4 Video
by rid967. 03/04/20 07:47 PM
It's Doom Bar time yipee
by +8Rich. 03/04/20 06:26 PM
COWL MASCOT ?
by KEVFITZ. 03/04/20 04:37 PM
Help Needed with a Roadster!
by Aeroman. 03/04/20 04:37 PM
Eurotunnel Tip
by CooperMan. 03/04/20 04:28 PM
V10 MORGAN
Spike Milligan
Rural Virgina
Forrestburn track day
Updated-Bafflectomy Procedure
Cuna2016, TonyRH, Kriado, MorganDriver, Andy Morris
6893 Registered Users
Topics37,708
Posts615,577
Members6,893
Most Online1,033
Dec 28th, 2019
mmueller.gl, pheasant
How to properly launch the M3W #619437
28/02/20 04:31 AM
28/02/20 04:31 AM
Massachusetts & New Hampshire ...
Bluesman Offline OP
Bluesman  Offline OP
As a newbie owner, I wonder if some seasoned folks could chime in on how to best clutch and rev the M3W from a standing start.
I assume I don't want to lug the engine when launching in 1st gear so as to not strain the Compensator and also to not lug an engine typically used to power an 800 lb motorcycle. Lugging is never good, but over revving can "smoke" the clutch.
I am wondering what approximate rpm you folks typically launch at in 1st gear?
How are the clutches in these machines? Are they strong enough so that higher rev launches are not an issue? Have many folks had to replace clutches at low mileage?
Probably over thinking it, but thought I would ask....
2019 M3W Black
Previous: 1985 Plus 8
Re: How to properly launch the M3W [Re: Bluesman] #619438
28/02/20 04:39 AM
28/02/20 04:39 AM
West of Seattle, USA
LightSpeed Offline
LightSpeed  Offline
To high an rpm launch can easily result in a smoking rear tire😊
Stephen
2019 M3W
Re: How to properly launch the M3W [Re: Bluesman] #619448
28/02/20 07:58 AM
28/02/20 07:58 AM
Hertfordshire
O
Obie Offline
Obie  Offline
O
Hertfordshire
I have timed a few 0-60 and it’s not an easy thing to 🚀 it’s a balance between smoking the clutch or the rear tyre.
Going by how delicate these things are I would say don’t over do it!
Re: How to properly launch the M3W [Re: Bluesman] #619526
28/02/20 12:27 PM
28/02/20 12:27 PM
Bluesman Offline OP
Bluesman  Offline OP
I am just talking about normal everyday driving
2019 M3W Black
Re: How to properly launch the M3W [Re: Bluesman] #619532
28/02/20 12:49 PM
28/02/20 12:49 PM
Leicestershire, UK
Bunny Offline
Bunny  Offline
Leicestershire, UK
There is quite a variation between individual cars, depending on how much play there is in the drivetrain, centa slop, drive belt tightness etc, etc. Therefore, there isn't any one answer to your question. Just treat it with respect and find out what works for your car.
Andy
Re: How to properly launch the M3W [Re: Bluesman] #619631
29/02/20 03:45 AM
29/02/20 03:45 AM
Bluesman Offline OP
Bluesman  Offline OP
So the clutch is pretty robust?
2019 M3W Black
Re: How to properly launch the M3W [Re: Bluesman] #619633
29/02/20 04:06 AM
29/02/20 04:06 AM
LightSpeed Offline
LightSpeed  Offline
It is not like any other clutch I have used. I learned to drive on a new MGA Coupe, had a Sprite, a TR4a IRS, a one ton truck with compound low, a 1939 Caterpillar dozer, several VWs and none of them had clutches like this thing.
Stephen
2019 M3W
Re: How to properly launch the M3W [Re: Bluesman] #619660
29/02/20 09:01 AM
29/02/20 09:01 AM
Hertfordshire
O
Obie Offline
Obie  Offline
O
Hertfordshire
What you say about not luging the motor is correct, be gentle on the throttle until above 2500rpm.
I find the M3W is actually very easy to drive, being so light with plenty of power it’s easy to make a quick getaway at say a roundabout and leave most cars behind without much trouble and the gear change is wonderful.
Get the clutch out quickly and don’t slip it too much is the way to go.
It’s a bit more difficult to get it right when going for a maximum speed launch.
Re: How to properly launch the M3W [Re: Bluesman] #619926
01/03/20 07:15 PM
01/03/20 07:15 PM
Gods own county! Oop north
Dab of oppo Offline
Dab of oppo  Offline
Mechanical sympathy is my watch word.
Your car will tell you when you have got it right, just a little experimentation is all that is required.
Re: How to properly launch the M3W [Re: Bluesman] #619934
01/03/20 07:45 PM
01/03/20 07:45 PM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
I think as Dab of Oppo says, mechanical sympathy is the thing to keep in mind. If you do get a bit heavy footed with things the back wheel will probably be the thing that limits the amount of power that can be put down by spinning up. I have just put my M3W back on the road after its winter lay up, that included fitting all the Bleazey mods to the Centa. I would say that the transmission now copes well with 2000 rpm in top, no shunting as there was before. I am most impressed with the improvements to the smoothness of the transmission but it still caught me out, after 7 years of driving M3W's, just how easy it is to loose traction with the back wheel, particularly on a slightly damp road. It was great to be back out in the M3W after 4 months, even in the cold.
Moderated by  Aeroman
