5 registered members (Rob Thornton, Vampirex, thelastgizmo, HeadlessBlue, BuyBritish), 190 guests, and 13 spiders.
John V6 464
+8Rich 398
TBM 240
Peter J 196
Where to go first
by thelastgizmo. 31/05/20 05:52 AM
Fossilmog Hive Beach Picnic 2020 Cancelled
by rid967. 30/05/20 10:20 PM
Testing out a steering wheel spacer
by JohnMat. 30/05/20 10:04 PM
Wearing Face Masks
by Peter J. 30/05/20 06:03 PM
New toy
by Bonesie. 30/05/20 05:31 PM
Interested in a Morgan/Motorcycle Ride VA/WV
by 2Sharp. 30/05/20 05:06 PM
Please help me find my first Morgan
by Roady. 30/05/20 04:04 PM
Auchindoir Church, Lumsden
Plus four Test Drive
Engine running!
Slow progress
Social distancing
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,369
Posts628,703
Members6,938
Most Online1,033
Dec 28th, 2019
7024, hbatts
+8 at the petrol station #626405
27/03/20 11:20 PM
27/03/20 11:20 PM
Luxembourg
Ivo Offline OP
TM Photographer of 2011
Ivo  Offline OP
Luxembourg
Hi friends,
Little question... Is it just me, who is entirely incapable, or ist that a feature of the +8?
With my Roadster, I found a position of the fuel pistol, that allowed me to fill the tank within a reasonable time. Not so with the +8. The pistol keeps shutting down, so the filling process takes forever. Tried it twice and gave up each time, before the tank was completely filled.
With the Roadster, it was also possible, to pull the pistol out and let the fuel flow into the filling hole. The +8 has a spring loaded “lid” covering the filling hole, which is pushed open, when the pistol is inserted, so this solution does nor work. Next time I will try to hold the lid open, with a cocktail spool with a long handle. But that can’t be the solution.
How long does it take you, to fill up your Morgan?
Sunny greetings,
Ivo
sunny
1998 +8
Re: +8 at the petrol station [Re: Ivo] #626406
27/03/20 11:47 PM
27/03/20 11:47 PM
West Dorset
rid967 Offline
rid967  Offline
West Dorset
My Roadster is slow to fill. I get kick back on the nozzle when the tank is probably no more than 75% full. I sometimes get better flow by moving the nozzle around but it is inconsistent. It just takes patience.
However, having had a problem last year by overfilling the car, I tend now not to worry too much about getting a really full tank.
3.7 Roadster
Porsche 964 C2
JCW Mini Cooper S Cab
BMW 1200 GS
+4 4 1995-2002 / LM 62 +8 2002-07
Re: +8 at the petrol station [Re: Ivo] #626408
28/03/20 12:08 AM
28/03/20 12:08 AM
Taffmog Offline
Taffmog  Offline
Try turning the handle to 12 o’clock, may help.
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
Re: +8 at the petrol station [Re: Ivo] #626429
28/03/20 08:08 AM
28/03/20 08:08 AM
Luddite Offline
Luddite  Offline
My old mid 80`s +8 has two filler caps, the idea being to open both while fuelling up at petrol stations, one opened as a filler and the other opened as a vent to stop the pump cutting out due to back pressure, works just fine.. with no fiddling around..!
Re: +8 at the petrol station [Re: Ivo] #626435
28/03/20 08:32 AM
28/03/20 08:32 AM
Rovert Offline
Rovert  Offline
My 2002 +8 is desperately slow to fill, No matter how I twist my nozzle!
Brian
Jersey and Spain
Re: +8 at the petrol station [Re: Ivo] #626437
28/03/20 08:33 AM
28/03/20 08:33 AM
East Anglia
madmax Offline
madmax  Offline
East Anglia
Its one of the many 'joys' of owning a Morgan I'm afraid , 'they all do it sir' is very true of this particular trait ! 3. 0'clock position seems to work on this model ! banghead
Re: +8 at the petrol station [Re: Ivo] #626446
28/03/20 08:59 AM
28/03/20 08:59 AM
London
MOG 615 Offline
MOG 615  Offline
London
The +8 of the late 90s and early 2000s can be slow to fill but there are a couple of things you can do to alleviate the situation.
1 As above use the filler hose at the 12 o'clock position rather than 6 o'clock
2 Take off the panel behind the spare wheel to expose the hose from the filler cap to the tank. You will see that it goes through pretty sharp bends as it transits from the cap on the drivers side , to the tank on the passengers side. Make sure that this hose is not kinked anywhere. Release the jubilee clips and try to get the hose to "line up" in a way that eases the flow. Be careful you don't precipitate another problem by kinking the overflow hose by doing these mods.
While you are there have a very good look at that hose , it can and does perish, as I can testify, quite an expensive part (approx £50 from my poor memory) but better replaced than a fuel seepage and
3 If all the above does not give sufficient improvement take the fuel filler cap off the car's back panel (after first releasing the jubilee clip holding it to the hose) , and very carefully drill another hole (or two) in the secondary cap (where the cut off plate is located) near the existing one. This will aid venting. However if you are in any doubt about where to drill , please take it to a Morgan dealer or below enthusiast who does and enlist their help. It goes without saying that you MUST do this off the car , the last thing you want is metal swarf in the tank. Also make sure that the cap is thoroughly cleaned before refitting, you must get rid of ALL the metal filings. i will try to take a picture of mine at some later date (bit dark in the garage to get a good image)
Andy G
1999 +8 , Indigo Blue.
Re: +8 at the petrol station [Re: Ivo] #626453
28/03/20 09:25 AM
28/03/20 09:25 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
My Roadster fills with the nozzle at 11 or 1 oclock
2006 Indigo Blue Roadster S1
Re: +8 at the petrol station [Re: Ivo] #626466
28/03/20 10:34 AM
28/03/20 10:34 AM
Normandy, France
Vampirex Online content
Vampirex  Online Content
Normandy, France
I have an "Aston Martin" filler cap mounted by my Morgan dealer, and I don't have any trouble to fill up.
Re: +8 at the petrol station [Re: Ivo] #626472
28/03/20 11:20 AM
28/03/20 11:20 AM
Devon, UK
KennethM Offline
KennethM  Offline
Devon, UK
No problem on my 2003 +8 if the nozzle is at around 7 or 8 o'clock at almost all petrol stations - one in Inverness just wouldn't fill at normal speed - seems it was the shut off on the nozzle was too sensitive as my brother's e-Type had the same problem!
Ken
2003 +8 35th Anniv. Model
Moderated by  Aeroman, Simon
