4 registered members (RB1, petemog, PaulV, Bonesie), 176 guests, and 22 spiders.
John V6 464
+8Rich 398
TBM 240
Peter J 196
Fossilmog Hive Beach Picnic 2020 Cancelled
by rid967. 30/05/20 10:20 PM
Testing out a steering wheel spacer
by JohnMat. 30/05/20 10:04 PM
Wearing Face Masks
by Peter J. 30/05/20 06:03 PM
New toy
by Bonesie. 30/05/20 05:31 PM
Interested in a Morgan/Motorcycle Ride VA/WV
by 2Sharp. 30/05/20 05:06 PM
Please help me find my first Morgan
by Roady. 30/05/20 04:04 PM
How to social distance
by John V6. 30/05/20 11:56 AM
Plus four Test Drive
Engine running!
Slow progress
Social distancing
Somewhere in Scotland?
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,367
Posts628,700
Members6,938
Most Online1,033
Dec 28th, 2019
7024, hbatts
Oil pressure tubing #628349
05/04/20 11:09 AM
05/04/20 11:09 AM
Salisbury, England
DaveK Offline OP
DaveK  Offline OP
Salisbury, England
Getting the small bits together for my rebuild. I'm after the tubing and the connections from my Kent engine block to the back of my Smith dial, which of course is shared with fuel gauge reading etc. Has anyone in the Talk Morgan world any ideal where I can get a new one. In the pass it was set up to pump oil onto the Kingpins but of course that will be binned as I just use grease like most people these days. Apart form the pre war Oily rag brigade!
Apart from that has everyone please stay safe.
Navy Dave
1976 Morgan 4/4
Re: Oil pressure tubing [Re: DaveK] #628357
05/04/20 11:29 AM
05/04/20 11:29 AM
Powick
tmg513 Offline
tmg513  Offline
Powick
https://www.carbuilder.com/uk/oil-pressure-gauge-tubing-kit
I don't know about the thread sizes but this might do it.
1972 4/4 2 Seater
Re: Oil pressure tubing [Re: DaveK] #628361
05/04/20 11:44 AM
05/04/20 11:44 AM
Derby
PhilRoyle Offline
PhilRoyle  Offline
Derby
I about to suggest carbuilder.com - if you order from them ask for a catalogue - full of ideas and tips as well as items they stock. Pure petrolhead porn!
Their service is very good in my experience.
Re: Oil pressure tubing [Re: DaveK] #628413
05/04/20 02:35 PM
05/04/20 02:35 PM
Evergreen, Colorado, USA
britmog Offline
britmog  Offline
I took the original parts from my 64 4/4 to the local plumbing store and easily found exact replacements, cheap too.
Bruce Marshall
1994 +8 (Maurice)
2013 M3W (Olga)
Re: Oil pressure tubing [Re: DaveK] #628424
05/04/20 03:11 PM
05/04/20 03:11 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
The fittings are 1/8 BSP - although I don't know if they are flat or cone ends. (if you find out, please let me know!)
1972 4/4 4 seater
Too many ratty motorbikes
Re: Oil pressure tubing [Re: DaveK] #628426
05/04/20 03:13 PM
05/04/20 03:13 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
This is the one I fancy . Oil Pressure line
1972 4/4 4 seater
Re: Oil pressure tubing [Re: DaveK] #628483
05/04/20 07:28 PM
05/04/20 07:28 PM
The frozen North
Jack The Lad Offline
Posting Desperado
Posting Desperado
The frozen North
Just spotted you .
give this place a call
A.E. TAYLOR AND CO . LTD
44 BOROUGH RD.
SUNDERLAND
SR1 1PW.
0191 5675078
EST OVER 100 YEARS
SPECIALISTS ON ALL TYPES OF RUBBER AND PLASTIC HOSING
LOOK THEM UP ON THE NET . AND GIVE THEM A CALL
USED THEM A FEW TIMES .
GOOD LUCK
Re: Oil pressure tubing [Re: DaveK] #628583
06/04/20 10:16 AM
06/04/20 10:16 AM
Norfolk
thelastgizmo Offline
Norfolk
As a recent Morgan owner (1974 4/4) I'm not familiar with what is involved in binning the oil feed to the suspension. I've only just discovered the well hidden valve on the bulkhead (after reading the original manual!). Is this documented anywhere?
Re: Oil pressure tubing [Re: DaveK] #628589
06/04/20 10:26 AM
06/04/20 10:26 AM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
I put grease nipples on the top of the kingpins (not used, but keep the crud out) and then fit blanking plugs to the plunger. All fittings were 1/8 BSP
Oiler removal
1972 4/4 4 seater
Re: Oil pressure tubing [Re: DaveK] #628969
07/04/20 10:35 PM
07/04/20 10:35 PM
Salisbury, England
DaveK Offline OP
DaveK  Offline OP
Salisbury, England
To thelastgizmo - I brought my MOG back in 2002 and the previous owner had already fitted grease nipples to the top and bottom. In fact it has the remote grease which is located on the inner wing. The idea being you don't have to struggle to do the top of the kingpins. Good bit of kit. When I stripped down my MOG I noticed that the valve located on the bulkhead which was left in location had he would have left a large hole.
Many thanks to everyone else for your replies.
Stay safe!
Navy Dave
1976 Morgan 4/4
Moderated by  Aeroman, Simon
