18 registered members (B3MOG, RobCol, Gordon D, M3W55, Alistair, JohnMat, teifistar, Brilliant Green, BLUE+4, Mike D, TBM, 60Yards, TimB, DavidR, Stockpie, Fuel.inj, JB62, Bitsobrits), 224 guests, and 14 spiders.
John V6 490
+8Rich 371
TBM 242
Peter J 204
Teaser post - Bonnet safety locks
by Marmota. 25/05/20 05:10 PM
Adhesives for trim and bodywork
by Rob Thornton. 25/05/20 03:18 PM
Loose door hinge bolts - 09 +4
by Kevcaster. 25/05/20 12:57 PM
Heads up , crankcase breather hose for Roadster
by John V6. 25/05/20 11:59 AM
Expensive accident
by madmax. 25/05/20 11:31 AM
What is winding you up at the moment?
by Philippo. 25/05/20 08:51 AM
Social distancing
Somewhere in Scotland?
M3W Cupholder
"Marty" outside our home 'Waunfach'!
All Morgans' Day 2020 Lapel Badge
jaktomaten, Bewifourfour, Sam8888, Brilliant Green, ninrum
6938 Registered Users
Topics38,315
Posts627,640
Members6,938
Most Online1,033
Dec 28th, 2019
+8Rich, ChrisR
Swing arm bearings and dust caps #628692
06/04/20 06:04 PM
06/04/20 06:04 PM
Furry Boots City
RedThree Offline OP
RedThree  Offline OP
Furry Boots City
Having been self isolating in my garage doing various tasks I noticed some movement on one swing arm bearing and the absence of the dust cap on that side. Having taken the swing arm out found that the bearing without a cap on it was every bit as trashed as you might expect. I've got the bearings and the oil seals out and new ones ordered but what I haven't found, probably mainly because I don't know exactly what they are called, are replacement caps that go on the open side of the swing arm bearing housings. Anyone got any inspiration? Obviously I have one but would like two new ones.
Re: Swing arm bearings and dust caps [Re: RedThree] #628697
06/04/20 06:24 PM
06/04/20 06:24 PM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
Rear swing arm bearing dust excluder caps are 48mm dia, 44mm inside and 18mm deep, there are some on ebay usually. Your LH swing arm bearing cap was probably never fitted, as with many M3Ws. I assume this because when the swing arm is adjusted almost fully to the left to align the drive belt sprockets, the bevel box sprocket will touch the dust cap as it stands proud by a few mm. I have used some aluminium speed tape as a dust excluder as it takes up less room and allows a little more adjustment. The swing arm parts info is in the Alternative Parts List, Suspension section on page 4. Try searching for "round plastic blanking end caps" on Ebay.
Re: Swing arm bearings and dust caps [Re: RedThree] #628700
06/04/20 06:38 PM
06/04/20 06:38 PM
Furry Boots City
RedThree Offline OP
RedThree  Offline OP
Furry Boots City
That would explain it...will have a look on eBay and at what I can do with the one by the sprocket which was indeed the missing one.
Thanks.
Re: Swing arm bearings and dust caps [Re: RedThree] #628701
06/04/20 06:39 PM
06/04/20 06:39 PM
SW Iowa, U.S.A.
Bitsobrits Online content
Bitsobrits  Online Content
SW Iowa, U.S.A.
Calum,
When I had my swingarm out I noticed the bearing dust caps filled to my car were a basic plastic hole plug, roughly 2" diameter (guess only, not a proper measurement).
One of mine was flanged and fitted "outside" of the tube portion where the bearing rides, and the other one (drive side) had the flange ground off and was pushed down into the tube, likely because that side has next to no clearance for a dust cap. No sealer was noted with either cap. When I was putting it all back together I changed the "outside" cap to an "inside" type to match the other, tapped them into the recess, then applied a generous amount of silicone sealant to the outside circumference to keep dust out and the caps in place.
The moral here is that if you only see one dust cap don't assume the other isn't there. It may just be pushed deeper in the opening. And if there is no dust cap, as Calum and others have noted, the bearing will very likely be in pretty bad shape.
2012 M3W #458
Iowa, U.S.A.
Re: Swing arm bearings and dust caps [Re: RedThree] #628704
06/04/20 06:44 PM
06/04/20 06:44 PM
Leicestershire, UK
Bunny Offline
Bunny  Offline
Leicestershire, UK
Thanks.
Surely you would just machine one up from a blank billet Calum? innocent
Andy
Re: Swing arm bearings and dust caps [Re: Bunny] #628713
06/04/20 07:01 PM
06/04/20 07:01 PM
Furry Boots City
RedThree Offline OP
RedThree  Offline OP
Furry Boots City
Thanks.
That is Plan B... crazy2
Moderated by  Aeroman
