2 registered members (pete757, JohnMat), 96 guests, and 14 spiders.
John V6 434
+8Rich 403
Hawki 183
Rear brake drums - 1980 4/4
by BigLes. 13/07/20 06:53 PM
Its finally here!!
by NickCW. 13/07/20 02:55 PM
Outdoor Cover for M3W
by WilsonLaidlaw. 13/07/20 02:42 PM
Brake problems after lockdown
by teifistar. 13/07/20 12:31 PM
Breakdown tow
by Pontruggermogger. 13/07/20 10:06 AM
Morgan jackets
by NickCW. 13/07/20 07:42 AM
Driver dies in Morgan accident
by Taffmog. 12/07/20 11:29 PM
peek a boo
Donington Sunday (part 2)
Donington Sunday
My old Matt black Aero
No More Five Mile Limit
GJT, Saxonian, GlenB 4475, Simon m wright, dominicalbarn
7054 Registered Users
Topics38,781
Posts637,693
Members7,054
Most Online1,033
Dec 28th, 2019
john humphreys
Rear lap belts #640626
27/05/20 01:05 PM
27/05/20 01:05 PM
Northants, UK
TBM Offline OP
TBM  Offline OP
Northants, UK
I'm thinking of putting a couple of lap belts into the back of my 4 seater for the very occasional times I may take rear passengers and to strap a dog harness to when we ulitmately get a couple of rescues.
Anyone got any advice or photos of how they've been installed? Looking at early style with a bench rear seat.
Cheers
Phil
1972 4/4 4 seater
Too many ratty motorbikes
Re: Rear lap belts [Re: TBM] #640639
27/05/20 02:03 PM
27/05/20 02:03 PM
Aberdeenshire
Image Offline
Image  Offline
Aberdeenshire
TBM .... on mine they bolt through the rear seat base frame using the three holes marked by the orange dots .....both belts share the middle mounting bolt
Cheers
Re: Rear lap belts [Re: TBM] #640641
27/05/20 02:15 PM
27/05/20 02:15 PM
Northants, UK
TBM Offline OP
TBM  Offline OP
Northants, UK
Great, thank you.
Is that bar welded in? It doesn't exist on mine. Should be very easy to replicate.
Could you give me the dimensions of the angle iron if possible? Looks about 25mm x 25mm x 2 or 3mm
Cheers
Phil
1972 4/4 4 seater
Re: Rear lap belts [Re: TBM] #640659
27/05/20 04:04 PM
27/05/20 04:04 PM
Aberdeenshire
Image Offline
Image  Offline
Aberdeenshire
Phil ....on mine the rear seat base is a welded up rectangle of angle iron that bolts through the inner ply arches either side (with a pressed steel panel that drops in to fill the centre for the seat squab to sit on) .... Acts as a nice stabiliser for the rear of the tub (hence I haven't removed it to pretty it up yet)
The angle is ..
32x32x5 mm
Though I suspect it's actually an old imperial size but I don't have a caliper that reads in pounds, shillings and pence smile
Let me know if need more pics.
Re: Rear lap belts [Re: TBM] #640661
27/05/20 04:37 PM
27/05/20 04:37 PM
Northants, UK
TBM Offline OP
TBM  Offline OP
Northants, UK
Cheers.
On mine I just have the front and sides of the frame, and then the pressed steel plate sat on the tank. There were three 'clips' on top of the tank (you can just see one of them in front of the fuel filler hose) that the pressed steel plate slotted into. I flattened them so I could fit my wooden luggage board things.
I reckon I could easily fit a chunk of angle just in front of the small uprights where the rear seat back slots into (you can just make it out on the top of the photo, to the right of the filler).
1972 4/4 4 seater
Re: Rear lap belts [Re: TBM] #640711
27/05/20 08:23 PM
27/05/20 08:23 PM
Aberdeenshire
Image Offline
Image  Offline
Aberdeenshire
Phil ... welding is a problem with the inner arch right there but if you had a triangular plate at each end so you could use three decent tensile bolts each side then that would be as strong as the couple of inches of weld. The end result would be better than the current fresh air belts by a long way .
Re: Rear lap belts [Re: TBM] #640746
27/05/20 09:37 PM
27/05/20 09:37 PM
SimonH Offline
SimonH  Offline
Originally Posted by TBM
Cheers.
That explains why you can lift the tank out through the top then.... innocent
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Re: Rear lap belts [Re: SimonH] #640748
27/05/20 09:44 PM
27/05/20 09:44 PM
Northants, UK
TBM Offline OP
TBM  Offline OP
Northants, UK
Is my set up fairly unique? With the clips on the tank it all seems fairly unmolested.
1972 4/4 4 seater
Re: Rear lap belts [Re: TBM] #640758
27/05/20 10:22 PM
27/05/20 10:22 PM
Northants, UK
TBM Offline OP
TBM  Offline OP
Northants, UK
Just checked the photos Mike Pullen sent me of his rear conversion on his 1971 (I think) 4seater and his doesn't have the crossbar either. Must have been a later addition post 1972.
1972 4/4 4 seater
Re: Rear lap belts [Re: Image] #640779
28/05/20 06:56 AM
28/05/20 06:56 AM
Northants, UK
TBM Offline OP
TBM  Offline OP
Northants, UK
Good plan. As you say, anything is better than nothing!
Just need to sort out a postion. Had a look last night and the seat back bows forward to much to stick a bar directly infront of the metal uprights. Will have to come forward a bit. You can see the uprights better in this pic of Mike's - I've ringed them. You can also see the little tank clips - he hasn't flattened his. Womder with the went for the change.
IIRC I think Mike also fitting a bar and lapbelts - I'll see if he's got any photos of his install.
1972 4/4 4 seater
Moderated by  Aeroman, Simon
