2 registered members (2Sharp, Moggo), 105 guests, and 11 spiders.
John V6 434
+8Rich 403
Hawki 183
Rear brake drums - 1980 4/4
by BigLes. 13/07/20 06:53 PM
Its finally here!!
by NickCW. 13/07/20 02:55 PM
Outdoor Cover for M3W
by WilsonLaidlaw. 13/07/20 02:42 PM
Brake problems after lockdown
by teifistar. 13/07/20 12:31 PM
Breakdown tow
by Pontruggermogger. 13/07/20 10:06 AM
Morgan jackets
by NickCW. 13/07/20 07:42 AM
Driver dies in Morgan accident
by Taffmog. 12/07/20 11:29 PM
peek a boo
Donington Sunday (part 2)
Donington Sunday
My old Matt black Aero
No More Five Mile Limit
GJT, Saxonian, GlenB 4475, Simon m wright, dominicalbarn
7054 Registered Users
Topics38,781
Posts637,691
Members7,054
Most Online1,033
Dec 28th, 2019
john humphreys
She lives! #641440
31/05/20 02:58 PM
31/05/20 02:58 PM
Bethel, CT USA
PaulyG Offline OP
PaulyG  Offline OP
Bethel, CT USA
Got the car back on the road yesterday. A huge thank you to Arwyn Williams who connected me with the shifter I needed as the original one came loose in my hand. Very different feel that will take a little getting used to, but it feels so much more solid than the old one.
BTW, post from UK to US took just under 3 weeks.
Of course, we get back home from our trip out to find that the water pump is leaking, and a noise from the left front on hard right turn leaves me to believe I may have a wheel bearing issue.
Never a full moment!
Re: She lives! [Re: PaulyG] #641442
31/05/20 03:07 PM
31/05/20 03:07 PM
Costock, South Nottinghamshire...
Paul F Offline
Paul F  Offline
Congratulations on fixing the gearbox.
One step forwards, two steps back. Hopefully, the parts you now need will be available locally to you.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Re: She lives! [Re: PaulyG] #641444
31/05/20 03:10 PM
31/05/20 03:10 PM
Bethel, CT USA
PaulyG Offline OP
PaulyG  Offline OP
Bethel, CT USA
Thanks. So far no one near me carries the water pump so that will be a day or two.
Re: She lives! [Re: PaulyG] #641451
31/05/20 03:32 PM
31/05/20 03:32 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
The rubber of the tyres can touch the chassis on full lock. There is even a wear plate on the chassis. That might be the noise.
2006 Indigo Blue Roadster S1
Re: She lives! [Re: PaulyG] #641464
31/05/20 04:02 PM
31/05/20 04:02 PM
Bethel, CT USA
PaulyG Offline OP
PaulyG  Offline OP
Bethel, CT USA
I thought of that, but I wasn't at full lock. It's a down hill slightly off camber turn. I've got a little movement with the front end jacked up, but I read I GoMog that it might be a caster nut adjustment. Wondering if I should pull the hub off since the wheel is off, just to look around.
Re: She lives! [Re: PaulyG] #641466
31/05/20 04:14 PM
31/05/20 04:14 PM
Bethel, CT USA
PaulyG Offline OP
PaulyG  Offline OP
Bethel, CT USA
With the wheel off I grab the disk top and bottom and give it a wiggle. If I tighten the caster nut to where it just makes contact the wiggle stops. But then I have to loosen the nut a little to get the cotter pin on, and I'm back where I started.
Thoughts?
Re: She lives! [Re: PaulyG] #641474
31/05/20 04:59 PM
31/05/20 04:59 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
What sort of noise were you getting? My nearside front bearing started 'ticking/clicking' on corners (but only on one direction - I think it was right handers). Initially I managed to crimp up the nut and the noise went for a short while, but came back again. Ended up replacing the bearings - fairly easy job, and make sure you order by the serial numbers (listed on gomog) as you'll get them for a fraction of the cost from a bearing specialist. I've got the grease seal number somewhere too,
1972 4/4 4 seater
Too many ratty motorbikes
Re: She lives! [Re: PaulyG] #641476
31/05/20 05:02 PM
31/05/20 05:02 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
Grease seal is SKF15004
1972 4/4 4 seater
Re: She lives! [Re: PaulyG] #641519
31/05/20 08:12 PM
31/05/20 08:12 PM
Massachusetts, USA
morgan_75 Offline
morgan_75  Offline
Massachusetts, USA
Just noticed that you're in CT. You're only 2.5 hours from Morgan Spares and half an hour from Quantum Mechanics. Quantum Mechanics specializes in gearboxes and differentials. Morgan Spares can handle anything for your car, parts or service.
'61 +4 DHC
'70 4/4
'80 4/4 4seater
Re: She lives! [Re: PaulyG] #641523
31/05/20 08:30 PM
31/05/20 08:30 PM
Arwyn Williams Offline
Thanks Paul for the kind words.
I'll explain a little about the gear shifter:
It's one that I modified from an aftermarket competition part about 18 months ago when I had a similar problem to Paul's.
The part came from either Rix Engineering or Matt Lewis Racing, can't remember which!
Instead of various plastic washers and plastic threaded parts there is a screwed housing containing a spherical bearing. There are two spanner flats to enable the housing to be tightened onto the gearbox
As supplied it's far too long. So I shortened it in the lathe and threaded the top part Its also too thin and would look odd sticking though the gaiter.
So I made up a top frollm a scrap piece of 1" stainless bar which was then tapped to match the thread I'd cut previously. I then cross drilled it and tapped it for locking screws and also cut a thread for the gear knob.(This is the part you can see sticking through the gaiter in Paul's photo.
I heated the top with an oxy torch and bent it over.
A quick polish with some emery tape to get rid of the tooling marks and then a buff of the polishing wheel.
Did 2000 miles with no issues and it became surplus when I changed to a 5 speed box in Feb this year
Arwyn
Moderated by  Aeroman, Simon
