3 registered members (2Sharp, Georgetoad, Cuna2016), 102 guests, and 13 spiders.
John V6 434
+8Rich 403
Hawki 183
Rear brake drums - 1980 4/4
by BigLes. 13/07/20 06:53 PM
Its finally here!!
by NickCW. 13/07/20 02:55 PM
Outdoor Cover for M3W
by WilsonLaidlaw. 13/07/20 02:42 PM
Brake problems after lockdown
by teifistar. 13/07/20 12:31 PM
Breakdown tow
by Pontruggermogger. 13/07/20 10:06 AM
Morgan jackets
by NickCW. 13/07/20 07:42 AM
Driver dies in Morgan accident
by Taffmog. 12/07/20 11:29 PM
peek a boo
Donington Sunday (part 2)
Donington Sunday
My old Matt black Aero
No More Five Mile Limit
GJT, Saxonian, GlenB 4475, Simon m wright, dominicalbarn
7054 Registered Users
Topics38,781
Posts637,689
Members7,054
Most Online1,033
Dec 28th, 2019
john humphreys
Hood frame rattle #641467
31/05/20 04:16 PM
31/05/20 04:16 PM
Sevenoaks,Kent
Viper Offline OP
Sir S1'a'lot
Viper  Offline OP
Sir S1'a'lot
Sevenoaks,Kent
Hood down and frame strapped down but rattled like mad
Do I recall seeing a sort of rubberised separation implement to stop the bars vibrating against each other. I think similar to some treacles use to separate their toes while they paint their nails............so I’ve heard innocent
Life is a bowl full of cherries....there you go wink
Re: Good frame rattle [Re: Viper] #641473
31/05/20 04:58 PM
31/05/20 04:58 PM
Evesham, Worc, UK
DJWuk Offline
DJWuk  Offline
Evesham, Worc, UK
Had same problem. Cut down some self adhesive foam strips (circa 3mm thick) into thin strips and stuck between frame poles. Now silent.
Dave
2011 +4 Sport
1970 Elan +2S
Re: Good frame rattle [Re: DJWuk] #641478
31/05/20 05:12 PM
31/05/20 05:12 PM
Sevenoaks,Kent
Viper Offline OP
Sir S1'a'lot
Viper  Offline OP
Sir S1'a'lot
Sevenoaks,Kent
Perfect. Might be my only option.
Re: Good frame rattle [Re: Viper] #641499
31/05/20 06:29 PM
31/05/20 06:29 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Depends on the car. It could be better to drill out the rivets & replace with nuts & bolts.
2006 Indigo Blue Roadster S1
Re: Good frame rattle [Re: Viper] #641573
01/06/20 08:59 AM
01/06/20 08:59 AM
PHZI Offline
PHZI  Offline
Is an easy up or trad hood? Different solutions. Mine is a trad hood with drop pivots and solved it eventually by trial and error. Tying down, cushioning and making sure pivot securing bolts were tight.
Re: Good frame rattle [Re: Viper] #641587
01/06/20 10:31 AM
01/06/20 10:31 AM
Sevenoaks,Kent
Viper Offline OP
Sir S1'a'lot
Viper  Offline OP
Sir S1'a'lot
Sevenoaks,Kent
It’s a trad hood frame. Not easy style or an a cantilever.
It’s nut and bolted. The bars vibrate against each other
Re: Good frame rattle [Re: Viper] #641607
01/06/20 02:01 PM
01/06/20 02:01 PM
Surrey
Kevcaster Offline
Kevcaster  Offline
Surrey
Yes this can drive a person mad. I have a system of saddle leather pads held with double sided tape placed where the stays bang together and velcro straps to hold it all tightly so that the hood bounces 'as one'. Once the hood is folded the velcro straps get tied around the frame stays on each side. I had a maddening rattle from one of the washers between two stays, for this I hammered the rivet tighter and that worked. My 4 seater is not as silent as a Roller but it is so much more quiet that it was.
Kevin
2009 Morgan Plus 4 4 seater
Re: Good frame rattle [Re: Viper] #641958
03/06/20 12:52 PM
03/06/20 12:52 PM
PHZI Offline
PHZI  Offline
Yes a strip of Velcro in and out of the frame plus tightening down with the standard leather straps as fitted to the car, seems to work for me. The cantilever drop pivots that I have also add another tightening dimension once the hood is dropped. If you haven't't got the drop pivots, worthwhile fitting. Circa £70 from John Taylor.
Re: Good frame rattle [Re: Viper] #642357
05/06/20 11:53 AM
05/06/20 11:53 AM
Cambridge UK
Stephen888 Offline
Stephen888  Offline
Cambridge UK
Who needs a hood? Dumped mine plus the frame in 1987!
1980 +8 Blue
Stephen
Re: Good frame rattle [Re: Stephen888] #642707
06/06/20 09:19 PM
06/06/20 09:19 PM
Northern Germany
bmgermany Offline
bmgermany  Offline
Northern Germany
I think I am the winner: 400000 Km without a hood -on motorbikes in summer and winter!
We bougt the 4/4 because it HAS A HOOD (for bad weather) ;-)
Each on his own!
Moderated by  Aeroman, Simon
