2 registered members (M3W55, RB1), 121 guests, and 25 spiders.
John V6 450
+8Rich 415
Hawki 179
Sweet Painted Lady
by +8Rich. 09/07/20 09:15 PM
door handle cylinder barrels
by BigLes. 09/07/20 07:19 PM
E10 Fuel Parts
by DaveK. 09/07/20 02:23 PM
Group runs out.
by Hawki. 09/07/20 12:28 PM
MULFAB Panhard Rod
by Grumpy2. 09/07/20 08:13 AM
Brooklands Wheel from MMC
by Perry_P_M3W. 08/07/20 10:55 PM
Loose Marbles
by +8Rich. 08/07/20 06:46 PM
Another Great Escape. Caister Motor Museum
RUY255 on Autosport Cover
why we love living in the mountains
Our 2020 Morgan Plus 4   110 Anniversary Model
My new Plus Four
Saxonian, GlenB 4475, Simon m wright, dominicalbarn, Sib8292
7053 Registered Users
Topics38,746
Posts636,948
Members7,053
Most Online1,033
Dec 28th, 2019
Stevey B, Sukram, waikiore
1974 4/4 heater #641829
02/06/20 08:15 PM
02/06/20 08:15 PM
Norfolk
thelastgizmo Offline OP
Norfolk
Is there a heater valve on this age car? If not can one be fitted without compromising the water flow. It got a bit warm around the knees driving in the sunshine today!
Re: 1974 4/4 heater [Re: thelastgizmo] #641830
02/06/20 08:18 PM
02/06/20 08:18 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
I fitted one to mine, controlled by Bowden cable. Has a bypass circuit so just cuts off water flow to the heater matrix,
You can just see it on the right of this picture.
1972 4/4 4 seater
Too many ratty motorbikes
Re: 1974 4/4 heater [Re: thelastgizmo] #641883
03/06/20 08:43 AM
03/06/20 08:43 AM
Norfolk
Norfolk
Thanks TBM. I see you must have a different sort of heater to my '74 model. I have a bulkhead mounted box with horizontally opposed inlet/outlet pipes. One of my hoses comes from the front of the engine via the nearside side of the engine. I also have twin circular outlets facing rearwards on the blower box. Seems they added these in 1974 for demister vents (which I don't have!).
I'll look out for the valves with inbuilt bypass.
I see you have fitted your uprated air filter. I must get one to replace the grotty wire gauze filter on mine.
Is that an after market exhaust manifold?
Re: 1974 4/4 heater [Re: thelastgizmo] #641887
03/06/20 09:00 AM
03/06/20 09:00 AM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
Similar system of pipes with mine -' hot' feed comes from inlet manifold and goes into heater matrix, and then it goes from matrix to a union on the water pump. Got the valve and bowden cable from eBay - Example Bypass Valve
Made a small bracket for the heater control and cable and it fits the opposite side of the steering column to the choke cable.
Filter is a 'deep' K&N. I had a shallow one, but didn't think there was much clearance from the lid of the filter and the top of the carb so bought a deeper one.
Manifold is a larger bore stainless Librands one, and then I made a large stainless side exit exhaust to join to it.
1972 4/4 4 seater
Re: 1974 4/4 heater [Re: thelastgizmo] #642018
03/06/20 03:53 PM
03/06/20 03:53 PM
Norfolk
Norfolk
I think I may try an electrically operated valve. I have a spare switch on the dashboard. Seem to be a few around.
Moderated by  Aeroman, Simon
