1 registered members (Sportster), 99 guests, and 24 spiders.
John V6 434
+8Rich 403
Hawki 183
Rear brake drums - 1980 4/4
by BigLes. 13/07/20 06:53 PM
Its finally here!!
by NickCW. 13/07/20 02:55 PM
Outdoor Cover for M3W
by WilsonLaidlaw. 13/07/20 02:42 PM
Brake problems after lockdown
by teifistar. 13/07/20 12:31 PM
Breakdown tow
by Pontruggermogger. 13/07/20 10:06 AM
Morgan jackets
by NickCW. 13/07/20 07:42 AM
Driver dies in Morgan accident
by Taffmog. 12/07/20 11:29 PM
peek a boo
Donington Sunday (part 2)
Donington Sunday
My old Matt black Aero
No More Five Mile Limit
GJT, Saxonian, GlenB 4475, Simon m wright, dominicalbarn
7054 Registered Users
Topics38,781
Posts637,692
Members7,054
Most Online1,033
Dec 28th, 2019
john humphreys
tempting fate maybe #642169
04/06/20 01:22 PM
04/06/20 01:22 PM
southwest France
meabh Offline OP
meabh  Offline OP
southwest France
Even"n all: gosh but yes I remember Dixon of Dock Green.
Since owning my Roadster. I have had the eml light come on from time to time. Always the same code, slow response on oxygen sensor. I replaced them at 8000 mile but after another five or so the eml would need cancelling from time to time so I decided to remove the sensors and leave them in a jar of petrol overnight. You would not believe the dirt and crud which lay in the bottom of the jar. It seems that a regular clean might wewll solve the problem. Time will tell.
Re: tempting fate maybe [Re: meabh] #642195
04/06/20 03:50 PM
04/06/20 03:50 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
Interesting. My car only does when hot & parked up for a while in cold weather and then on the passenger side.
It is though sensitive to cheaper fuel. I wonder if the E10 in France is adding to your issue?
2006 Indigo Blue Roadster S1
Re: tempting fate maybe [Re: meabh] #642199
04/06/20 04:09 PM
04/06/20 04:09 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
Meabh have you already tested the O2 sensor after cleaning? Is it still working at all? I had to replace my O2 sensor (before cat) last week after 80.000 km. The message was P2297, „signal out of range during deceleration“, firstly once in a week and then after each delete of errors soon again. And on the real-time graph you could see that the voltage jumps were wider and slower than with a new sensor. With the new O2 sensor I need noticable less fuel and the throttle response is better again.
It is such a gradual process to the worse that one first gets used to it. If your purification works I will try it after a year or so as well.
Re: tempting fate maybe [Re: meabh] #642226
04/06/20 05:15 PM
04/06/20 05:15 PM
Cornwall
griffo Offline
griffo  Offline
Cornwall
Not many people know that Jack Warner was a rally/race driver beforevthecwarvandvbefore he became an actor. He was my father,s co driver (in Riley's) several times in the Monte, the six days Alpine Race and other events in the 1930's.
Re: tempting fate maybe [Re: meabh] #642241
04/06/20 06:10 PM
04/06/20 06:10 PM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
Ah, Doxon of Dick Green...there's a distant memory...evenin’ all!
Doug
2011 +4 in Rich Maroon
Re: tempting fate maybe [Re: meabh] #642243
04/06/20 06:27 PM
04/06/20 06:27 PM
southwest France
meabh Offline OP
meabh  Offline OP
southwest France
Thanks for the replies.Heinz, so far so good. I'll clean them again when I service it.john, I can find E5 easily enough and always use 98 octane. However I did make a mistake a couple of weeks back, adding five gals of 95 which brought up the mIl light soon afterwards. Coincidence?
Re: tempting fate maybe [Re: meabh] #642246
04/06/20 06:53 PM
04/06/20 06:53 PM
South Oxfordshire
SFG Offline
SFG  Offline
South Oxfordshire
Where is the O2 sensor, please?
SFG
2012 4/4 Sport
Re: tempting fate maybe [Re: meabh] #642249
04/06/20 07:11 PM
04/06/20 07:11 PM
Devonshire
+8Rich Offline
+8Rich  Offline
Devonshire
The one on the Cat, from memory of a few years ago I think there is only one on the Sport, current owners will confirm.
Regards Richard
1994 Connaught Green +8 prev
Re: tempting fate maybe [Re: meabh] #642291
05/06/20 07:48 AM
05/06/20 07:48 AM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
On the S1 Roadster it is on the cat & there is only one each side.
Re: tempting fate maybe [Re: meabh] #642315
05/06/20 09:10 AM
05/06/20 09:10 AM
southwest France
meabh Offline OP
meabh  Offline OP
southwest France
SFG, on my 2010 Roadster there are two per exhaust. The first is to be found towards the lower front of each cat and the second is to be found to the rear but on top. This one is slightly recessed whereas the front one is easy to remove.
Moderated by  Aeroman, Simon
